Critique my corner weights #991713
05/13/11 03:02 PM
05/13/11 03:02 PM
Longview, Texas
marvo451 Offline OP
marvo451  Offline OP
Longview, Texas
Just got off the scales at a friends shop, tell me how this looks to you.
LF 865 RF 805
LR 788 RR 792
Total weight for my big block Duster including my 185# is 3250. Weights are with me in the car in the race ready mode.
Do you think I'm close to correct. My last pass last fall went WAY crooked and ended up with a smashed oil pan....what a drag!?
Re: Critique my corner weights [Re: marvo451] #991714
05/13/11 03:26 PM
05/13/11 03:26 PM
SOUTH JERSEY
HEMIFRED Offline
HEMIFRED  Offline
SOUTH JERSEY
as close as you need to start off.
what type rear suspension ?
home of the
Sox and Martin Hemi Duster
Re: Critique my corner weights [Re: marvo451] #991715
05/13/11 03:32 PM
05/13/11 03:32 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Looks real close... you MIGHT need a touch more on
the RR but that will be found out on the launch...
have someone video your launches
Re: Critique my corner weights [Re: marvo451] #991716
05/13/11 03:37 PM
05/13/11 03:37 PM
Your weights look typical for a BB A body car, maybe a little better than most on the right rear weight I have been told by several factory back Mopar SS racers years ago that you need 30 lbs more on the right rear than the left rear for best perforamnce on a drag car Your car going crooked is not from the weight distribution in my opinion Look at the tire circumferences on the rear tires, shoot for 1/4 inch or less in circumference differences If they are close then look at the rear end alignment to the chassis and or bent rear shocks or binding in the suspension in both the front or rear. My Duster use to go straigt as a arrow until I readjusted the ride hieght and the coil spring preload to get some more weight on the RR, it went left until I readjusted both springs to the same hieght with the weight on them that was with the 8 3/4 in the car, it now has a Dana 60 in it Take your time and see what you find BTW, my car ended up bending and tweaking the 8 3/4 rear end housing bad enough to need replacing, it now has a cut down Dana 60 truck rear end in it, ladder bars and coil overs rear suspension with a diagonal link IHTHs
Re: Critique my corner weights [Re: Cab_Burge] #991717
05/13/11 03:49 PM
05/13/11 03:49 PM
Mt. Vernon, Ohio
dartman366 Offline
dartman366  Offline
Mt. Vernon, Ohio
I agree with Cab on the 30# on the RR, thats exactly what mine took to make it leave straight, you look close so I would try a couple of hit's and see what happens and adjust from there, just watch a few cars first and try and determine if the track is hooking straight, some times that will throw things off, also try both lanes.
Re: Critique my corner weights [Re: Cab_Burge] #991718
05/13/11 03:50 PM
05/13/11 03:50 PM
Longview, Texas
marvo451 Offline OP
marvo451  Offline OP
Longview, Texas
Ladder bar, coil over double adjustable Strange shocks. Stock type front suspension with single adjustable Stranges.
Re: Critique my corner weights [Re: marvo451] #991719
05/13/11 04:04 PM
05/13/11 04:04 PM
Eighty Four, PA
B G Racing Offline
B G Racing  Offline
Eighty Four, PA
Start with 30/40 pounds more on the RR than on the LR. Which way was the car hooking(driving)?
Re: Critique my corner weights [Re: B G Racing] #991720
05/13/11 04:14 PM
05/13/11 04:14 PM
Longview, Texas
marvo451 Offline OP
marvo451  Offline OP
Longview, Texas
Ususlly goes straight, but went seriously right while in the air, then came down HARD. That is why I scaled it trying to find out if something was seriously out of whack or bent. Car has 5 flats of preload on the Right ladder bar. Also, the car has 2 deep cycle marine batteries on the Right rear in the trunk.
Re: Critique my corner weights [Re: marvo451] #991721
05/13/11 07:23 PM
05/13/11 07:23 PM
Was this a one time deal or did it always go right when the front tires where in the air? If always look for the problem , if only once maybe there was some slippery or wet stuff on the track My car has no prelaod on the ladder bars, a little more tension on the left torsion bar and equal lengths now on the rear springs and cup adjustments I do run a spool and I make sure that the rear tires are within 1/8 inch of each other on the circumference  , I have two deep cyles mounted like yours on the right side also Ain't racing fun
Re: Critique my corner weights [Re: marvo451] #991722
05/13/11 07:56 PM
05/13/11 07:56 PM
ky
68roadrunner Offline
ky
you should look for a problem, there should be no way you need 5 flats. tighten up the left front to transfer weight on the right rear.
Re: Critique my corner weights [Re: 68roadrunner] #991723
05/13/11 08:33 PM
05/13/11 08:33 PM
Longview, Texas
marvo451 Offline OP
marvo451  Offline OP
Longview, Texas
Yep.........5 flats is what it took to make it go straight.
Re: Critique my corner weights [Re: marvo451] #991724
05/13/11 08:51 PM
05/13/11 08:51 PM
MR_P_BODY Offline
MR_P_BODY  Offline
When you scaled the car were you at 0 pre-load to
get the measurements
Re: Critique my corner weights [Re: MR_P_BODY] #991725
05/13/11 09:56 PM
05/13/11 09:56 PM
Longview, Texas
marvo451 Offline OP
marvo451  Offline OP
Longview, Texas
No, 5 flats is what is is raced at...........race ready status
http://www.youtube.com/watch?v=Ai5EnELtPWI
This link shows the 2 passes I made in time trials last November. First pass is a little over 1 minute in and the "pan wrecker" is a little over 3 minutes in.
Re: Critique my corner weights [Re: marvo451] #991726
05/13/11 10:04 PM
05/13/11 10:04 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Normally you scale a car with 0 pre-load then add
in 20# or so then hit the track to see what it does
then add or subtract to correct... but the weights
looked close...if you add alot of pre-load it can
up-set the car on decell on the top end when you nose over
Re: Critique my corner weights.....UPDATE [Re: MR_P_BODY] #991727
05/15/11 08:13 AM
05/15/11 08:13 AM
Longview, Texas
marvo451 Offline OP
marvo451  Offline OP
Longview, Texas
Took the car to Mopars at the Motorplex at Ennis. Car went straight as a string. 60 ft. 1.37, only problem was trying to calm the car down as it was carrying the fronts to right at the 60 ft beams.
Re: Critique my corner weights.....UPDATE [Re: marvo451] #991728
05/16/11 12:02 PM
05/16/11 12:02 PM
Longview, Texas
marvo451 Offline OP
marvo451  Offline OP
Longview, Texas
Check out this picture from the Motorplex....
Re: Critique my corner weights.....UPDATE [Re: marvo451] #991729
05/16/11 01:38 PM
05/16/11 01:38 PM
I like to see 1 to 3 inches of air under both front tires, anymore is wasted energy hiking them higher I would try stiffer shock settings to start with and then maybe the front ladder bar location, what hole is your bars in the front now?
Re: Critique my corner weights.....UPDATE [Re: Cab_Burge] #991730
05/16/11 02:05 PM
05/16/11 02:05 PM
Longview, Texas
marvo451 Offline OP
marvo451  Offline OP
Longview, Texas
Front shocks ened up full stiff and I adjusted the rears after every pass. That was NOT the biggest wheelstand of the day. Rear Strange shocks are at 5 Extension and 5 Compression now.
Re: Critique my corner weights.....UPDATE [Re: marvo451] #991731
05/16/11 02:27 PM
05/16/11 02:27 PM
It lloks like your front bar joint is in the middle or upper hole on the, is it? if so I would try the lowest hole if you move the bars down don't forget to check and reset the pinion angle as needed I like 2 to 4 degrees difference pinion nose down between the drive shaft and the pinion angle on my Duster with ladder bars
Re: Critique my corner weights.....UPDATE [Re: Cab_Burge] #991732
05/16/11 04:29 PM
05/16/11 04:29 PM
Longview, Texas
marvo451 Offline OP
marvo451  Offline OP
Longview, Texas
Ladder bar is one hole from the top and is pointing downhill slightlty. I believe the position is close where it is. Any lower resulted in even larger wheelstands and less consistent traction. Where I usually race doesn't have the kind of traction as the Motorplex does.
