Will anyone be running an E-Curve dist at Mo Power? #992809
05/15/11 01:46 PM
05/15/11 01:46 PM
Beavercreek, Ohio
OA5599 Offline OP
OA5599  Offline OP
Beavercreek, Ohio
First time to the track with the stroker motor this Friday. Haven't had much time to mess with the E-Curve distributor. Will anyone there be who has experience with one?
Re: Will anyone be running an E-Curve dist at Mo Power? [Re: OA5599] #992810
05/15/11 05:49 PM
05/15/11 05:49 PM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
Please report how it works.
I have got TWO of them so far and the timing at idle bounces around 10 degrees. I returned one and the replacement does the same thing. I immediately put a new MP unit and orange box and works fine both times.
I have a feeling mine is getting some EMF interference from something. I talked with a builder that had one on the dyno that wouldn't let the electronic fuel injection work. Had to be some EMF cross talk stuff going on.
Re: Will anyone be running an E-Curve dist at Mo Power? [Re: autoxcuda] #992811
05/15/11 06:49 PM
05/15/11 06:49 PM
Lehigh Acres, Florida
rickstershemi Offline
Also interested have one on the 408 that we haven't fired up yet
Rickster
