PUMP GAS BIG BLOCKS- how fast you guys going??? #999497
05/25/11 03:49 AM
05/25/11 03:49 AM
junction city oregon
V
viperblue72 Offline OP
V
How fast are you guys going with pump gas big blocks? Let's hear them combos
Re: PUMP GAS BIG BLOCKS- how fast you guys going??? [Re: viperblue72] #999498
05/25/11 05:44 AM
05/25/11 05:44 AM
Finalnd, Perkele
jyrki Offline
jyrki  Offline
Finalnd, Perkele
7.89/181 mph. 3550 lbs, 4.10 gears and ET Streets. 477 cu in RB with Indy 440-1 heads, roller cam etc.
Oh, and a couple of small hair dryers help a little too..
http://www.youtube.com/watch?v=EK50vNlHjLo
Plynouth VIP '67 TT IC EFI
Re: PUMP GAS BIG BLOCKS- how fast you guys going??? [Re: jyrki] #999499
05/25/11 07:15 AM
05/25/11 07:15 AM
pa
572charger Offline
572charger  Offline
pa
606 cuin pump gas hemi 3910 lbs full exhaust street tires driven daily 9.60s at 142 a a little no2 8.90s at 154
606 hemi pump gas best 9.60 at 142mph on motor
05 hemi daytona 1500 go-mango 4wd quadcab
2007 hotrod mag pump gas drags runner up, roadkill nights dodge big tire winner 2018 2019 back to back
Re: PUMP GAS BIG BLOCKS- how fast you guys going??? [Re: 572charger] #999500
05/25/11 09:12 AM
05/25/11 09:12 AM
an8sec70cuda Offline
572" pump gas hemi. 3820# on drag radials, mufflers, etc. 9.54 at 140.4 mph, 1.32 sixty foot. All motor.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: PUMP GAS BIG BLOCKS- how fast you guys going??? [Re: viperblue72] #999501
05/25/11 10:09 AM
05/25/11 10:09 AM
Ortonville, MI
RoadRnnr69 Offline
Keyster
RoadRnnr69  Offline
Keyster
Ortonville, MI
10.96 with a 500" RB, street car that runs on 87 and up.
Re: PUMP GAS BIG BLOCKS- how fast you guys going??? [Re: viperblue72] #999502
05/25/11 10:24 AM
05/25/11 10:24 AM
NC
440Jim Offline
440Jim  Offline
NC
Best (mineshaft air) 9.16 at 143 mph.
3220 lbs back half, footbrake
511 CID
Indy 440-1 heads
279/284 flat tappet cam
13.5 CR (E-85 ethanol pump fuel)
You got to love E-85 ethanol. Cheaper than pump 87 octane.
Re: PUMP GAS BIG BLOCKS- how fast you guys going??? [Re: 440Jim] #999503
05/25/11 11:37 AM
05/25/11 11:37 AM
Taxes & Virus's R-US, NY
Dragula Offline
Dragula  Offline
We will soon find out with the 72 Duster that has unported EZ-heads, 512 cubes RB motor on pump gas at 2880lbs w/o driver and lots of tire to hook it. I suspect just under 10.40's when we get the carb nailed down, but you never know. Blew the dana 60 last week, so we almost found out....
I have a 484 pump gas hemi in the '70 Cuda, and its gone high 10's on a shut off pass in full street trim at 3280lbs w/o driver, and should be running right in the high 9's when I get it back togather...
Re: PUMP GAS BIG BLOCKS- how fast you guys going??? [Re: Dragula] #999504
05/25/11 01:10 PM
05/25/11 01:10 PM
organ
maximum entropy Offline
organ
boy, do i feel inadequate with this bunch! mine's a 496 "a" body, hydraulic flat tappet cam, 3.73 gears, 30" tall drag radials, revving 2650 at 65 mph. nice freeway cruiser. i drive it to our local high altitude high temperature track. it runs 7.00 at 98 and change. that equates to 10.60 over at woodburn (real air, reasonable temps).
Re: PUMP GAS BIG BLOCKS- how fast you guys going??? [Re: maximum entropy] #999505
05/25/11 01:25 PM
05/25/11 01:25 PM
10:34 at 128.6 MPH best so far with fuel delivery problems (10 micron filter between the pump and stock gas tank )3450 lb. Duster with a 518 pump gas low deck stroker with CNC ported Eddy RPM heads and a six pak, corked up with the air cleaner on using Oregon pump gas. It will go faster now as I have switched heads and intake, fixed the fuel delivery problem, 10.00 at 132 MPH hopefully
Re: PUMP GAS BIG BLOCKS- how fast you guys going??? [Re: Cab_Burge] #999506
05/25/11 01:59 PM
05/25/11 01:59 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
Not as impressive as some of the ones listed here but here goes. My 65 Belvedere had a pump gas 451 in it with Indy SR's and a solid cam. Weighed 3770lbs and was my daily driver. On a BFG 275/60 Drag Radial it went 10.50's. This was in 2001-2002. No bottle all motor.
Re: PUMP GAS BIG BLOCKS- how fast you guys going??? [Re: viperblue72] #999507
05/25/11 02:02 PM
05/25/11 02:02 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
what's considered pump gas? I'm thinking 93-94 octane youcan get at any gas station? Hoping to pull mid 11's. We'll see June 4th. 11.2:1 440-6 Ported Stage VI heads, 6-pack, 588 solid roller, meth injection, headers, 3800 Turbo action stall & manual valve body 3.91's driven to the track and home (if not broken).
Coming soon!!!!
Re: PUMP GAS BIG BLOCKS- how fast you guys going??? [Re: viperblue72] #999508
05/25/11 03:17 PM
05/25/11 03:17 PM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
451 low deck, 10.75:1, E heads, .630 roller, Victor, 1000 Demon, 2" headers with 3&1/2" exhaust, in '69 GTX rust bucket. Don't own a trailer so it's almost always driven to and from the track on 93 octane swill. 11.02 @ 123mph, will be looking for 10s this year, again, same as last year and the year before that...
Rich H.
Esse Quam Videri
Re: PUMP GAS BIG BLOCKS- how fast you guys going??? [Re: ZIPPY] #999509
05/25/11 03:53 PM
05/25/11 03:53 PM
robin hood country
deaks Offline
deaks  Offline
robin hood country
Why dont you drop the exhaust zippy.
My car is not pump, so nothing to add there.
Mick
69 Dart GTS 440 mopar .590 cam, Edelbrock heads, 3200#
best et 6.45, 106.78, 10.14, 132.88 mph, 1.47 60ft
best 60ft 1.36
Re: PUMP GAS BIG BLOCKS- how fast you guys going??? [Re: deaks] #999510
05/25/11 04:12 PM
05/25/11 04:12 PM
V
V
Some good running combos here. Wow!
Re: PUMP GAS BIG BLOCKS- how fast you guys going??? [Re: viperblue72] #999511
05/25/11 04:28 PM
05/25/11 04:28 PM
Greenville, South Carolina
BBLM23 Offline
BBLM23  Offline
10.18 @ 130mph 3300lbs with my 250lbs in it. ET Streets, 3" exhaust with X-pipe, Dynomax Super Turbos, 4.10 Dana.
Pump gas 493
Old post
Re: PUMP GAS BIG BLOCKS- how fast you guys going??? [Re: BBLM23] #999512
05/25/11 04:37 PM
05/25/11 04:37 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
Mine was 91 octane form the pump. Full exhaust and all. Drove it to the track ran it and drove it home, to the grocery store, parts store food whereever.
Re: PUMP GAS BIG BLOCKS- how fast you guys going??? [Re: Mr.Yuck] #999513
05/25/11 05:00 PM
05/25/11 05:00 PM
V
V
I consider pump gas what you can pull up and purchase at any gas station. Here in oregon its 91 octane. The E85 is pump gas too from what I gather LOL.
Re: PUMP GAS BIG BLOCKS- how fast you guys going??? [Re: Al_Alguire] #999514
05/25/11 05:06 PM
05/25/11 05:06 PM
Shelby Twp. Mi
HardcoreB Offline
HardcoreB  Offline
Shelby Twp. Mi
Dartin's car 10.24 @ 133 451B1/BS, MW port, 11.6:1CR, 308/.625"CompCam roller, Indy 400-3, Thru 3" mufflers @ 3360lbs Much tweaking yet to go.
Re: PUMP GAS BIG BLOCKS- how fast you guys going??? [Re: HardcoreB] #999515
05/25/11 05:27 PM
05/25/11 05:27 PM
bigfork mn
dragram440 Offline
dragram440  Offline
bigfork mn
92 oct. here in minnesota. The store down the road from the track has 110 that must count.
67' charger 499 RB 10.57 at 127
Re: PUMP GAS BIG BLOCKS- how fast you guys going??? [Re: dragram440] #999516
05/25/11 05:29 PM
05/25/11 05:29 PM
We have 93 octane here.
CHIP
