1970 440-6 problems
#98484
08/02/08 11:42 AM
08/02/08 11:42 AM
when I accelerate lightly I get a surge and when I come off the highway I get a lot of backfiring through both exhausts. I have glass packs, Taylor plug wires, Auto light 85 plugs, Mopar pointless distrbutor, timing is 12 and 36. No vacuum leaks but may have an exhaust leak. Any ideas? At 65mph the car seems to run great. I have about ninty miles on the car right now.
Re: 1970 440-6 problems
#98485
08/02/08 11:45 AM
08/02/08 11:45 AM
Posts: 3,312 Marine Corps Base Hawaii
DemonKyle
USMC LCPL
USMC LCPL
Whats the timing set at?
Have you tuned all three carbs?
Edit: Oops completely Missed it
[Re: DemonKyle]
#98486
08/02/08 11:55 AM
08/02/08 11:55 AM
as I said in the first question the timing is set at 12 and 36 and yes the carbs are set
#98487
08/02/08 12:52 PM
08/02/08 12:52 PM
Posts: 3,287 West Coast, USA
jbc426
West Coast, USA
Sounds like a fuel control/float level issue to me. Did it just start doing it or has it always done it(dirt/contamination)?
1970 Plymouth 'Cuda #'s 440-6(block in storage)currently 493" 6 pack, Shaker, 5 speed Passon, 4.10's 1968 Plymouth Barracuda Convertible 408 Magnum EFI with 4 speed automatic overdrive, 3800 stall lock-up converter and 4.30's (closest thing to an automatic 5 speed going)
[Re: jbc426]
#98488
08/02/08 01:31 PM
08/02/08 01:31 PM
always do it and I just took the three carbs off and cleaned them inside and out. They have ninty miles on the and now they have four miles on them so I do not think it is a fuel issue
[Re: DemonKyle]
#98490
08/02/08 02:13 PM
08/02/08 02:13 PM
Posts: 216 clearwater,fl
postbody65
clearwater,fl
check your firing order and timing your airgap start on basics
[url=http://www.postbody65@yahoo.com
#98491
08/02/08 02:20 PM
08/02/08 02:20 PM
maybe disconnect front and rear carb.-vehicle should run smooth on center carb.-if it does then you have a problem with one of the outboard carbs.
[Re: screamindriver]
#98493
08/02/08 05:12 PM
08/02/08 05:12 PM
that is interesting because I was wondering if the glass packs were the popping I was hearing. It is more a poppomg than a backfire and I do have an exhaust leak where the exhaust manifold connects to the exhaust, just have not had a chance to fix that yet
[Re: Challenger 1]
#98495
08/02/08 05:49 PM
08/02/08 05:49 PM
we did an extensive check for a vacuum leak and found nothing
#98497
08/03/08 04:55 PM
08/03/08 04:55 PM
at this point nothing is clearing up the problem could you explain to me what a bad power valve in the center carb would do.
[Re: 69440]
#98499
08/03/08 05:12 PM
08/03/08 05:12 PM
the vacuum advance is plugged. That was one of the first things suggested. Can you tell me about the power valve?
#98501
08/08/08 04:53 PM
08/08/08 04:53 PM
Posts: 120 Arizona
anmracing
Arizona
When you say it surges, what do you mean???? When you give it gas it doesn't do anything (it bogs)and then it feels like it catches and gets moving again?????
