Need template for a luggage rack onto Chally decklid?! #999565
05/25/11 10:31 AM
05/25/11 10:31 AM
FL
71GoMango Offline OP
FL
Is there anywhere to get a template for this or proper measurements? Just want to make sure its installed correctly. Thanks!
Re: Need template for a luggage rack onto Chally decklid?! [Re: 71GoMango] #999566
05/25/11 11:27 AM
05/25/11 11:27 AM
St. Louis, Mo
3
318 Stroker Offline
318 Stroker  Offline
St. Louis, Mo
You have mail...
Re: Need template for a luggage rack onto Chally decklid?! [Re: 318 Stroker] #999567
05/25/11 12:27 PM
05/25/11 12:27 PM
FL
FL
318 stroker, didnt see any mail?
Re: Need template for a luggage rack onto Chally decklid?! [Re: 71GoMango] #999568
05/25/11 05:47 PM
05/25/11 05:47 PM
St. Louis, Mo
3
318 Stroker Offline
318 Stroker  Offline
St. Louis, Mo
You have a PM
Re: Need template for a luggage rack onto Chally decklid?! [Re: 318 Stroker] #999569
05/26/11 09:28 AM
05/26/11 09:28 AM
FL
FL
I had to update my email, sorry, if you dont mind resending, thanks!
Re: Need template for a luggage rack onto Chally decklid?! [Re: 71GoMango] #999570
05/26/11 10:08 AM
05/26/11 10:08 AM
cataclysm80 Offline
cataclysm80  Offline
This can be enlarged by clicking on the "Attachment" link at the top of this post.
Tav
Re: Need template for a luggage rack onto Chally decklid?! [Re: 71GoMango] #999571
05/26/11 10:14 AM
05/26/11 10:14 AM
cataclysm80 Offline
cataclysm80  Offline
As for locating it on the decklid, I've never done it before, but I'd suggest measuring the distance between the rear outboard studs on the rack and checking to make sure it is the same as the distance between the center of the cutouts on the underside of the trunk lid.
As long as it's the same (I think it should be), drill your first two holes in the center of those cutouts.
Then, with some masking tape on your trunk lid to protect the paint, position the luggage rack on the trunk lid. Take some measurements to double check that it's centered where you want it. Now you can use it to mark on the tape, where the other four holes for the rivnuts need to be.
Are those rivnuts the same as the ones used for side mirrors? I think they are.
How are those holes suposed to be sealed so that water doesn't leak into your trunk? Perhaps some kind of sealer on the rivnuts when they are installed?
Tav
Re: Need template for a luggage rack onto Chally decklid?! [Re: cataclysm80] #999572
05/26/11 01:39 PM
05/26/11 01:39 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
The rivnuts otherwise known as nutserts are the same "T" design but instead of 10-24 they are 1/4-20..
Re: Need template for a luggage rack onto Chally decklid?! [Re: 1_WILD_RT] #999573
05/26/11 03:31 PM
05/26/11 03:31 PM
FL
FL
318 Stroker sent me this, just incase you want to add this to your file cataclysm, has a few more details on it.
Re: Need template for a luggage rack onto Chally decklid?! [Re: 71GoMango] #999574
05/26/11 03:39 PM
05/26/11 03:39 PM
FL
FL
Cataclysm, what part of FL are you in? Im up near Jacksonville, almost GA...
Re: Need template for a luggage rack onto Chally decklid?! [Re: 71GoMango] #999575
05/26/11 03:57 PM
05/26/11 03:57 PM
St. Louis, Mo
3
318 Stroker Offline
318 Stroker  Offline
St. Louis, Mo
Clay, Between Tav and I, I hope this gives you the info you need...
Re: Need template for a luggage rack onto Chally decklid?! [Re: 318 Stroker] #999576
05/26/11 04:30 PM
05/26/11 04:30 PM
FL
FL
Thanks, I should be good to go, looks like I should be centered and 4" from the front edge with those front two legs.
Re: Need template for a luggage rack onto Chally decklid?! [Re: 71GoMango] #999577
05/26/11 05:23 PM
05/26/11 05:23 PM
St. Louis, Mo
3
318 Stroker Offline
318 Stroker  Offline
St. Louis, Mo
Check the diagram again carefully. You should be 4" from the back edge, with the back legs...
Re: Need template for a luggage rack onto Chally decklid?! [Re: 318 Stroker] #999578
05/26/11 05:29 PM
05/26/11 05:29 PM
kalispell montana
jwilson 61 Offline
jwilson 61  Offline
kalispell montana
should be from the front edge to front leg
70 cuda 440 6bbl Auto with a dana 60
68 road runner QQ1 383 auto
1970 6 barrel 4 speed Superbird FY1 number matching
15 Challenger 6.4 SRT pearl White 6 Speed
72 Cuda 440 5 speed
71 Road Runner 440 4 speed
Re: Need template for a luggage rack onto Chally decklid?! [Re: jwilson 61] #999579
05/26/11 05:53 PM
05/26/11 05:53 PM
St. Louis, Mo
3
318 Stroker Offline
318 Stroker  Offline
St. Louis, Mo
After reading the last two posts, I believe you guys are right. Everyone was looking at the diagram correctly, but I had my semantics wrong. As I'm standing at the back of the car, I was calling the edge where the decklid hinges as the back edge. But it's towards the front of the car, so yes, it is actually the front edge. Sorry guys...
Re: Need template for a luggage rack onto Chally decklid?! [Re: 71GoMango] #999580
05/26/11 09:57 PM
05/26/11 09:57 PM
cataclysm80 Offline
cataclysm80  Offline
Wow, Hey Thanks! That will be a nice addition to my collection. I've gotten some other really nice info from Allen (318 Stroker) in the past also.
Hi Allen, Thanks to you to!
I'm in Florida between Daytona and Orlando. You must be up by Fernandina Beach or Yulee?
Tav
Re: Need template for a luggage rack onto Chally decklid?! [Re: 71GoMango] #999581
05/26/11 10:01 PM
05/26/11 10:01 PM
cataclysm80 Offline
cataclysm80  Offline
before you drill, have a look at the bottom side of the trunk lid. I believe there are cutouts on the underside to access most of the holes. You can use this as a clue to see if you're in the right spot.
Tav
