Re: Need template for a luggage rack onto Chally decklid?!
[Re: cataclysm80]
#999572
05/26/11 01:39 PM
05/26/11 01:39 PM
1_WILD_RT
Management Trainee
Management Trainee
Today? Who Knows?
The rivnuts otherwise known as nutserts are the same "T" design but instead of 10-24 they are 1/4-20..
[Re: 71GoMango]
#999575
05/26/11 03:57 PM
05/26/11 03:57 PM
Posts: 4,323 St. Louis, Mo
318 Stroker
St. Louis, Mo
318 Stroker sent me this, just incase you want to add this to your file cataclysm, has a few more details on it.
Clay, Between Tav and I, I hope this gives you the info you need...
[Re: 71GoMango]
#999577
05/26/11 05:23 PM
05/26/11 05:23 PM
318 Stroker
St. Louis, Mo
Thanks, I should be good to go, looks like I should be centered and 4" from the front edge with those front two legs.
Check the diagram again carefully. You should be 4" from the back edge, with the back legs...
[Re: 318 Stroker]
#999578
05/26/11 05:29 PM
05/26/11 05:29 PM
Posts: 125 kalispell montana
jwilson 61
kalispell montana
should be from the front edge to front leg
70 cuda 440 6bbl Auto with a dana 60 68 road runner QQ1 383 auto 1970 6 barrel 4 speed Superbird FY1 number matching 15 Challenger 6.4 SRT pearl White 6 Speed 72 Cuda 440 5 speed 71 Road Runner 440 4 speed
[Re: jwilson 61]
#999579
05/26/11 05:53 PM
05/26/11 05:53 PM
318 Stroker
St. Louis, Mo
After reading the last two posts, I believe you guys are right. Everyone was looking at the diagram correctly, but I had my semantics wrong. As I'm standing at the back of the car, I was calling the edge where the decklid hinges as the back edge. But it's towards the front of the car, so yes, it is actually the front edge. Sorry guys...
[Re: 71GoMango]
#999580
05/26/11 09:57 PM
05/26/11 09:57 PM
Posts: 4,165 Florida
cataclysm80
Wow, Hey Thanks! That will be a nice addition to my collection. I've gotten some other really nice info from Allen (318 Stroker) in the past also. Hi Allen, Thanks to you to! I'm in Florida between Daytona and Orlando. You must be up by Fernandina Beach or Yulee? Tav
[Re: 71GoMango]
#999581
05/26/11 10:01 PM
05/26/11 10:01 PM
cataclysm80
before you drill, have a look at the bottom side of the trunk lid. I believe there are cutouts on the underside to access most of the holes. You can use this as a clue to see if you're in the right spot.
Tav
