Re: Federal to Saginaw PS pump/direct swap?
[Re: JohnRR]
#985947
05/04/11 11:39 AM
05/04/11 11:39 AM
Posts: 6,095 Valencia, España
NachoRT74
Valencia, España
I think brackets and fittings are both diff
[Re: NachoRT74]
#985948
05/04/11 11:41 AM
05/04/11 11:41 AM
Posts: 1,249 Las Vegas
JeffC
Las Vegas
Yep, you need the right brackets and hose. Then you need to find a belt that will fit.
[Re: NachoRT74]
#985953
05/05/11 09:30 AM
05/05/11 09:30 AM
Posts: 3,712 Sacramento, Ca
Darius
Sacramento, Ca
Those brackets are cool. I wonder if there is a similar package for the same Federal to Saginaw switch on a 340?
Driving modern convenience in classic beauty
[Re: Darius]
#985954
05/05/11 09:47 AM
05/05/11 09:47 AM
Posts: 74,978 U.S.S.A.
JohnRR
U.S.S.A.
Yes there is, 1972 B body I worked on had a saginaw pump on it from the factory.
I ASSuMEd the OP had a saninaw pump setup for a smallblock complete and was wondering if it would work in place of the federal , didn't realize he was trying to reinvent the wheel .
