Page 2 of 3 1 2 3
Re: WOW!!! Is she HOT!!!!!!!!!!!!!!!!! OMG! [Re: OzHemi] #998828
05/24/11 09:15 AM
05/24/11 09:15 AM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
Lean...
Or timing ?
These 2 guys are right, it's the tune up, I'd bet a weeks pay on it.
You don't need to modifiy the cooling system, you need to run the right tuneup, I'm sure.
Re: WOW!!! Is she HOT!!!!!!!!!!!!!!!!! OMG! [Re: WyleECoyote] #998829
05/24/11 09:23 AM
05/24/11 09:23 AM
there is no hot honey to b seen . Over 350 hits and if you're not in advertizing you've missed your calling . Just imagine what you could do in the real world
Re: WOW!!! Is she HOT!!!!!!!!!!!!!!!!! OMG! [Re: Challenger 1] #998830
05/24/11 09:39 AM
05/24/11 09:39 AM
Tennessee
WyleECoyote Offline OP
Tennessee
I will check the timing - but I don't see why it would be different than when I drove the 1,000 mile trip to St. Louis. Stranger things happen - maybe the timing chain is stretching and changed the timing?? Regardless - I'll check it. Thank you.
Re: WOW!!! Is she HOT!!!!!!!!!!!!!!!!! OMG! [Re: WyleECoyote] #998831
05/24/11 09:50 AM
05/24/11 09:50 AM
Clintwood VA
johnedod Offline
johnedod  Offline
Clintwood VA
Take your digital thermometer and get another vehicle up to operating temp. and take readings at the same places you did on your car. Preferably at the same outside temp as on the day you checked your car. That way you'll have something to compare to. Is it puking any coolant?
Johnedod
68 Road Runner
71 Road Runner
78 Power Wagon
Re: WOW!!! Is she HOT!!!!!!!!!!!!!!!!! OMG! [Re: WyleECoyote] #998832
05/24/11 09:56 AM
05/24/11 09:56 AM
Cincinnati, Ohio
Cincinnati, Ohio
Just as long as you checked the other stuff the guys above suggested, then I'd be sure it's either lean or needs more intial timing, probably both.
Re: WOW!!! Is she HOT!!!!!!!!!!!!!!!!! OMG! [Re: Challenger 1] #998833
05/24/11 10:17 AM
05/24/11 10:17 AM
Houston, Tx
hemi68charger Offline
Houston, Tx
I had problems once with my '69 C500. Turned out to be the temperature sending unit. Along with the laser thermometer, I would try the old fashion boiling/cooking thermometer with the round dial that goes up to at least 400. take off the radiator cap and let her idle until the thermostat opens. Look at the thermometer and then your temp gauge. This could be one test. Also, if your connection on the bulkhead connector is bad/weak, it'll effect your readings. After all, the gauge is reading resistance from the sending unit and if you add more resistance, it could be reading wrong...
If you do get another sending unit, get a Mopar brand. I didn't have any luck with the junk offered over the counter at my local auto part stores.
Just a thought,,
Troy
Houston Mopar Connection Club
Re: WOW!!! Is she HOT!!!!!!!!!!!!!!!!! OMG! [Re: hemi68charger] #998834
05/24/11 11:23 AM
05/24/11 11:23 AM
Athens, Greece
Pyper70 Offline
Pyper70  Offline
Athens, Greece
Not to poke the beehive...you do have an overflow catch can right?
Family owned 1969 Charger R/T DualQuad 440/727/GVO/3.55s
Re: WOW!!! Is she HOT!!!!!!!!!!!!!!!!! OMG! [Re: WyleECoyote] #998835
05/24/11 01:48 PM
05/24/11 01:48 PM
Is the new radiator aluminum? If so i had a simialr experience with a new aluminum radiator 4 yrs ago, it cooled fine when I first put it in. It ran 165F going down thw road at 50+ MPH or higher and 160 F degreesas soon as I let off the throttle and slowed down to 35 MPH or slower. The next spring it ran 190+ all the time I had filled it with distilled water and Water Wetter and then added antifreeze later for the winter storage   I had it reversed flush this past winter and it is now running 165 F again I did buy and install a sacrifisal anode that screws into where the drain plug goes, maybe that will help Let us know what you find
Re: WOW!!! Is she HOT!!!!!!!!!!!!!!!!! OMG! [Re: WyleECoyote] #998836
05/24/11 01:53 PM
05/24/11 01:53 PM
Sunny South Florida
Golden-Arm Offline
Golden-Arm  Offline
Sunny South Florida
(another new one or the current one that works) WILL have 3 holes in it! What size holes? 1/8th inch?
i drill a single 1/8" hole in mine, just to make sure they dont hold an air bubble. remove the stat and crank it up and let it run for a while. watch the temp, and monitor water flow. if it still gets hot with the stat removed, you have a questionable radiator, or blockage in the block, providing you see decent water flow. if the flow is poor, i'd suspect the pump. be sure the hoses aren't collapsing. the bottom one is the one to look at closely. use redline water wetter too. it does help.
Re: WOW!!! Is she HOT!!!!!!!!!!!!!!!!! OMG! [Re: Golden-Arm] #998837
05/24/11 05:11 PM
05/24/11 05:11 PM
P
Paul_Fancsali Offline
P
Keep at 180 stat. Drop your antifreeze level concentrate to 30 % and quit worrying the engine is not over heated at 228 Hot yes boiling No Also last time I had one do what yours is doing the head gasket was blown between cylinders but you said you did check with pressure tester Also get a 18 lb cap it will help a little
Re: WOW!!! Is she HOT!!!!!!!!!!!!!!!!! OMG! [Re: Paul_Fancsali] #998838
05/24/11 06:10 PM
05/24/11 06:10 PM
Tennessee
Tennessee
Thanks Paul. I didn't get to play with it today so hopefully tomorrow! I appreciate your input.
Wile E. Coyote
Super Genius, Lover of FCA US LLC Products
68 Road Runner (440 4-spd), 71 Superbee (383 slap), 71 Charger 500 (383 4-spd wA/C 1of 182), 72 Imperial, 74 Charger SE (440 sunroof), 84 D350 Crew-cab Dually (440), 75 D300 Dually Tandem (318 4-speed)
Re: WOW!!! Is she HOT!!!!!!!!!!!!!!!!! OMG! [Re: WyleECoyote] #998839
05/24/11 08:28 PM
05/24/11 08:28 PM
Post some racy pic(s) and pull that stat
Re: WOW!!! Is she HOT!!!!!!!!!!!!!!!!! OMG! [Re: hemi68charger] #998840
05/25/11 12:30 AM
05/25/11 12:30 AM
Texas
jetdoctor_75402 Offline
super gas
super gas
Texas
Have a 72 Dart 5.2 52,230 miles and it started overheating and what I found was a previous owner had put stop leak in engine. It built up in the corner of the back driver side cooling water jacket in the block. Found this when I removed the heads to replace head gaskets (they were not bad, just covering bases). The stop leak was intended to stop a leak at rear water soft plug in rear of block. Don't know your history on your car, but might be a possibility?
regrds
doc
UPDATE: Re: WOW!!! Is she HOT!!!!!!!!!!!!!!!!! OMG! [Re: Challenger 1] #998841
07/25/11 07:33 PM
07/25/11 07:33 PM
Tennessee
Tennessee
Lean...
Or timing ?
Challenger 1 - Will you be sending that weeks pay via Paypal or check???...
Well, regardless that the radiator was new, and no matter that we flushed the cooling system - apparently the 1,000 mile trip to MMW in St.Louis knocked enough rust and debris loose in the engine/cooling system that the radiator was plugged up. After trying EVERYTHING else, I took the radiator back to the shop and told them my problem and they said they would flow check it. Yep, sure enough - they said even though it was cooling, the flow was terrible. A $21 radiator flush and I'm back in business!
WHAT a lesson learned!
Thanks for ALL the help and ideas you guys gave me (and all of us here on Moparts), I think this will be a valuable thread!
Wile E. Coyote
Re: UPDATE: Re: WOW!!! Is she HOT!!!!!!!!!!!!!!!!! OMG! [Re: WyleECoyote] #998842
07/25/11 07:45 PM
07/25/11 07:45 PM
Wow, I wish I had seen this sooner as I don't believe your problem is fixed long term!
Both my father and I had problems with '71 vintage motors overheating. Replaced hoses, thermostats, had the radiators cleaned and everything would be fine....for a while...
I turns out that on both motors (his a 383, mine a 318) they had lots of casting sand that was left in the block! Both motors were original and had never been out of the car when we bought them. After we pulled the motors and THOROUGHLY cleaned out the pan rails/water passages the problem went away.
Re: UPDATE: Re: WOW!!! Is she HOT!!!!!!!!!!!!!!!!! OMG! [Re: WyleECoyote] #998843
07/25/11 08:53 PM
07/25/11 08:53 PM
Cincinnati, Ohio
Cincinnati, Ohio
Lean...
Or timing ?
I guess the check is in the mail.
Re: WOW!!! Is she HOT!!!!!!!!!!!!!!!!! OMG! [Re: Cab_Burge] #998844
07/25/11 09:41 PM
07/25/11 09:41 PM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
I wonder if the Water Wetter alone didn't give it enough corrosion protection. Especially for the surface area of a fresh new radiator. The aluminum needs some added silicates and nitrates for protection.
When you have a new radiator or new heater core, those protective ingredients can get quickly depleted even out of 50/50 coolant to cover that new area. Then you are not left with much protection to carry you over to the next coolant exchange interval.
I know Justice Brothers recommends it's Super Radiator Cooler (pn 22/P) AND an additional Radiator Protectant bottle (pn 1/P) for water only situations.
Re: WOW!!! Is she HOT!!!!!!!!!!!!!!!!! OMG! [Re: autoxcuda] #998845
07/26/11 03:26 AM
07/26/11 03:26 AM
Land 'O Lakes
RoadRunnerLuva Offline
Land 'O Lakes
This thread should end up in the Tech archives
Plymouth Makes It!
Re: WOW!!! Is she HOT!!!!!!!!!!!!!!!!! OMG! [Re: RoadRunnerLuva] #998846
07/26/11 03:39 AM
07/26/11 03:39 AM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
Pretty common problem... Debris in the cooling system doesn't get properly cleaned out by EPA compliant hot tank.. It just gets loosened so when the engine is assembled & running in the car
after a few heat cycles the debris starts breaking up & plugs the radiator... A good solution is to run a coolant filter for the first couple thousand miles...
http://autocoolantfilter.com/
Re: WOW!!! Is she HOT!!!!!!!!!!!!!!!!! OMG! [Re: 1_WILD_RT] #998847
07/26/11 03:49 AM
07/26/11 03:49 AM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
In a new motor, I agree.
I spend hours MYSELF just picking the loose scale out of my block and air blowing the living heck out of it! And it was real clean to start with. Then after I got it back from the machine shop I put a pressure washer and hose through everything.
My new motor stays cool and I have a tiny mechanical fan with no shroud yet. I did do a drain and fill soon after I got the motor running. But if it idles or in real slow traffic for quite some time it will get hot (not boil over though). I need to add a shroud AND do a good backflush.
I thought I did a decent job of getting the junk out of there
Page 2 of 3 1 2 3
