Re: Horn No Worky
[Re: Mopar_Country]
#981407
04/27/11 01:21 PM
04/27/11 01:21 PM
Posts: 938 Poplar Bluff, Mo. 63901
268RTs4ME
Take a hot wire off your battery,and touch it to horn ,and see if your horn honks.If not bad horn, Check fuse and see if you have current to horn relay, all you do at steering wheel is ground when u push horn ring.
Re: Horn No Worky
[Re: Mopar_Country]
#981409
04/27/11 02:00 PM
04/27/11 02:00 PM
Posts: 6,096 Valencia, España
NachoRT74
Valencia, España
horn button drives negative and closes the relay circuit to send positive.
If you heard the click it looks relay is working.
wire what feeds horns is green traced red, search for that wire on back of bulkhead and check for power there when pressing horn
Re: Horn No Worky
[Re: Mopar_Country]
#981412
04/27/11 03:22 PM
04/27/11 03:22 PM
268RTs4ME
Stick your test light in wire that plugs on horn and have someone push horn, u should have current to wire that plugs on horn,,, Also make sure your horn has a good ground>>>>>
Re: Horn No Worky
[Re: Mopar_Country]
#981414
04/27/11 07:45 PM
04/27/11 07:45 PM
NachoRT74
Valencia, España
well, check directly at relay. Dunno remmeber if 74s are attached to glovebox liner provision ( I know 75/76s are ) or still at driver side kick panel area close to dash frame
same color wire, green traced red. The other wires must be black coming from horn switch ( ground switch ) and violet, full batt source.
Re: Horn No Worky
[Re: NachoRT74]
#981416
04/27/11 09:51 PM
04/27/11 09:51 PM
Posts: 1,822 Colorado
denfireguy
Colorado
If there is a break in the wire inside the relay, it will click but will not supply power to the horn. Clicking shows that ground circuit to the horn button is working but I beleive the relay itself has an open inside. Yes your light should light when the button is pushed but since the relay is not feeding the wire, it is not lighting. Craig
2014 Ram 1500 Laramie, 73 Cuda Previous mopars: 62 Valiant, 65 Fury III, 68 Fury III, 72 Satellite, 74 Satellite, 89 Acclaim, 98 Caravan, 2003 Durango Only previous Non-Mopar: Schwinn Tornado
