Location of fuel vapor line / bulkhead in trunk #990948
05/12/11 01:11 PM
05/12/11 01:11 PM
Arizona
jsully Offline OP
jsully  Offline OP
Arizona
Can someone please post a picture with dimensions showing where the holes for the fuel vapor lines (holes for bulkhead) are located on a 70 Challenger trunk floor? It has a vent line on top of the fuel filler (just inside fender).
I replaced the trunk floor and extensions and did not 'see' any bulkhead when disassembling.
Thank you
Re: Location of fuel vapor line / bulkhead in trunk [Re: jsully] #990949
05/15/11 12:14 AM
05/15/11 12:14 AM
Arizona
jsully Offline OP
jsully  Offline OP
Arizona
Re: Location of fuel vapor line / bulkhead in trunk [Re: jsully] #990950
05/15/11 01:18 AM
05/15/11 01:18 AM
cataclysm80 Offline
cataclysm80  Offline
Here's a thread I had back in 2008 asking basicaly the same questions. I think you'll find it quite helpfull.
https://board.moparts.org/ubbthreads/show...&PHPSESSID=
Note the photo by B5TA shows which one of the two grommets is used, and that the other unused grommet does not have a hole punched in it yet. This is correct. The unpunched grommet is 70 challenger only I believe. Reproductions all come pre-punched.
Tav
Re: Location of fuel vapor line / bulkhead in trunk [Re: cataclysm80] #990951
05/15/11 03:58 PM
05/15/11 03:58 PM
Arizona
jsully Offline OP
jsully  Offline OP
Arizona
This is Perfect, Thank you very much.
I am headed out to cut the hole...
