Page 5 of 6 1 2 3 4 5 6
Re: 354 HEMI off the dyno [Re: goldmember] #996715
05/23/11 03:55 PM
05/23/11 03:55 PM
Wisconsin
sjs64polara Offline OP
Wisconsin
Guess you need to put it in a car and post the results.
It’s going in a 29 Chrysler coupe street rod………… its just going to be a tire smoker
If you guys don’t believe the numbers then call Hod Heads and ask them how much they make with these types of combos. (336) 352-4866
Re: 354 HEMI off the dyno [Re: sjs64polara] #996716
05/23/11 04:01 PM
05/23/11 04:01 PM
State College, PA
RyanJ Offline
moparts member
RyanJ  Offline
moparts member
State College, PA
I’m perplexed about the comments. They build 355 Chevy circle track motors with 700+hp frequently. Those motors are only 9.5:1…………. And NVR isn’t to only guy in town doing it. Circle track racers jump around to different builders all the time. No one ever talks about dynos being hot, fat, off, whatever the lingo is.
You guys are funny
630 FT LBS of TQ... 1.78/INCH
The best N/A motor I have ever dynoed was 1.52/INCH That was 16.5:1, CNC heads flowing 390 cfm, Sheetmetal tunnel ram on Oxygenated race gas.
Most motors we dyno with heads flowing similar to yours, cam specs & compression also in parameters of yours make in the neighborhood of 1.20-1.25 FT LBS/INCH
You may not want to hear it, but it's just the truth.
That dyno is currently reading about 30% high. He needs to re-check his calibration & the strain gauge. It's a new SF902, it is a nice piece & motor looks to be well built from the pics, the power #'s are simply inaccurate, it's basically impossible to make those kind of #'s TQ wise N/A with that type of combo.
Don't worry about the HP #'s as others have said those are just being calculated of of the TQ that the strain gauge is reading & for whatever reason it is reading incorrectly or he has a correction factor error in the computer programming. Just focus on the TQ #'s being so far out of wack.
Re: 354 HEMI off the dyno [Re: HotRodDave] #996717
05/23/11 04:04 PM
05/23/11 04:04 PM
Lynchburg, VA
Leon441 Offline
Leon441  Offline
Lynchburg, VA
You may want to read the engine masters challenge article to better understand their numbers. If I am not mistaken each pull is an average HP and average torque over a range of RPM. They made three pulls with an average for each pull then averaged those numbers.
Long story short the numbers in engine masters challenge score card are not peak HP.
Leon
Re: 354 HEMI off the dyno [Re: Leon441] #996718
05/23/11 04:17 PM
05/23/11 04:17 PM
San Diego
formula S Offline
formula S  Offline
San Diego
Long story short the numbers in engine masters challenge score card are not peak HP.Leon
Peek hp I was told by hot heads was 613hp at 6500 and the heads flowed 367 cfm ported
Re: 354 HEMI off the dyno [Re: RyanJ] #996719
05/23/11 04:25 PM
05/23/11 04:25 PM
Western New York
sixpackbee Offline
sixpackbee  Offline
Western New York
I would question the funky torque curve. I wonder if they had enough resistance in the brake when they pulled it.
1959 Bugeye Sprite
1967 Charger Black L code
1967 Coronet R/T Convert Green 440 auto bought from original owner
1968 Charger R/T Bronze 440 4 spd console AM/FM
1969 Super Bee WM21H B5 A40 D21 N96
1969 Barracuda Formula S 340 Convert pilot car
1969 Hemi Road Runner RM23J D32 Omaha orange 4.10 Dana N96 N85
1970 Super Bee WM23N FE5 V1X 3.91 axle package, N96
1970 Road Runner RM21N B3 V1X D13
1971 MG Midget
1971 Road Runner RM23H GW3, A57
1972 Road Runner RM23P FY1, D21
Re: 354 HEMI off the dyno [Re: sjs64polara] #996720
05/23/11 04:52 PM
05/23/11 04:52 PM
Q
Quicktree Offline
Quicktree  Offline
Q
You guys are funny
yea but they are spinning them 9k
Re: 354 HEMI off the dyno [Re: HotRodDave] #996721
05/23/11 04:56 PM
05/23/11 04:56 PM
Grand Haven, MI
patrick Offline
patrick  Offline
Grand Haven, MI
to echo Ryan and Dave, the high torque numbers are the first thing that didn't pass the smell test. the highest torque/CID pump gas motors I can recall seeing results of are ~1.4lbs/CID. that would put a 360 cube motor at 500 ft-lbs. most of those are usually high compression, pretty decently sized cam motors, stuff that's on the edge of pump gas capability.....
if the torque numbers are off, then the HP numbers (derived from torque) are off....
as far as 700HP roundy round motors, my bet is their HP peak ~8k RPM, or higher, which would require ~460 lb-ft at that RPM, which means a biiiig cam, probably in the 270-280@.050 range....they're probably also running methanol and extreme compression ratios.
heck, top nascar engines (what I'd call bleeding edge technology for pushrod motors) are making 750-850hp from 358 cubes, but at ~10,000 RPM...which again, requires about 450 lb-ft at that RPM....
if I had to swagger, based on the combo, I bet a more realistic number is going to be 400-460hp, 420-450lb-ft of torque, with HP peak in the 5800 RPM range.....
2017 Grand Cherokee Overland
Re: 354 HEMI off the dyno [Re: patrick] #996722
05/23/11 05:04 PM
05/23/11 05:04 PM
LONG ISLAND
fishy340 Offline
fishy340  Offline
LONG ISLAND
440ci sb here with indy 360-1's 620lb tq in mine sounds a little more in line
Re: 354 HEMI off the dyno [Re: fishy340] #996723
05/23/11 05:30 PM
05/23/11 05:30 PM
Wisconsin
Wisconsin
The hp numbers don’t mean anything to us. I’ve said that several times. We’re not dyno racers.
I thing I DIDN’T say was flow numbers, I don’t know where that comment came from.
I never mentioned what was done to the heads either.
What ever the case is……. I still find you guys funny. What’s the next heated discussion going to be
Re: 354 HEMI off the dyno [Re: sjs64polara] #996724
05/23/11 05:47 PM
05/23/11 05:47 PM
Gainesville,FL
goldmember Offline
goldmember  Offline
Gainesville,FL
"The hp numbers don’t mean anything to us." Then why post them? Everyone has been nice to you,even if the "dyno numbers" (that you posted) were far from realistic with the info you provided.
Re: 354 HEMI off the dyno [Re: sjs64polara] #996725
05/23/11 05:57 PM
05/23/11 05:57 PM
Q
Quicktree Offline
Quicktree  Offline
Q
you know that is one sweet looking motor, I don't care if it makes 100hp
Re: 354 HEMI off the dyno [Re: HotRodDave] #996726
05/23/11 06:19 PM
05/23/11 06:19 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Yeah that challenge thing is interesting, bigger motor less HP and TQ
I am also wondering why they quit pulling at 5000 when TQ and HP where still climing?
Thats what threw me off... I thought it was maxed
out on the original numbers... so the HP/TQ could
very well be in line... didnt realize they quit at
5000 rpm... like you said... even the TQ was still
climbing
EDIT
for the calibration it is being run on
Re: 354 HEMI off the dyno [Re: Quicktree] #996727
05/23/11 06:19 PM
05/23/11 06:19 PM
junction city oregon
V
viperblue72 Offline
viperblue72  Offline
V
Your dyno #s are absolutely believable and are completely realistic for this motor. IF IT WERE SUPERCHARGED.
Maybe you should go play on the websites where the ricers play. They would believe you.
On a different note still a VERY VERY cool motor indeed.
Re: 354 HEMI off the dyno [Re: goldmember] #996728
05/23/11 06:20 PM
05/23/11 06:20 PM
Wisconsin
Wisconsin
I would have posted the numbers if they were 300hp. I’m happy for my old man It’s the first Hemi since him and Ron Ritter purchased Chris Karamesines “Chizler” in the early / mid sixties.
Re: 354 HEMI off the dyno [Re: sjs64polara] #996729
05/23/11 07:03 PM
05/23/11 07:03 PM
Texas
dannysbee Offline
dannysbee  Offline
Texas
The cool factor is there no doubt. He should be very proud. But the numbers don't add up. Was it the same dyno that the engine in the 64 Polara was on? It seemed to be a little off with 550 HP and 12.44 et's. At 4000 lbs the HP would figure closer to 450. What was the MPH on the Polara?
Getting old just means you were smarter than some and luckier than others.
Re: 354 HEMI off the dyno [Re: goldmember] #996730
05/23/11 07:35 PM
05/23/11 07:35 PM
Oconomowoc, WI.
Cudahlr Offline
Cudahlr  Offline
Oconomowoc, WI.
Hmmmm. Spence would that thing fit in my car?
Very cool engine! Im happy for the old fart too!
1968 Barracuda 360/727 11.20 @ 121 mph 421 rwhp
1985 Harley Sportster Bobber
2006 Ram 2500 sport - The Cudahlr
Re: 354 HEMI off the dyno [Re: galen] #996731
05/23/11 09:21 PM
05/23/11 09:21 PM
Vermont
TrWaters Offline
TrWaters  Offline
Vermont
Very nice, I like it. Who built the headers,if you don't mind me asking.
Those appear to be HotHeads headers, as well as their heads, intake, valley cover, front cover, pulleys,water crossover, etc. And the Stef's pan.
TR Waters
Re: 354 HEMI off the dyno [Re: TrWaters] #996732
05/23/11 09:37 PM
05/23/11 09:37 PM
Guitar Jones Offline
I've heard the early Hemi heads don't need a lot of lift to flow good numbers. I've only heard that though, no personal experience. However who cares what it makes, it's got the major cool factor going on and in a 29 Chrysler it should be sweet. Have fun and tell the old man I envy him.
Re: 354 HEMI off the dyno [Re: TrWaters] #996733
05/23/11 09:53 PM
05/23/11 09:53 PM
Wisconsin
Wisconsin
Those appear to be HotHeads headers, as well as their heads, intake, valley cover, front cover, pulleys,water crossover, etc. And the Steff's pan.
I think they are Hot Heads headers, non sure. You nailed the rest of it
Re: 354 HEMI off the dyno [Re: Guitar Jones] #996734
05/23/11 10:01 PM
05/23/11 10:01 PM
Wisconsin
Wisconsin
Thank you
Be careful what you say otherwise you may get in a wrestling match
