Re: 354 HEMI off the dyno
[Re: goldmember]
#996715
05/23/11 03:55 PM
05/23/11 03:55 PM
Posts: 449 Wisconsin
sjs64polara
Wisconsin
Guess you need to put it in a car and post the results.
It’s going in a 29 Chrysler coupe street rod………… its just going to be a tire smoker ![](/ubbthreads/images/graemlins/devil.gif)
If you guys don’t believe the numbers then call Hod Heads and ask them how much they make with these types of combos. (336) 352-4866 ![](/ubbthreads/images/graemlins/shruggy.gif)
[Re: sjs64polara]
#996716
05/23/11 04:01 PM
05/23/11 04:01 PM
Posts: 8,547 State College, PA
RyanJ
moparts member
moparts member
State College, PA
I’m perplexed about the comments. They build 355 Chevy circle track motors with 700+hp frequently. Those motors are only 9.5:1…………. And NVR isn’t to only guy in town doing it. Circle track racers jump around to different builders all the time. No one ever talks about dynos being hot, fat, off, whatever the lingo is. You guys are funny
630 FT LBS of TQ... 1.78/INCH
The best N/A motor I have ever dynoed was 1.52/INCH That was 16.5:1, CNC heads flowing 390 cfm, Sheetmetal tunnel ram on Oxygenated race gas.
Most motors we dyno with heads flowing similar to yours, cam specs & compression also in parameters of yours make in the neighborhood of 1.20-1.25 FT LBS/INCH
You may not want to hear it, but it's just the truth.
That dyno is currently reading about 30% high. He needs to re-check his calibration & the strain gauge. It's a new SF902, it is a nice piece & motor looks to be well built from the pics, the power #'s are simply inaccurate, it's basically impossible to make those kind of #'s TQ wise N/A with that type of combo.
Don't worry about the HP #'s as others have said those are just being calculated of of the TQ that the strain gauge is reading & for whatever reason it is reading incorrectly or he has a correction factor error in the computer programming. Just focus on the TQ #'s being so far out of wack. ![](/ubbthreads/images/graemlins/Twocents.gif)
[Re: HotRodDave]
#996717
05/23/11 04:04 PM
05/23/11 04:04 PM
Posts: 4,330 Lynchburg, VA
Leon441
Lynchburg, VA
You may want to read the engine masters challenge article to better understand their numbers. If I am not mistaken each pull is an average HP and average torque over a range of RPM. They made three pulls with an average for each pull then averaged those numbers.
Long story short the numbers in engine masters challenge score card are not peak HP.
Leon
[Re: Leon441]
#996718
05/23/11 04:17 PM
05/23/11 04:17 PM
Posts: 660 San Diego
formula S
San Diego
Long story short the numbers in engine masters challenge score card are not peak HP.Leon
Peek hp I was told by hot heads was 613hp at 6500 and the heads flowed 367 cfm ported
[Re: RyanJ]
#996719
05/23/11 04:25 PM
05/23/11 04:25 PM
Posts: 3,060 Western New York
sixpackbee
Western New York
I would question the funky torque curve. I wonder if they had enough resistance in the brake when they pulled it.
1959 Bugeye Sprite 1967 Charger Black L code 1967 Coronet R/T Convert Green 440 auto bought from original owner 1968 Charger R/T Bronze 440 4 spd console AM/FM 1969 Super Bee WM21H B5 A40 D21 N96 1969 Barracuda Formula S 340 Convert pilot car 1969 Hemi Road Runner RM23J D32 Omaha orange 4.10 Dana N96 N85 1970 Super Bee WM23N FE5 V1X 3.91 axle package, N96 1970 Road Runner RM21N B3 V1X D13 1971 MG Midget 1971 Road Runner RM23H GW3, A57 1972 Road Runner RM23P FY1, D21
[Re: sjs64polara]
#996720
05/23/11 04:52 PM
05/23/11 04:52 PM
Quicktree
yea but they are spinning them 9k
[Re: HotRodDave]
#996721
05/23/11 04:56 PM
05/23/11 04:56 PM
Posts: 16,123 Grand Haven, MI
patrick
Grand Haven, MI
to echo Ryan and Dave, the high torque numbers are the first thing that didn't pass the smell test. the highest torque/CID pump gas motors I can recall seeing results of are ~1.4lbs/CID. that would put a 360 cube motor at 500 ft-lbs. most of those are usually high compression, pretty decently sized cam motors, stuff that's on the edge of pump gas capability.....
if the torque numbers are off, then the HP numbers (derived from torque) are off....
as far as 700HP roundy round motors, my bet is their HP peak ~8k RPM, or higher, which would require ~460 lb-ft at that RPM, which means a biiiig cam, probably in the 270-280@.050 range....they're probably also running methanol and extreme compression ratios.
heck, top nascar engines (what I'd call bleeding edge technology for pushrod motors) are making 750-850hp from 358 cubes, but at ~10,000 RPM...which again, requires about 450 lb-ft at that RPM....
if I had to swagger, based on the combo, I bet a more realistic number is going to be 400-460hp, 420-450lb-ft of torque, with HP peak in the 5800 RPM range.....
[Re: fishy340]
#996723
05/23/11 05:30 PM
05/23/11 05:30 PM
sjs64polara
Wisconsin
The hp numbers don’t mean anything to us. I’ve said that several times. We’re not dyno racers. I thing I DIDN’T say was flow numbers, ![](/ubbthreads/images/graemlins/shruggy.gif) I don’t know where that comment came from. I never mentioned what was done to the heads either. ![](/ubbthreads/images/graemlins/shruggy.gif) What ever the case is……. I still find you guys funny. What’s the next heated discussion going to be ![](/ubbthreads/images/graemlins/popcrn.gif)
[Re: sjs64polara]
#996725
05/23/11 05:57 PM
05/23/11 05:57 PM
Quicktree
I thing I DIDN’T say was flow numbers, I don’t know where that comment came from. I never mentioned what was done to the heads either. ![](/ubbthreads/images/graemlins/shruggy.gif)
you know that is one sweet looking motor, I don't care if it makes 100hp ![](/ubbthreads/images/graemlins/thumbs.gif)
[Re: goldmember]
#996728
05/23/11 06:20 PM
05/23/11 06:20 PM
sjs64polara
Wisconsin
"The hp numbers don’t mean anything to us." Then why post them? Everyone has been nice to you,even if the "dyno numbers" (that you posted) were far from realistic with the info you provided.
I would have posted the numbers if they were 300hp. I’m happy for my old man It’s the first Hemi since him and Ron Ritter purchased Chris Karamesines “Chizler” in the early / mid sixties.
[Re: galen]
#996731
05/23/11 09:21 PM
05/23/11 09:21 PM
Posts: 2,129 Vermont
TrWaters
Vermont
Very nice, I like it. Who built the headers,if you don't mind me asking.
Those appear to be HotHeads headers, as well as their heads, intake, valley cover, front cover, pulleys,water crossover, etc. And the Stef's pan.
TR Waters
[Re: TrWaters]
#996732
05/23/11 09:37 PM
05/23/11 09:37 PM
Posts: 20,677 in a cattle trailer down by th...
Guitar Jones
I've heard the early Hemi heads don't need a lot of lift to flow good numbers. I've only heard that though, no personal experience. However who cares what it makes, it's got the major cool factor going on and in a 29 Chrysler it should be sweet. Have fun and tell the old man I envy him.
[Re: TrWaters]
#996733
05/23/11 09:53 PM
05/23/11 09:53 PM
sjs64polara
Wisconsin
Those appear to be HotHeads headers, as well as their heads, intake, valley cover, front cover, pulleys,water crossover, etc. And the Steff's pan.
I think they are Hot Heads headers, non sure. You nailed the rest of it ![](/ubbthreads/images/graemlins/thumbs.gif)
[Re: Guitar Jones]
#996734
05/23/11 10:01 PM
05/23/11 10:01 PM
sjs64polara
Wisconsin
Thank you ![](/ubbthreads/images/graemlins/thumbs.gif) Be careful what you say otherwise you may get in a wrestling match ![](/ubbthreads/images/graemlins/eeek.gif)
