ATF for power steering. #985579
05/03/11 07:22 PM
05/03/11 07:22 PM
San Jose,CA
migsBIG Offline OP
YouTube is my go-to news source
migsBIG  Offline OP
San Jose,CA
We were finishing the tightning and fill of the firm feel box and remembered back in the good old days we used to use ATF in those thing. Was wondering if there was any benifit to running that instead of the moddern ps fluids that are now out.
Re: ATF for power steering. [Re: migsBIG] #985580
05/03/11 07:34 PM
05/03/11 07:34 PM
St. John's Newfoundland
440newport Offline
440newport  Offline
I don't think there is a benefit but I always used ATF.
Re: ATF for power steering. [Re: 440newport] #985581
05/04/11 03:31 AM
05/04/11 03:31 AM
Granite Bay CA
Kern Dog Offline
Striving for excellence
Kern Dog  Offline
Granite Bay CA
I have read several times that with Mopars, ATF is for the trans and Power steering fluid is for the pump. Nobody has explained why to me either. I have used ATF for years with no ill effects. Maybe a member can offer more insight?
Re: ATF for power steering. [Re: Kern Dog] #985582
05/04/11 07:59 AM
05/04/11 07:59 AM
North Dakota
6PakBee Offline
6PakBee  Offline
North Dakota
FSM
Re: ATF for power steering. [Re: migsBIG] #985583
05/04/11 08:23 AM
05/04/11 08:23 AM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
I read once in a manual or some place that Mopar says you may want to use auto transmission fluid in cold climates
Re: ATF for power steering. [Re: Dodgem] #985584
05/04/11 11:10 AM
05/04/11 11:10 AM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
Run one of each for a year,drain and you will see why they don't recommend ATF in power steering pump.
Re: ATF for power steering. [Re: Dodgem] #985585
05/04/11 11:36 AM
05/04/11 11:36 AM
A Banana Republic near you.
JohnRR Offline
JohnRR  Offline
That was for 833's ...
Re: ATF for power steering. [Re: JohnRR] #985586
05/04/11 02:31 PM
05/04/11 02:31 PM
Granite Bay CA
Kern Dog Offline
Kern Dog  Offline
Granite Bay CA
Come on, people... we are all car guys. Telling us NOT to do something isn't enough. The traits that make us good mechanics ALSO make us curious people. WHY? WHY? WHY??? I have a much easier time accepting an answer when I know the reasoning behind it. This is certainly one of the reasons that I was a "pain in the butt" kid. I never liked hearing people say..." Because I am the mother/father/uncle/policeman, THATS why."
Re: ATF for power steering. [Re: JohnRR] #985587
05/04/11 02:48 PM
05/04/11 02:48 PM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
that's probably it used it in my 4 speed or a 50/50 mix. but I did use ATF for power steering in all my cars and trucks from 1976 till 2001.
Yup it's in the manual transmission part of my 68 manual but I converted to auto in the spring of 1984
Re: ATF for power steering. [Re: Dodgem] #985588
05/04/11 03:37 PM
05/04/11 03:37 PM
Littleton Colo
Geezer Offline
Geezer  Offline
Littleton Colo
Tom Lee used to recommend for saginaw boxes the over the counter GM product or the Havoline product,must not be available anymore as he is selling his own now. http://lee-powersteering.com/rebuild-misc.htm
Re: ATF for power steering. [Re: 62maxwgn] #985589
05/04/11 04:40 PM
05/04/11 04:40 PM
Houston, Texas
racerx20 Online content
Standard but OK
racerx20  Online Content
Standard but OK
Houston, Texas
My 05 GTO uses ATF in the power steering pump from the factory.
1972 Road Runner
1988 Shelby CSX-T
Re: ATF for power steering. [Re: racerx20] #985590
05/04/11 06:03 PM
05/04/11 06:03 PM
Indiana
Fury Fan Offline
Fury Fan  Offline
Indiana
Lots of science between fluids and the seals. PS is just a hydraulic system, so anything will work, right?. The question is - for how long and what will the effects be?
The OEMs alter seal materials to keep pace with the recommended fluids (and vice versa). The effects might take a while to manifest and therefore might be attributed to normal wear -- and not to incorrect fluid. Dexron 6 is a prime example.
Re: ATF for power steering. [Re: Fury Fan] #985591
05/04/11 06:25 PM
05/04/11 06:25 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Compare the P/N of some steering box seals from the era when they used ATF to the later era when they warned not to use ATF...same P/N, same seal so material compatability isn't the issue.
Re: ATF for power steering. [Re: John_Kunkel] #985592
05/04/11 07:19 PM
05/04/11 07:19 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
You are making an assumption that may not be warranted. Who is to say the seal material wasn't changed with the later made PN? Be cheaper to make all seals out of one material that is compatible with both fluids than to use two different materials.
One thing I do know, some GM types told my wife to run ATF in my 72 Dart's power steering when the was low. Shortly thereafter I had to replace the seal in the steering box output. Coincidence? I dunno but it's a job that is no fun to do.
Don't be the exception.
Re: ATF for power steering. [Re: Supercuda] #985593
05/04/11 08:07 PM
05/04/11 08:07 PM
Someplace you aren't
SomeCarGuy Offline
SomeCarGuy  Offline
You could always just run a manual box. No fluid to worry over then.
I want my fair share
Re: ATF for power steering. [Re: Supercuda] #985594
05/04/11 08:07 PM
05/04/11 08:07 PM
md
W
wicked Offline
wicked  Offline
W
md
Seems to me power steering fluid had a little higher viscosity than atf, and I know I've had less issue with leaks using it
Re: ATF for power steering. [Re: wicked] #985595
05/04/11 08:10 PM
05/04/11 08:10 PM
connecticut
pnypwr Offline
pnypwr  Offline
connecticut
its says not to run type a atf, fords run dex3 in their ps systems, ive seen type a being thinner and leaking, type f is heavier, but nowadays its all mixed and called FA i run dex 3 with no ill effects.
"Are you gonna bark all day lil doggy? Or are you gonna bite?"
05 ram 2500 ctd
74 gremlin x 360
65 mustang 347
70 coronet R/T 440
03 Mach 1
Re: ATF for power steering. [Re: wicked] #985596
05/05/11 02:01 AM
05/05/11 02:01 AM
Granite Bay CA
Kern Dog Offline
Kern Dog  Offline
Granite Bay CA
The owners manual for my 2007 RAM 1500 states that ATF+4 is to be used in the power steering pump. Its synthetic.
Re: ATF for power steering. [Re: migsBIG] #985597
05/05/11 09:22 AM
05/05/11 09:22 AM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
Back in the day I never saw anyone run PS fluid.Everyone just used ATF.There should have been millions of bad ps units then.I use PS fluid now as most newer cars require it.My sons 62 still has ATF in it.No problems after almost 50 years.Rocky
Chrysler Firepower
Re: ATF for power steering. [Re: therocks] #985598
05/05/11 09:39 AM
05/05/11 09:39 AM
Norwich CT USA
moparts Offline
moparts  Offline
Norwich CT USA
I know as of 5 years ago when I was still working for a Dodge dealer, the PS Fluid was switched over to the ATF +4 which is a synthetic type fluid.
Not sure if they still use the ATF+4 as PS fluid but they did for awhile
Tom ,
2011 Ram 3500 C&C Diesel
2009 Challenger R/T
1971 Challenger Conv. 511/4 speed
1970 Challenger R/T 503/727
