77 Cordoba,How many parts will work on 72 Rally Charger #982809
04/29/11 10:06 PM
04/29/11 10:06 PM
Manistee, Michigan.
High Impact Offline OP
Manistee, Michigan.
I have a buddy that want to sell me a 77 doba with a running 400-4bbl with buckets and console with a tilt column. Disk brakes, rear sway bar..........I guess thats about it for good stuff. How many parts will work on a 72 B-body. Just trying to figure out if its worth it.
Thanks,Dave-
Re: 77 Cordoba,How many parts will work on 72 Rally Charger [Re: High Impact] #982810
04/29/11 11:01 PM
04/29/11 11:01 PM
Kent, Wa
340SHORTY Offline
Truck Nut
340SHORTY  Offline
Truck Nut
Kent, Wa
door hinges
I am truckless..
Re: 77 Cordoba,How many parts will work on 72 Rally Charger [Re: High Impact] #982811
04/29/11 11:04 PM
04/29/11 11:04 PM
IN
ahy Offline
ahy  Offline
IN
The engine would make a great core for a 451/496/512 stroker. The transmission would be a good core also. I believe the spindles/front brakes would swap although some would be concerned about the taller spindles vs original.
If you want AC and a high output alternator the 100 A "big case" alternator setup it probably has works great... just a bit heavy. If you aren't using AC there are lighter options.
I used the block from a '78 Cordoba for a 496 stroker in a Challenger. I also used the big alternator - after I found the small case wasn't enough for my application.
Re: 77 Cordoba,How many parts will work on 72 Rally Charger [Re: High Impact] #982812
04/29/11 11:22 PM
04/29/11 11:22 PM
Iowa State fan
kilroy Offline
kilroy  Offline
Iowa State fan
Thanks,Dave-
most all of it! Its a B-body too. DO IT! My charger is filled with 76 monoca cop car parts! Bonus is the disk brakes are the 11.75 units good stuff. Rear sway bar will bolt up and work good.
1973 Charger, former SE, former auto
I'm not trying to be difficult, it comes naturally....
Re: 77 Cordoba,How many parts will work on 72 Rally Charger [Re: High Impact] #982813
04/30/11 11:12 AM
04/30/11 11:12 AM
US of A
A38s! Offline
A38s!  Offline
US of A
Don't toss some stuff because it won't fit a 72. I stash 360/4 parts these days.
WANTED: Your 71-78 Late B-body sedan parts! Police or Civilian.
Re: 77 Cordoba,How many parts will work on 72 Rally Charger [Re: kilroy] #982814
04/30/11 11:33 AM
04/30/11 11:33 AM
Glendale, AZ
69L78Nova Offline
Banned. Forever.
69L78Nova  Offline
Banned. Forever.
Glendale, AZ
A 76 Monaco is a C-body. It would either be a 75-76 Coronet, or 77-78 Monaco
1969 Nova
454/M21/3.31
Mild mid-11 second weekend cruiser
1994 F150 XLT Super Cab 2WD
5.0/4R70W/3.55
(Daily driver)
Re: 77 Cordoba,How many parts will work on 72 Rally Charger [Re: kilroy] #982815
04/30/11 11:52 AM
04/30/11 11:52 AM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
not really. 73 and lates B bodies are a diff story, from 71/72s.
Re: 77 Cordoba,How many parts will work on 72 Rally Charger [Re: High Impact] #982816
04/30/11 04:44 PM
04/30/11 04:44 PM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
I know the ash tray is the same, even same part#.
Glove box liner I think is the same, these are some of the parts i used in my '71 Charger.
Re: 77 Cordoba,How many parts will work on 72 Rally Charger [Re: 451Mopar] #982817
04/30/11 07:08 PM
04/30/11 07:08 PM
Manistee, Michigan.
Manistee, Michigan.
Its a running driving car that needs some attention but could be driven as is. He wants to trade me a 454 thats been sitting on a shelf in my shop for it. I probably should........its just that the motor takes up alot less room than ANOTHER car.
I thought the bucket seats were the same but Im not sure. My 72 car was missing the correct seats.
Would the disk brakes work on my 1967 Sport Fury? Or, My 68 Charger? Everything else I have already has disks.
How about the rear sway bar?
I know it has the fancy chrome road wheels for that era car and there complete and shine really nice yet.........Thats a bonus!
Just curious what you guys thought
Re: 77 Cordoba,How many parts will work on 72 Rally Charger [Re: 69L78Nova] #982818
04/30/11 09:51 PM
04/30/11 09:51 PM
Iowa State fan
kilroy Offline
kilroy  Offline
Iowa State fan
probably is a 77 it has double square lights.
Re: 77 Cordoba,How many parts will work on 72 Rally Charger [Re: NachoRT74] #982819
04/30/11 09:53 PM
04/30/11 09:53 PM
Iowa State fan
kilroy Offline
kilroy  Offline
Iowa State fan
only real diff is front k-frame mounting from 72 to 73. but even the part on k frame will work.
Re: 77 Cordoba,How many parts will work on 72 Rally Charger [Re: kilroy] #982820
05/01/11 01:31 PM
05/01/11 01:31 PM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
false!
inner fenders are totally diff, radiator core support, frame rails are diff too. NOTHING of the front clip unibody will interchange correctly, K member and suspension won't interchange.
Actually even the firewall COULD fit, the 77 bulkhead opening is diff.
between 72 and 73 Chargers, the floor pans fit up to trunk, dutchman panel, roof, glasses, cowl, Hoods, trunk lid ALTHOUGH cilinder will need to keep matching the correct lid year because that changed too between 72 and 73. Rear valance will fit BUT bumper guards cut outs changes. Front valance fits but you can tell diff on inner areas and brackets to frame rails. Fenders fits BUT inside you can tell areas won't match, ( will find BIG diff unmatched areas with radiator core support ) and won't be able to fit correct wheel op molds.
Wiring will be a perfect match between a 72 and a 73 with just some wires turned around at bulkhead easy to match, but thing are diff with 74s and EVEN MORE DIFF with laters.
Doors won't, quarters won't, quarter glass won't...
Dash frame will interchange as complete assembly with a 77 BUT dunno if clusters can be interchanged, I don't think so. Glove box and ashtray parts will.
etc...
Re: 77 Cordoba,How many parts will work on 72 Rally Charger [Re: NachoRT74] #982821
05/01/11 06:27 PM
05/01/11 06:27 PM
KS
68SportSatvert Offline
KS
The brakes will work and they whould have the 11.75" rotors. Thw spindles are the taller ones but will work fine. PM me if you don't want them...
Re: 77 Cordoba,How many parts will work on 72 Rally Charger [Re: NachoRT74] #982822
05/01/11 09:38 PM
05/01/11 09:38 PM
Iowa State fan
kilroy Offline
kilroy  Offline
Iowa State fan
... quarter glass won't...
etc...
To cloud this discussion more and make it more confusing. I have some 71 quarter glass in mine right now, and regulators, fits perfect.
Re: 77 Cordoba,How many parts will work on 72 Rally Charger [Re: kilroy] #982823
05/01/11 11:38 PM
05/01/11 11:38 PM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
which kind ? the full glass kind or the one mounted on pot metal frame ?
Not saying won't fit, since bolting locations are the same BUT if you see a 73/74 glass they are bigger. 71/72s are a little bit smaller so adjusting on C area could be some "tight" into the opening area once aligned with doors. Also teh vertical seal and molding is shorter on 71/72s than 73/74s
Re: 77 Cordoba,How many parts will work on 72 Rally Charger [Re: NachoRT74] #982824
05/03/11 01:27 AM
05/03/11 01:27 AM
murfreesboro, TN
Q
Qbird Offline
Qbird  Offline
Q
murfreesboro, TN
73/74 charger roof is actually 71/72 Satellite disguised by trim.
Re: 77 Cordoba,How many parts will work on 72 Rally Charger [Re: Qbird] #982825
05/03/11 03:28 AM
05/03/11 03:28 AM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
actually roof itself is the same between Plymouth and Dodges on those years ( 71/74 2 doors B bodies ) since the quarter window opening shape is not on roof, its on quarter panel
however the CHARGER glass, its diff between 71/72 and 73/74 ( as stated not saying won't fit somehow )... 71/72 Plymouth, yes is the same than 73/74 Charger, so does the opening shape
