Re: Compression Ring, which is what?
[Re: Bill MeLater]
#979433
04/28/11 05:59 PM
04/28/11 05:59 PM
Posts: 151 Northern Virginia
barracuda7
Northern Virginia
If they didn't come with an "Instruction" sheet, simply go to their website. Get it wrong and you will regret it...
I found the little Dot marked on rings. I have another question
What exactly happens if you mix up the compression rings? I mean the 1st ring go to second groove and 2nd ring go to top groove(Assume both ring have right direction but wrong position-Dot marked and the Dot toward the top of piston)
Have anyone tried this with their Toy see what happen?
Or anyone know Piston Rings structure, can you explain what will happen if we mix up those compress rings?
[Re: barracuda7]
#979434
04/28/11 07:53 PM
04/28/11 07:53 PM
Posts: 4,950 WI
Dcuda69
WI
I bought Piston Rings Set for my 383. There are two 5/64 Compression Ring, they look exactly the same. How do I know which one go on Top or it does not matter? Thanks a lot!
Here the pics:
If that's the box they came in....the flaps on the box should be labeled top ring/second ring,etc. but now you took them out so...refer to previous posts
[Re: barracuda7]
#979435
04/29/11 10:42 AM
04/29/11 10:42 AM
Posts: 75,043 U.S.S.A.
JohnRR
U.S.S.A.
You don't want to swap the top and second rings , not sure if it's ok to do something like that with a cheap set of cast rings , but the other ring sets , moly , ductile , etc , the top ring is many times a different material and the shape of it may be somewhat different.
[Re: barracuda7]
#979438
04/29/11 09:21 PM
04/29/11 09:21 PM
Posts: 12,675 Columbia, CT
moper
Columbia, CT
the ring design is not the same for top and 2nd rings. The second ring is not a compression ring and is not shaped to seal well. It's an oil scraper. IIRC, the top ring will not have a bevel at all, just a dot or mark. the second ring will have a bevel and may not have a dot at all.
[Re: moper]
#979439
04/30/11 12:36 AM
04/30/11 12:36 AM
Posts: 301 California
court9155
California
Its hit and miss but bevel up if no ID dot and ductile or moly etc all have noticeably different top rings.
Id bet you can get away with using a 2nd ring in the top on what appear to be cheap cast 5/64 rings you have there.
Look close I bet they arent even beveled, as referenced in almost all ring manufacturers destructions.
67 charger
[Re: court9155]
#979440
04/30/11 02:16 AM
04/30/11 02:16 AM
Posts: 12,216 NO RUST IN AZ!!!
azmopar
NO RUST IN AZ!!!
aasahhhhh my old employer Sealed Power. the PIP always goes UP. dont mix the rings the reverse twist will break the ring in short order. (i worked for them for 20 yrs)
70 Challenger Convertible 340 six pak CLONE? 70 Duster real FM3 car 65 Dart Charger FOR SALE
#NONIKESEVER
A Real man aint afraid to drive PINK!!!!
67 Plymouth Valiant PILOT CAR 273 Commando 4 spd
