Paint removal on plastic bezels #996609
05/21/11 01:48 PM
05/21/11 01:48 PM
Santa Barbara, CA
HitIt Offline OP
HitIt  Offline OP
Santa Barbara, CA
Hello-
I'm looking to see if there is a good way to strip paint off a plastic gauge cluster bezel. Is there a chemical stripper that is safe for plastic?
This 62 Plymouth bezel has some intricate & delicate patterns in it that make removal by scotch brite not possible. It's been painted a few times and the detail is starting to get lost.
Thanks!!
very clever dinner. appetizing food fit neatly into interesting round pie.
Re: Paint removal on plastic bezels [Re: HitIt] #996610
05/21/11 08:44 PM
05/21/11 08:44 PM
Ontario, Canada
Stanton Online content
Don't question me!
Stanton  Online Content
Don't question me!
Ontario, Canada
Test EZ-off oven cleaner on a small area on the back to make sure it doesn't harm the plastic. If not then give it a go. However, if it gets anywhere near "chromed" plastic, that will be ruined.
Re: Paint removal on plastic bezels [Re: HitIt] #996611
05/21/11 10:27 PM
05/21/11 10:27 PM
cataclysm80 Offline
cataclysm80  Offline
Brake fluid or lacquer thinner?
Tav
Re: Paint removal on plastic bezels [Re: cataclysm80] #996612
05/21/11 10:56 PM
05/21/11 10:56 PM
On my '63 Dodge I used Easy Off on the cluster (after I took the clear lenses off) and worked it into the tight areas with a toothbrush.
Worked awesome!
Re: Paint removal on plastic bezels #996613
05/22/11 01:00 PM
05/22/11 01:00 PM
Santa Barbara, CA
HitIt Offline OP
HitIt  Offline OP
Santa Barbara, CA
Thanks for the info.
How long did you let the easy off sit? Did it remove the chrome plating? Is there a certain variety of the cleaner that works best, I think there are a few like non-amonia etc.
I've got an extra peice to test on too.
Re: Paint removal on plastic bezels [Re: HitIt] #996614
05/22/11 06:00 PM
05/22/11 06:00 PM
Use the heavy duty, not the fume free.
Yes, the chrome plating will come off!
If there isn't much of it, you can always use Bare Metal Foil to replicate it if you're on a budget.
I don't recall how long it took but the hotter it is outside, the better!
