Yesterday while driving home my truck (79 W150) sputtered and died, and would not fire back up. Being 2 blocks from the house I strapped it to my friends car and pulled it to the house.
Fuel is coming out of the carburetor just fine, but I am getting no spark. I have replace the cap and rotor, and swapped to a different coil to no avail. I have 12v on the + side of the coil, 12v on the end of the coil plug wire. Pulled the distributor, and everything seems fine with it.
Could the ignition module cause this issue? Is there anything else I can test with the voltmeter to determine what needs replaced?
