Horn No Worky #981406
04/27/11 12:56 PM
04/27/11 12:56 PM
Under My Car
Mopar_Country Offline OP
Under My Car
74 Dart Sport, I can't seem to get the horn to work and I have looked through the FSM and can't find any solutions in there. When I push the horn button I hear a relay of some kind clicking but no beep. I have checked at the wire with a test light and my kid pushing the button and I have no power there. Any suggestions on where to look would be greatly appreciated. Thanks
Re: Horn No Worky [Re: Mopar_Country] #981407
04/27/11 01:21 PM
04/27/11 01:21 PM
Poplar Bluff, Mo. 63901
2
268RTs4ME Offline
268RTs4ME  Offline
Take a hot wire off your battery,and touch it to horn ,and see if your horn honks.If not bad horn, Check fuse and see if you have current to horn relay, all you do at steering wheel is ground when u push horn ring.
Re: Horn No Worky [Re: 268RTs4ME] #981408
04/27/11 01:55 PM
04/27/11 01:55 PM
Under My Car
Under My Car
When pushing the horn button shouldn't my test light, light?
Re: Horn No Worky [Re: Mopar_Country] #981409
04/27/11 02:00 PM
04/27/11 02:00 PM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
horn button drives negative and closes the relay circuit to send positive.
If you heard the click it looks relay is working.
wire what feeds horns is green traced red, search for that wire on back of bulkhead and check for power there when pressing horn
Re: Horn No Worky [Re: NachoRT74] #981410
04/27/11 02:03 PM
04/27/11 02:03 PM
Under My Car
Under My Car
OK, I'll do that here shortly. I also have a line toner I'm going to hook up at the horn and tone it back to see if I have a break in the wire somewhere.
Re: Horn No Worky [Re: Mopar_Country] #981411
04/27/11 03:03 PM
04/27/11 03:03 PM
Under My Car
Under My Car
Horn doesn't work so I will replace it. But I still get no power to wire, should I?
Re: Horn No Worky [Re: Mopar_Country] #981412
04/27/11 03:22 PM
04/27/11 03:22 PM
2
268RTs4ME Offline
268RTs4ME  Offline
Stick your test light in wire that plugs on horn and have someone push horn, u should have current to wire that plugs on horn,,, Also make sure your horn has a good ground>>>>>
Re: Horn No Worky [Re: 268RTs4ME] #981413
04/27/11 04:07 PM
04/27/11 04:07 PM
Under My Car
Under My Car
Replaced the horn with a working unit, still no beep beep. Test light hooked to wire, push button, nothing.
Re: Horn No Worky [Re: Mopar_Country] #981414
04/27/11 07:45 PM
04/27/11 07:45 PM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
well, check directly at relay. Dunno remmeber if 74s are attached to glovebox liner provision ( I know 75/76s are ) or still at driver side kick panel area close to dash frame
same color wire, green traced red. The other wires must be black coming from horn switch ( ground switch ) and violet, full batt source.
Re: Horn No Worky [Re: NachoRT74] #981415
04/27/11 08:19 PM
04/27/11 08:19 PM
Under My Car
Under My Car
The relay is clipped to the fuse box on the driver side kick panel. I'll check the green with red coming off the relay.
Re: Horn No Worky [Re: NachoRT74] #981416
04/27/11 09:51 PM
04/27/11 09:51 PM
Colorado
denfireguy Offline
denfireguy  Offline
Colorado
If there is a break in the wire inside the relay, it will click but will not supply power to the horn. Clicking shows that ground circuit to the horn button is working but I beleive the relay itself has an open inside.
Yes your light should light when the button is pushed but since the relay is not feeding the wire, it is not lighting.
Craig
