HONING WITH TRQ PlATES OVER RATED? #981453
04/27/11 03:00 PM
04/27/11 03:00 PM
junction city oregon
V
viperblue72 Offline OP
V
How many of you do or don't hone with torque plates and what's your experiences? I noiced one of the engine masters engines mentioned not bothering with it. I'm guessing it all depends on how rigid the cylinder walls are? Has anybody ever measured the cylinder walls with then without the deck plate to see if there's distortion and how much. My guess is that maybe there's a little power to be had there but maybe not.
Re: HONING WITH TRQ PlATES OVER RATED? [Re: viperblue72] #981454
04/27/11 03:03 PM
04/27/11 03:03 PM
Guitar Jones Offline
It was worth .7 on my buddys V6 stocker.
Re: HONING WITH TRQ PlATES OVER RATED? [Re: viperblue72] #981455
04/27/11 03:13 PM
04/27/11 03:13 PM
Az
Crizila Offline
Crizila  Offline
Az
Fastest 300
Re: HONING WITH TRQ PlATES OVER RATED? [Re: Guitar Jones] #981456
04/27/11 03:29 PM
04/27/11 03:29 PM
Taxes & Virus's R-US, NY
Dragula Online content
Dragula  Online Content
It's a must do...
Re: HONING WITH TRQ PlATES OVER RATED? [Re: Guitar Jones] #981457
04/27/11 03:29 PM
04/27/11 03:29 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Details?
Re: HONING WITH TRQ PlATES OVER RATED? [Re: Guitar Jones] #981458
04/27/11 03:32 PM
04/27/11 03:32 PM
mogadore ohio 44260
racingblues1426 Offline
mogadore ohio 44260
Did you mean .07 or .7 as almost 1 tenth???
Re: HONING WITH TRQ PlATES OVER RATED? [Re: racingblues1426] #981459
04/27/11 03:36 PM
04/27/11 03:36 PM
NE Oklahoma
V
Von Offline
Von  Offline
V
NE Oklahoma
My machinist told me that BB Mopes usually distort quite a bit...He told me how much the block he just machined for me (400) distorted, but cant remember the exact specs. Sounded like a pretty good amount.
72 RR, Pump gas 440, 452s, 3800 lbs, Corked, ET Radials,. 11.33@117.72. Same car, bone stock 346s, 9.5 comp, baby solid. 12.24@110.
Re: HONING WITH TRQ PlATES OVER RATED? [Re: John_Kunkel] #981460
04/27/11 03:41 PM
04/27/11 03:41 PM
Details?
I mean 7 tenths. 3.9 V6 in a Dakota. Same exact specs, cam, heads, intake everything except the shortblocks. The first one was not honed with a plate. The second one was and it picked up 7 tenths and became incredibly consistent where before it wasn't. YMMV
Re: HONING WITH TRQ PlATES OVER RATED? [Re: viperblue72] #981461
04/27/11 03:57 PM
04/27/11 03:57 PM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
back in the day 1993 ish I was building a new motor and my machinist was going to use a torque plate. he showed me the cylinder bores perfectly round and hone ran smooth. Then he bolted the torque plate on to simulate the head being torqued and re measured and dam it distorted the cylinders a lot (pushed into the bore at each bolt hole!) then he ran the hone and it was rough he said you have to take the high spots down.
I wonder how much less studs distort the bores?
Re: HONING WITH TRQ PlATES OVER RATED? [Re: Dodgem] #981462
04/27/11 04:01 PM
04/27/11 04:01 PM
V
V
Wow! Good to know some real world examples. Seems like it would be even better to heat the block to operating temperature and torque plate hone. Well it looks like I won't be skipping that procedure. Thanks guys.
Re: HONING WITH TRQ PlATES OVER RATED? [Re: Dodgem] #981463
04/27/11 04:05 PM
04/27/11 04:05 PM
Oklahoma
hemiiroc Offline
hemiiroc  Offline
Oklahoma
All the ones i've done pull the cylinder in at the bolt holes..it usually takes .002-.003 to take the distortion out
Re: HONING WITH TRQ PlATES OVER RATED? [Re: viperblue72] #981464
04/27/11 04:05 PM
04/27/11 04:05 PM
organ
maximum entropy Offline
organ
take perfectly round cylinders, attach a deck plate, and remeasure. you will be amazed.
Re: HONING WITH TRQ PlATES OVER RATED? [Re: viperblue72] #981465
04/27/11 04:06 PM
04/27/11 04:06 PM
IN
Irun5snd8th Offline
Irun5snd8th  Offline
IN
Its worth mentioning that the heads are not the only thing that can distort it, albeit they do the most. Many engine shops will have you bolt as much of your setup on the block as you can including engine mounts and whatnot.
AFCO, Rons Fuel Injection sponsored Dodge Challenger Mention Street Lethal Motorsports
Re: HONING WITH TRQ PlATES OVER RATED? [Re: viperblue72] #981466
04/27/11 04:08 PM
04/27/11 04:08 PM
AndyF Offline
AndyF  Offline
Depends on the engine block. Some engines need torque plates and some don't. It is a good idea for a Mopar big block or small block.
Re: HONING WITH TRQ PlATES OVER RATED? [Re: viperblue72] #981467
04/27/11 04:18 PM
04/27/11 04:18 PM
organ
organ
did they win?
Re: HONING WITH TRQ PlATES OVER RATED? [Re: viperblue72] #981468
04/27/11 04:27 PM
04/27/11 04:27 PM
Locomotion Online content
Locomotion  Online Content
Bottom line....better ring seal, longer life, more HP/torque. Some people go so far as to install a torque plate on each head, use the same style head gaskets as will be used on the final assembly, run warm water through the block, torque the main caps to spec.......every little bit helps. Diminishing returns, but returns none-the-less. (Certainly can't hurt!) It's just a matter of how much time & money you want to invest.
Re: HONING WITH TRQ PlATES OVER RATED? [Re: Locomotion] #981469
04/27/11 04:32 PM
04/27/11 04:32 PM
IN
Irun5snd8th Offline
Irun5snd8th  Offline
IN
As with all things stocker related, one single thing will not typically make a huge difference. Its the combined aggregate of all those things that results in a fast car
Re: HONING WITH TRQ PlATES OVER RATED? [Re: Irun5snd8th] #981470
04/27/11 04:49 PM
04/27/11 04:49 PM
V
V
Great information guys. I always know ill get well informed answers here.
Thanks again.
Re: HONING WITH TRQ PlATES OVER RATED? [Re: viperblue72] #981471
04/27/11 05:16 PM
04/27/11 05:16 PM
QLD Australia
Keith Black® Offline
QLD Australia
be interesting to know the with/without distortion on say, a block with liners and studs..
Darren Beale
Keith Black Racing Engines®
Re: HONING WITH TRQ PlATES OVER RATED? [Re: viperblue72] #981472
04/27/11 05:16 PM
04/27/11 05:16 PM
sweden
sshemi Offline
sshemi  Offline
sweden
If its a bb or hemi i would say yes, its worth it.
My last stock block hemi was very not striaght without torque plates.
Aldough on a sb im not so sure.
They seem to be straight with or without a plate.
