1970 440-6 problems #98484
08/02/08 11:42 AM
08/02/08 11:42 AM
Anonymous OP
Anonymous OP
when I accelerate lightly I get a surge and when I come off the highway I get a lot of backfiring through both exhausts. I have glass packs, Taylor plug wires, Auto light 85 plugs, Mopar pointless distrbutor, timing is 12 and 36. No vacuum leaks but may have an exhaust leak. Any ideas? At 65mph the car seems to run great. I have about ninty miles on the car right now.
Re: 1970 440-6 problems #98485
08/02/08 11:45 AM
08/02/08 11:45 AM
Marine Corps Base Hawaii
DemonKyle Offline
USMC LCPL
DemonKyle  Offline
USMC LCPL
Whats the timing set at?
Have you tuned all three carbs?
Edit: Oops completely Missed it
Re: 1970 440-6 problems [Re: DemonKyle] #98486
08/02/08 11:55 AM
08/02/08 11:55 AM
Anonymous OP
Anonymous OP
as I said in the first question the timing is set at 12 and 36 and yes the carbs are set
Re: 1970 440-6 problems #98487
08/02/08 12:52 PM
08/02/08 12:52 PM
West Coast, USA
jbc426 Offline
jbc426  Offline
West Coast, USA
Sounds like a fuel control/float level issue to me. Did it just start doing it or has it always done it(dirt/contamination)?
Re: 1970 440-6 problems [Re: jbc426] #98488
08/02/08 01:31 PM
08/02/08 01:31 PM
Anonymous OP
Anonymous OP
always do it and I just took the three carbs off and cleaned them inside and out. They have ninty miles on the and now they have four miles on them so I do not think it is a fuel issue
Re: 1970 440-6 problems [Re: jbc426] #98489
08/02/08 01:43 PM
08/02/08 01:43 PM
DemonKyle Offline
USMC LCPL
DemonKyle  Offline
USMC LCPL
Sounds like the timing is off to me. Or fuel mixture.
Maybe loading up too much in one cylinder?
Re: 1970 440-6 problems [Re: DemonKyle] #98490
08/02/08 02:13 PM
08/02/08 02:13 PM
clearwater,fl
P
postbody65 Offline
postbody65  Offline
P
clearwater,fl
check your firing order and timing your airgap start on basics
[url=http://www.postbody65@yahoo.com
Re: 1970 440-6 problems #98491
08/02/08 02:20 PM
08/02/08 02:20 PM
Anonymous OP
Anonymous OP
maybe disconnect front and rear carb.-vehicle should run smooth on center carb.-if it does then you have a problem with one of the outboard carbs.
Re: 1970 440-6 problems #98492
08/02/08 04:54 PM
08/02/08 04:54 PM
Harrisburg, Pa.
screamindriver Offline
Harrisburg, Pa.
Good Lord don't disconnect the secondary carb linkage...They'll open up and you won't be able to close them...If the surge is RPM specific it might be the distributor mechanical advance curve in action...Or it could be a slight lean surge and the center carb needs bigger jets.. No way to tell sitting here for sure.. Is the exhaust poping or really cracking ???? Exhaust leak upstream will sometimes pop like that or simply the glass packs are doing their thing...
Re: 1970 440-6 problems [Re: screamindriver] #98493
08/02/08 05:12 PM
08/02/08 05:12 PM
Anonymous OP
Anonymous OP
that is interesting because I was wondering if the glass packs were the popping I was hearing. It is more a poppomg than a backfire and I do have an exhaust leak where the exhaust manifold connects to the exhaust, just have not had a chance to fix that yet
Re: 1970 440-6 problems [Re: screamindriver] #98494
08/02/08 05:14 PM
08/02/08 05:14 PM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
Sounds lean for sure and the back fire could be from being lean or a vacuum leak. Doubt if it has anything to do with what kinda mufflers you have. Could be the exhaust leak you have at the manifold causing the back fire on decell.
Re: 1970 440-6 problems [Re: Challenger 1] #98495
08/02/08 05:49 PM
08/02/08 05:49 PM
Anonymous OP
Anonymous OP
we did an extensive check for a vacuum leak and found nothing
Re: 1970 440-6 problems #98496
08/02/08 06:00 PM
08/02/08 06:00 PM
Arizona
anmracing Offline
anmracing  Offline
Arizona
It sounds like a lean issue...
The popping is cool air sucked in from the exhaust manifold leak on decel is my bet....
Glass pack sound awesome and they will pop on decel too.....
I would love to hear a sound clip of your car.
Re: 1970 440-6 problems [Re: screamindriver] #98497
08/03/08 04:55 PM
08/03/08 04:55 PM
Anonymous OP
Anonymous OP
at this point nothing is clearing up the problem could you explain to me what a bad power valve in the center carb would do.
Re: 1970 440-6 problems #98498
08/03/08 05:05 PM
08/03/08 05:05 PM
Washington
69440 Offline
69440  Offline
Washington
This is just a shot in the dark, but try disconnecting the vacuum advance, but be sure to plug off both sides. If you see any difference, then you can be safe to assume it's within the dist.
Re: 1970 440-6 problems [Re: 69440] #98499
08/03/08 05:12 PM
08/03/08 05:12 PM
Anonymous OP
Anonymous OP
the vacuum advance is plugged. That was one of the first things suggested. Can you tell me about the power valve?
Re: 1970 440-6 problems #98500
08/08/08 04:43 PM
08/08/08 04:43 PM
Arizona
anmracing Offline
anmracing  Offline
Arizona
If the PV is bad you would find that your plugs would foul out pretty fast and would be blowing black smoke.
It could possibely cause a back fire through the exhaust due to it running a lot richer than it should. That combined with a possible crossed wire could cause a huge exhuast backfire that would wake up the dead......
To answer your question, what it does is the diaphram opens as the vacuum drops when pressing the excelerator causing it to richen up. If you put a plug in place of a PV then you better changer the jets. Boost them up 10-12 sizes bigger.
Re: 1970 440-6 problems #98501
08/08/08 04:53 PM
08/08/08 04:53 PM
Arizona
anmracing Offline
anmracing  Offline
Arizona
When you say it surges, what do you mean???? When you give it gas it doesn't do anything (it bogs)and then it feels like it catches and gets moving again?????
Re: 1970 440-6 problems #98502
08/08/08 10:19 PM
08/08/08 10:19 PM
Groton, MA.
BHuey Offline
BHuey  Offline
Groton, MA.
Does your car have power brakes ? If so don't overlook the vacuum booster, it can cause a surge condition if the diaphram is leaking, brakes can feel OK but vaccuum on a gauge will be low and fluctuating.
70 Challenger R/T Conv. 66 Vette 427 Coupe 61 Vette FI Roadster
