Re: ATF for power steering.
[Re: Fury Fan]
#985591
05/04/11 06:25 PM
05/04/11 06:25 PM
Posts: 25,967 Rio Linda, CA
John_Kunkel
Rio Linda, CA
Compare the P/N of some steering box seals from the era when they used ATF to the later era when they warned not to use ATF...same P/N, same seal so material compatability isn't the issue.
[Re: wicked]
#985595
05/04/11 08:10 PM
05/04/11 08:10 PM
Posts: 4,872 connecticut
pnypwr
connecticut
its says not to run type a atf, fords run dex3 in their ps systems, ive seen type a being thinner and leaking, type f is heavier, but nowadays its all mixed and called FA i run dex 3 with no ill effects.
"Are you gonna bark all day lil doggy? Or are you gonna bite?"
05 ram 2500 ctd 74 gremlin x 360 65 mustang 347 70 coronet R/T 440 03 Mach 1
[Re: migsBIG]
#985597
05/05/11 09:22 AM
05/05/11 09:22 AM
Posts: 21,083 Niles , Ohio
therocks
Niles , Ohio
Back in the day I never saw anyone run PS fluid.Everyone just used ATF.There should have been millions of bad ps units then.I use PS fluid now as most newer cars require it.My sons 62 still has ATF in it.No problems after almost 50 years.Rocky
Chrysler Firepower
[Re: therocks]
#985598
05/05/11 09:39 AM
05/05/11 09:39 AM
Posts: 15,552 Norwich CT USA
moparts
Norwich CT USA
I know as of 5 years ago when I was still working for a Dodge dealer, the PS Fluid was switched over to the ATF +4 which is a synthetic type fluid. Not sure if they still use the ATF+4 as PS fluid but they did for awhile
Tom ,
2011 Ram 3500 C&C Diesel 2009 Challenger R/T 1971 Challenger Conv. 511/4 speed 1970 Challenger R/T 503/727
