4 Weber 's on a Wedge? #991455
05/13/11 03:11 AM
05/13/11 03:11 AM
Right here
HP2 Offline OP
HP2  Offline OP
Right here
I can't get this out of my mind. I saw an x-brand V8 with 4 2-barrel Weber's standing up between the valve covers and it looked sooo cool
Have been googling around but can't find an intake for Chrysler engines.
Anyone seen one? Any experiences from Weber IDA's on a V8?
To get a picture of it just follow the link
http://www.carburetion.com/weber/wildv8.asp
70 W100 Power Wagon. 318 4-spd
70 Sport Fury 440 2dr HT
71 Duster 340
71 Charger Super Bee - 383/727
72 Charger "Sabotage" - 440/727 - Street/Strip
78 Warlock in beautiful patina
Re: 4 Weber 's on a Wedge? [Re: HP2] #991456
05/13/11 03:46 AM
05/13/11 03:46 AM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
I've seen small block weber setups. I think originally for sprint cars. I think there's a B engine weber setup too.
IIRC, Mopar Action did articles convering all the intakes made for small blocks and big blocks.
Re: 4 Weber 's on a Wedge? [Re: HP2] #991457
05/13/11 04:03 AM
05/13/11 04:03 AM
Goat Rodeo
drago Offline
drago  Offline
Goat Rodeo
One weber barrel for each intake port! means that there's no common plenum to cause reversion and rough cammy idle. idle will much smoother than similar holley setup.
GREAT 'WANG' NOISE! when they're working hard. all the euro supercars like ferrari and lambo used them.
downside is cost - complexity with the linkages and synchronising/tuning the carbs.
but you probably already knew this?
go for it!
Re: 4 Weber 's on a Wedge? [Re: drago] #991458
05/13/11 08:50 AM
05/13/11 08:50 AM
Carson City, NV
babarracuda Offline
babarracuda  Offline
Carson City, NV
There is a guy in San Luis Obispo, CA who used the Weber setup on a 413 B engine and ended up taking it off because it was faster and smoother with dual quads.
Re: 4 Weber 's on a Wedge? [Re: autoxcuda] #991459
05/13/11 12:30 PM
05/13/11 12:30 PM
Right here
HP2 Offline OP
HP2  Offline OP
Right here
I can drop an email to Mr Ehrenberg and ask, thanks for advice
71 Duster 340
Re: 4 Weber 's on a Wedge? [Re: HP2] #991460
05/13/11 12:41 PM
05/13/11 12:41 PM
Pikes Peak Country
TC@HP2 Offline
TC@HP2  Offline
Pikes Peak Country
Glenn Bunch runs them on his Hemi Challenger, but it is an IMSA GT race car.
These intakes were made, but not easily found.
Re: 4 Weber 's on a Wedge? [Re: TC@HP2] #991461
05/13/11 02:34 PM
05/13/11 02:34 PM
sweden
1Fast340 Offline
1Fast340  Offline
sweden
probably not impossible to have a manifold fabbed up by a good machinist.
webers worked real good on older europen 4cylinders,to be honest they are superior to holleys and edelbrocks by design since they realy dont care to much about the pulses wich the holleys and edelbrocks have so much trouble with handling.. the trick to make them work exept for tuning is to get the runnerlenghts and stacks right.
Re: 4 Weber 's on a Wedge? [Re: 1Fast340] #991462
05/15/11 03:53 AM
05/15/11 03:53 AM
Right here
HP2 Offline OP
HP2  Offline OP
Right here
I'm sure I can have one fabricated, but it will take a lot of time make everything working with linkage, tuning and all. Would be so much easier finding a complete kit like the ones from Carbs Unlimited.
My believe is that one barrel per cylinder will outperform any plenum intake on the planet when it comes to my needs
71 Duster 340
Re: 4 Weber 's on a Wedge? [Re: HP2] #991463
05/15/11 09:07 AM
05/15/11 09:07 AM
IN
ahy Offline
ahy  Offline
IN
On thing to consider... with one barrel per cylinder there is no "sharing" of carb capacity between cylinders. You need a lot more CFM per cylinder with this setup - maybe 3 or 4x what you would need for a single 4 bbl on a single plane. One of the articles mentioned above (MA I believe) went through the numbers. From memory, the biggest Weber could handle a warm SB but not a BB. You might be able to get some more specific information from the folks who set up one throttle body per cylinder injection.
Re: 4 Weber 's on a Wedge? [Re: ahy] #991464
05/15/11 01:27 PM
05/15/11 01:27 PM
Mesa, Arizona
dart4forte Online boogie
dart4forte  Online Boogie
Mesa, Arizona
Steve Strope of Pure Vision did a one-off Charger that was converted to right hand drive. It had three Webbers on a sixpack manifold.
Re: 4 Weber 's on a Wedge? [Re: dart4forte] #991465
05/15/11 01:44 PM
05/15/11 01:44 PM
sweden
1Fast340 Offline
1Fast340  Offline
sweden
her is another option,not webers but still very cool
http://www.unikracing.com/eng/chrysler.html
Re: 4 Weber 's on a Wedge? [Re: 1Fast340] #991466
05/15/11 04:01 PM
05/15/11 04:01 PM
Gig Harbor,WA
Commando66 Offline
Commando66  Offline
Gig Harbor,WA
How about this? It's a 273 with a fabricated intake.
Re: 4 Weber 's on a Wedge? [Re: HP2] #991467
05/15/11 04:07 PM
05/15/11 04:07 PM
AndyF Offline
AndyF  Offline
I designed a manifold for this conversion a while back. Fairly easy part to make but I never got around to putting it into production. The Weber carbs cost a ton of money, most people don't know anything about them, and there is a lot of fussing to do with the linkage and fuel lines. So I just moved on to other projects.
