Page 1 of 3 1 2 3
ECS Carpet Review #982826
04/29/11 10:10 PM
04/29/11 10:10 PM
Georgetown Ontario Canada
anlauto Offline OP
anlauto  Offline OP
Today I installed my first carpet from ECS...
Here it is right out of the box.
CHECK OUT MY NEW WEB SITE !
Re: ECS Carpet Review [Re: anlauto] #982827
04/29/11 10:11 PM
04/29/11 10:11 PM
anlauto Offline OP
anlauto  Offline OP
As you can see it lays in place nicely, but there is plenty of triming to do.
Re: ECS Carpet Review [Re: anlauto] #982828
04/29/11 10:13 PM
04/29/11 10:13 PM
anlauto Offline OP
anlauto  Offline OP
Unfortunately with me living in Canada the cost of this carpet and the shipping was somewhat expensive...approximately three times more then a regular carpet..
Re: ECS Carpet Review [Re: anlauto] #982829
04/29/11 10:15 PM
04/29/11 10:15 PM
anlauto Offline OP
anlauto  Offline OP
I was very impressed with the way it seem to fit nicely in place, but that didn't really "speed up" the installation process...As for "loop count" and things of that nature, I could not visually see in difference from other carpets I've installed..
Re: ECS Carpet Review [Re: anlauto] #982830
04/29/11 10:22 PM
04/29/11 10:22 PM
Washougal,Wa
Dodge Offline
Dodge  Offline
Washougal,Wa
How much was just the carpet? Looks to lay down alot better than the carpet I put in my Charger last year. Have you installed a better fitting carpet kit?
Stand behind your word
Re: ECS Carpet Review [Re: anlauto] #982831
04/29/11 10:22 PM
04/29/11 10:22 PM
anlauto Offline OP
anlauto  Offline OP
I don't think the gas pedal ended up where it should, but that could be my fault or the fact that the carpet was molded to the hump in the floor and when up tight against the hump, I could not move the heel pad any further to the passenger side.
OVER ALL:
It is very nice quality stuff for sure.
Unless I have another customer that directs me to buy it, or ECS comes up with a way to supply them without shipping (ie: selling them at major shows) I really don't feel that there was sufficient differences from a quality rolled up carpet for me to justify the extra cost.
You guys living inside the USA must try one of these carpets and form your own opinion.
I've installed 20+ carpets in my day...
Re: ECS Carpet Review [Re: Dodge] #982832
04/29/11 10:24 PM
04/29/11 10:24 PM
anlauto Offline OP
anlauto  Offline OP
By the time it arrived in Canada it was $500+ CDN.
No, I've never installed a better fitting carpet, but I've been able to get great results using carpet that has been rolled in a box as well.
Re: ECS Carpet Review [Re: anlauto] #982833
04/29/11 11:12 PM
04/29/11 11:12 PM
On the previous one's that you've installed, did you use any heat source like a heat gun to get the carpet to lay down better? Do most carpet sets come with the jute (sp?) backing? I'm in the market for some and trying to find out all I can...
Re: ECS Carpet Review [Re: anlauto] #982834
04/30/11 12:01 AM
04/30/11 12:01 AM
Warrenton, VA
RoadRunnerJD Offline
Warrenton, VA
How long did you have to wait? Did they take your order right away when you called? I'd like to get one for my 69 Barracuda but ECS does not have an inventory and said I would have to wait until they could work it in to a future order from their supplier. It sounded like I have to wait indefinitely? I offered to make a deposit. They are supposed to let me know when they're ready but I'm not sure they really have my contact information? I guess I'll get back in touch and try to re-order. One thing is for sure, I cannot live with the Tr_m one I got. It's laying out flat in the car now just hoping it will gain done shape but it's not looking any better than when it came out of the box. It absolutely does not fit nicely over the 4 speed hump. At least the ACC carpets that I have put in my B bodys was somewhat formed and layed flat once you get it in place.
Re: ECS Carpet Review [Re: RoadRunnerJD] #982835
04/30/11 09:29 AM
04/30/11 09:29 AM
anlauto Offline OP
anlauto  Offline OP
I went through the exact same process I waiting quite awhile, but I believe it was during the time of their "move". Once I actually placed the order and paid for it, the wait time was only a couple of weeks...I bought two at the same time and they were both stuffed in the same box
I've never had to use a heat source in the past? Try taking them out of the box when they arrive and lay them out somewhere...The sun helps if it's summer time.
Re: ECS Carpet Review #982836
04/30/11 10:50 AM
04/30/11 10:50 AM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
The ECS carpet is the best available if you want a proper fit and contour. The other sources that are rolled, folded, and crammed into a box CAN be made to lay flat but usually requires allot of manipulating and a heat gun, then they always seem to have weird stretches and mis shapen areas that never lay right.
The biggest issues I've seen from the other sources are the heal pads which are not right, and most are cut too small overall which does not cover some areas as far as they should (like up under the firewall). ECS carpets are larger so you can trim them properly on all sides and have the heal pads sewn into the correct area.
Yes, the cost is high, maybe not for everyone, especially "drivers", but if you are looking for a high end show car quality ECS supplied carpet stands alone.
Re: ECS Carpet Review [Re: ScottSmith_Harms] #982837
04/30/11 10:58 AM
04/30/11 10:58 AM
On the run…
BloFish Offline
BloFish  Offline
On the run…
I have to agree with Scott. I've bought 2 of them over the years, and was very pleased with the quality
It really doesn't matter whether you win or lose…
as long as you look good doing it!
‘65 A100
‘69 ‘Cuda
‘73 Vega GT
‘06 Mega Cab
‘14 Mercedes SLK
Re: ECS Carpet Review [Re: BloFish] #982838
04/30/11 11:12 AM
04/30/11 11:12 AM
Kirkland, Washington
Pacnorthcuda Online boogie
Pacnorthcuda  Online Boogie
Top quality, too bad the shipping makes it so spendy.
Makes me wonder if a middle-ground solution might work--DON'T cram it into the smallest box possible like the cheap way, but a few(?) strategic folds of the ECS carpet to avoid the "oversized" shipping yet still lay much better than the small box way???
Re: ECS Carpet Review [Re: Pacnorthcuda] #982839
04/30/11 11:22 AM
04/30/11 11:22 AM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
My personal take on that is that you don't compromise quality to make things cost less, there's plenty of that out there already, mediocrity sucks!
Re: ECS Carpet Review [Re: ScottSmith_Harms] #982840
04/30/11 02:16 PM
04/30/11 02:16 PM
Montreal,Quebec,Canada
JulesdaWiperman Offline
super gas
super gas
So far I have ordered one ECS carpet and it is ABSOLUTELY the best. The service was awesome and the product was
as described. The expense was worth it as the carpet lay perfectly first shot. To me the extra work in installing
other carpets is much worse than the extra expense.
Jules
Re: ECS Carpet Review [Re: JulesdaWiperman] #982841
04/30/11 07:28 PM
04/30/11 07:28 PM
anlauto Offline OP
anlauto  Offline OP
Can't wait to try a column shift car with no console brackets to cut around...
I agree 110% that it layed down nice, but I couldn't see telling my customers that carpet cost $500
Most of my guys want cars done nice, but always seem to have a budget and not deeeep pockets...Maybe one of these days I'll get some guys with big bucks !
I like to restore cars for the "workin man"
Re: ECS Carpet Review [Re: anlauto] #982842
04/30/11 09:13 PM
04/30/11 09:13 PM
It sounds like your complaint should be with the shipping company. You called this vendor, they gave you a price, you relayed the pricing information to your customer, your customer accepted, you called the vendor back to place the order and now gripe about the choices you made? Nobody forced you or your customer to buy anything. The best advice here would be to get on a shipping forum and complain about how much they charge to send things from the US to Canada. Isn't that your real complaint?
Re: ECS Carpet Review [Re: anlauto] #982843
04/30/11 09:13 PM
04/30/11 09:13 PM
Richmond, VA
rayztoy Offline
rayztoy  Offline
Richmond, VA
Re: ECS Carpet Review [Re: rayztoy] #982844
04/30/11 09:37 PM
04/30/11 09:37 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
I like to think of ALL of my customers as "working men" regardless of thier job descriptions, incomes, or budgets.
Re: ECS Carpet Review [Re: ScottSmith_Harms] #982845
04/30/11 10:07 PM
04/30/11 10:07 PM
RI Deep in the rust belt
chargervert Offline
chargervert  Offline
That rug looks great Alan. I thought that 1970 4 speed B bodies that had Burnt Orange interiors,came with black carpet. I know that automatic cars had Burnt Orange carpets,but if I remember correctly 4 speeds had black rugs. Was that just Dodges,or were the Plymouth cars carpet black also?
70 Charger R/T SE 472 Hemi 70 Charger R/T convertible 70 Charger R/T V Code Sixpack 69 Charger R/T SE Sunroofcar 68 Charger 383 68 Charger 318 71 Charger R/T 70 Challenger convertible 71 Challenger convertible 71 Cuda 340 09 Challenger R/T Classic
Page 1 of 3 1 2 3
