Re: Sequence Patterns and Codes
[Re: Dave Watt]
#9880
02/23/05 02:37 PM
02/23/05 02:37 PM
Posts: 4,361 swamps of florida
beepsalot
swamps of florida
the VON, has nothing to do with the order that the cars came out, they were generated by the chryco computer, dealing more with dealer number...I.E. - i know of 2 71 cuda 340/3 spd/shaker cars that have sequential order numbers, but the V.I.N.'s and assembly dates are 6 weeks apart, but they went to the same dealership. hope that throws a new light on the vehicle order number situation....
Just Follow Me Down the Street, You'll Know i'm Up to No Good...
[Re: M_code_Coop]
#9881
03/09/05 08:02 PM
03/09/05 08:02 PM
Sequence# B 301572 Order# 426 922482 Sequential number(VIN) WM21M9A303022.Sold car sales bank 4Special Order 9. Q5 AUTOMATIC 6 PAK under Remarks at bottom of sheet. Hope this helps. PJ
[Re: M_code_Coop]
#9884
05/05/05 12:24 AM
05/05/05 12:24 AM
Posts: 5,048 Atlanta Indiana
Dave Watt
Atlanta Indiana
This is a repost since all the old attachments are gone. Plymouth Road Runner RM21M9A246386 949003 Order Number 3-29-69 Scheduled Build Date
Engine casting # 2536430-5 (Cast date) 2 19 69 E440 (EAD) 3 19 HP T W (According to Galen G., TW stands for water test)
Transmission
Exhaust Manifolds 2806900 (right)(No Date) 2843992 (left) (Date) 1 8 69
Carburators Front (List)4393 (Date)0739 Center(List)4391 (Date)0729 Rear (List)4394 (Date)0729
Dana 60 housing 2 17 9 B1 2 20 9 B7 3 C 34155 602957 6
Sure grip unit (Date) 2 19 69
Torsion Bars, Hemi Suspension Right 780 (Date)109 Left 781 (Date)079
Wiper Motor (Date) 0219
Radiator 2949054 (Date)0279
[Re: 69Y2RT]
#9886
12/11/05 09:21 PM
12/11/05 09:21 PM
Posts: 586 Silicon valley
A12bee
super street
super street
Silicon valley
I was working on the bee over the weekend and found another part with a date code. The attached shot is from the inner fender splash quard. It is marked as such SWL 9 2. I believe decoded that is left side splash guard Dated (9) 1969 , (2) Feb. -Paul
This space left intentianlly blank.
[Re: A12bee]
#9887
12/29/05 03:46 PM
12/29/05 03:46 PM
A12bee
super street
super street
Silicon valley
Saw this on the eng/trans lost and found page.
440 block from lynch road
Vin 9A270698 Cast date 2 17 69 EAD 5 5 69
[Re: M_code_Coop]
#9888
01/11/06 09:50 PM
01/11/06 09:50 PM
Posts: 5,659 Port Huron, Michigan
MI_Custumz
Here is a link to a 69 Runner that was built at Lynch Rd. I am not at home so hopefully someone can save the pics for reference. Last 6 of VIN is 289324 and built on 605. Can't quite make out the buildsheet since I am at work supposed to be working. web page
[Re: MI_Custumz]
#9890
01/13/06 01:13 AM
01/13/06 01:13 AM
Posts: 4,150 VA
RapidRunner
VA
I guess I will add this here. Ever adding to list
the second column is the SPD from the fender tag.
RH 319 9A243347 RM 315 9A243369 RM 324 9A246221 RM 329 21M9A246386--------EAD 3 19 (dave Watt) ..........9A246386----Feb 6th Tranny (Dave Watt) RM 329 21H9A246389--------EAD 3 19 (Harry Goldthorpe) RH 327 9A248906 RM 402 9A252551 RM 404 21H9A254049 WM 408 9A255429 RM 329 21M9A257118 -----------(rocketresto) RM 410 9A257478 RM 426 23M9A262511 ------ 4 29 (HolyRRoller tranny) WM 426 M9A263554 (AZ Dave) WM 501 9A265557 RM 505 9A266270 RM 506 9A267355 ..........9A270643--------EAD 5 28 ..........9A270698--------EAD 5 5 RM 426 23M9A272929--------EAD 6 4 RM 426 23M9A282561 (TailButcher) RM 426 23M9A282563--------EAD 6 5 RM 426 21M9A282574 (RapidRunner) RM 426 2XM9A282587 (gillman34) WM 426 23M9A284121---------------(justonewontdo) RM 426 23M9A286687--------EAD 6 3 (John D’s from Northern VA) RM 605 21H9A289324 ---------(MI_Custumz) TRANS VIN 290229 May 21,1969 (DannysBEE) WM 23H9A295300--------EAD 6 12 RM 616 23H9A297104 TRANS VIN 9A297974 May 28 1969 RM 619 9A300194 WM 426 23M9A301687--------EAD 6 10 (BADSIXPACK – Pete) WM 426 23M9A301697 (BADSIXPACK – Pete) RP 618 9A300367 XX 426 M9A303025--------EAD 6 13 WM 426 9A306947 WM 426 23M9A306xxx--------EAD 6 18 RM 701 9A305078 RS 709 9A309995 RM 709 9A310417 RM 709 9A310859
Who knows? The Shadow Knows! But he ain't on this fraking forum!
"This restoration is a test,, It is ONLY a test, Had this been an actual Restoration I would have received instructions on what to do and where to get the MONEY!"
[Re: RapidRunner]
#9891
01/19/06 08:33 PM
01/19/06 08:33 PM
Where do I find the EAD???
[Re: Dave Watt]
#9893
01/20/06 08:29 AM
01/20/06 08:29 AM
Thanks. I wish that I had my original block back. I was told that it was ruined and then I found out that it ended up in a Charger, that has been sold out of our area to parts unknown.
[Re: M_code_Coop]
#9894
01/24/06 12:52 AM
01/24/06 12:52 AM
Coop, recent acquisition, M-Code WM23M9A284121, tag notes = Top LtoR 13134 286679 Bottom right, 921468, don't know if it helps the cause, but looking for original drivetrain as we speak...Origianl F/8 car, painted yellow, minied, tied, celled, 6 pointed, any guys out there remember this car from street bracket racing extensively in the 80's (Chicagoland)(Some of you guys might not remember the eighties!) (Maybe that's good-Back then Michael Jackson was eccentric, not crazy!) Thanks for the much information you have posted, I have really enjoyed reading the posted information.......What's the build date based on this info coop??..........B
#9896
01/25/06 12:00 AM
01/25/06 12:00 AM
Posts: 2,562 Harleysville PA
M_code_Coop
Harleysville PA
Welcome! and thanks for the info. Nice car too. many of us have cars which were track warriors...you're far from alone on that one. Every little bit of info helps. Now, if we can get some of the 'all original' motor cars out there to post their dates we could more accurately assess the NOM cars. I'm no expert, just guilty of starting this thread. Love to take a guess at your build date... Have you checked behind the door panels? They are one of the last things to go on the car and are dated. Aside from part dates we generally use the VINs to round up a build date. if you look above to Rapid's (Mike E) post you'll see John D's original motor car has a VIN very close to yours and an EAD (engine assembly date) of June 3rd. The post 2 above that refers to a lynch road runner with a 289324 VIN having an 'official' (often not actual) build date of June 5th. If you check through the various info on this thread you'll see a broad trend. The early cars (24XXXX VINs) were built in March, and the late cars (30XXXX VINs) were built in June/July. But that's not to say the trend is absolute. There are always exceptions. The debates on when the engines and door panels were actually installed (relative to when they were dated) have yet to be resolved. But taking all things into consideration, and hazzarding a guess for you- I'd say your car generally fits into a 1st or second week of June build date. Take your pick on the exact day. It would've been nice if the last person escorting these things out the door had stamped the date on them -LOL- but no such luck. We are left to speculate through calculated guessing. Hopefully more here will speculate on how to decipher your car's date. You'll see the beauty of this forum and how multiple responses lead to a more complete understanding of the 'answer'. Welcome (again) and stick around.
[Re: M_code_Coop]
#9897
01/25/06 12:54 AM
01/25/06 12:54 AM
Thanks Coop, I have been enlightened by both you and Mr. Watt, and I see the "trend" you are talking about. Don't hold it against me, but I have been through GTO's for the last dozen years (maybe 50-3 Judges), and it is easier to deal with connecting a car with the original paperwork from Pontiac (PHS), Vs a car that has been for lack of a better term, "drop shipped to the hot rod shop"....This is an education on my part... By the way the entire tag reads 13134 286679 9A284121 925 999 603 26 A12 1X 8X F8 F8 h2X X9 WM23 E63 D21 426 921468 Tag has a sideways "G' by the right screw hole... Mr Watt has been gratious and filled me in on most of the meanings of these (Hats Off to Him!) Great Forum here, my experiences so far have been great,,,,, Keep Smiling! Brian
