727 small block trans shield recommendations? #978048
04/22/11 01:32 PM
04/22/11 01:32 PM
Beavercreek, Ohio
OA5599 Offline OP
OA5599  Offline OP
Beavercreek, Ohio
After reading a post from a few days ago, I'm spooked about putting our new 550 hp stroker in without a transmissin shield. Can anyone recommend one for a '69 Cuda that will fit well and protect my limbs?
Re: 727 small block trans shield recommendations? [Re: OA5599] #978049
04/22/11 03:49 PM
04/22/11 03:49 PM
Missouri
StrokerPost Offline
StrokerPost  Offline
Missouri
CSR are probably gonna be the better fitting, at least of the ones I know of. This pic is a BB version, but its the same deal. You may have to do a teeny bit of trimming to make it fit, but very little. My .
http://www.jegs.com/webapp/wcs/stores/se...amp;showValue=1
Re: 727 small block trans shield recommendations? [Re: StrokerPost] #978050
04/22/11 05:02 PM
04/22/11 05:02 PM
aotearoa
rebel Offline
rebel  Offline
aotearoa
a little bit of work to fold the firewall pinchweld lip & maybe a slight bit of trans tunnel hammering where it reduces down in size but without doubt, the CSR is the best fit.
Re: 727 small block trans shield recommendations? [Re: rebel] #978051
04/22/11 11:16 PM
04/22/11 11:16 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
Another issue to watch for is header clearance. Mine don't leave enough room between to my 727 and the collector.
Doug
