70 Charge Moog front suspension part numbers #987713
05/07/11 07:45 PM
05/07/11 07:45 PM
missouri, USA
moparmojo Offline OP
missouri, USA
By chance does anyone happen to have the Moog part # for the front suspension of a 70 Dodge Charger.I am in need of a total rebuild. I got some Rock Auto gift cards and would like to get this front end finally back together.
Re: 70 Charge Moog front suspension part numbers [Re: moparmojo] #987714
05/07/11 08:13 PM
05/07/11 08:13 PM
N.E. OHIO, USA
A12 Offline
A12  Offline
N.E. OHIO, USA
Here's what I have that I used a few years ago:
1965-79 B-Body
'75-'79 Cordoba
'79 300 Dodge
'65-'76 Coronet
'66-'78 Charger
'69-'71 Super Bee
'77-'78 Monaco
'78-'79 Magnum Plymouth
'65-'70 Belvedere
'65-'74 Satellite
'67-'74 GTX
'68-'75 Road Runner
'75-'78 Fury
Upper Ball Joint Year Model Part Number
1965-79 All K772
Lower Ball Joint and Steering Arm Year Model Part Number (Right) Part Number (Left)
1965-72 All K781 K783
1973-79 All K7069* K7069*
* If original ball joint has four wrench flats, it is a threaded type and must be replaced by K719 threaded ball joint.
Upper Control Arm Kit Year Description Part Number
1965-72 Cam Bolt Kit (less bushings) K8243A
1965-72 Bushing Kit K408
1973-79 Shaft Kit K7105
1973-79 Bushing Kit K7058
Lower Arm Bushing Kit Year Model Part Number
1965-72 All K791 (2 kits required per car)
1973-79 All K7059 (2 kits required per car)
Strut Rod Bushing Kits Year Model Part Number
1965 All K7039
1966-72 All K7026
1973-74 exc/ Police & Taxi (to 10-19-73) K7068
1973-74 exc/ Police & Taxi (from 10-20-73) K7085
1973-74 Police & Taxi K7026
1973-79 All K7085
Idler Arm & Pitman Arm Kits Year Model Idler Arm Pitman Arm
1965-67 All K779 N/A
1968-70 All K7041 N/A
1971-72 All K7041 N/A
1973-76 All w/manual steering K7066 N/A
1973-76 All w/power steering K7066 K7076
1977-79 All K7066 K7076
Re: 70 Charge Moog front suspension part numbers [Re: A12] #987715
05/07/11 08:15 PM
05/07/11 08:15 PM
APACHE JUNCTION AZ
Joesixpack Offline
Joesixpack  Offline
APACHE JUNCTION AZ
I have the special tool to change the upper control arm bushings if you want to borrow it.
Re: 70 Charge Moog front suspension part numbers [Re: Joesixpack] #987716
05/12/11 02:44 AM
05/12/11 02:44 AM
near St Petersburg, FL
Lifsgrt Offline
Lifsgrt  Offline
Suggest you use the offset upper control arm bushings during your rebuild. Installed correctly, they'll bring your steering much closer to todays standards, and when you exit a turn, the steering wheel will self-center much more than with non-offset bushings.
Re: 70 Charge Moog front suspension part numbers [Re: moparmojo] #987717
05/12/11 09:51 AM
05/12/11 09:51 AM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
All those Moog p/n's will be listed on Rockauto under the make and model of your car !!!
Re: 70 Charge Moog front suspension part numbers [Re: A12] #987718
05/12/11 10:07 PM
05/12/11 10:07 PM
missouri, USA
missouri, USA
Thanks everyone!
