New lifters and old cam?
#975405
04/18/11 01:00 AM
04/18/11 01:00 AM
Posts: 456 Santa Barbara, CA
HitIt
Santa Barbara, CA
Hi all- I've got a couple hydraulic lifters in my 440 that don't seem to pump up as well as others resluting in some play in the rocker.
What is the thought on replacing lifters only and not the cam? Is this done without issues? Do I need to break the lifters in in any particular way?
Cam is a basic 488 lift made by Elgin.
Thanks!
very clever dinner. appetizing food fit neatly into interesting round pie.
Re: New litters and old cam?
[Re: HitIt]
#975406
04/18/11 01:25 AM
04/18/11 01:25 AM
Posts: 9,826 las vegas
70AARcuda
las vegas
no problem with new lifters on old cam..
just went you start the engine...you need to break in cam again...
Tony
70 AARCuda Vitamin C 71 Dart Swinger 360 10.318 @ 128.22(10-04-14 Bakersfield) 71 Demon 360 10.666 @122.41 (01-29-17 @ Las Vegas) 71 Duster 408 (10.29 @ 127.86 3/16/19 Las Vegas)
[Re: 70AARcuda]
#975407
04/18/11 03:05 PM
04/18/11 03:05 PM
Posts: 18,493 Granite Bay CA
Kern Dog
Striving for excellence
Granite Bay CA
Well... technically you are mating the new lifters to the old cam. One thing to consider: What caused the lifters to degrade? You might want to measure the lobes from the bad lifters to ensure that they match the other lobes. If there is ANY sign of heavy wear, replace the cam. Once the surface hardness starts to wear away, cams will fail quickly.
[Re: Kern Dog]
#975408
04/18/11 11:37 PM
04/18/11 11:37 PM
HitIt
Santa Barbara, CA
Thanks for the info guys. The lifters in question seem spongy like they have a 1/4" of movement in the hydraulic mechanism if that makes sense. Does that still seem like the cam could be bad or more likely a bad lifter? I completely understand the reason behind measuring the cam just wondering if I'm on the right track with the bad lifter idea. Thanks!
[Re: 70AARcuda]
#975411
04/19/11 12:42 AM
04/19/11 12:42 AM
Posts: 3,698 NE Oklahoma
Von
NE Oklahoma
I have one solid cam that has had 4 sets of lifters on it over the years. No problems....
72 RR, Pump gas 440, 452s, 3800 lbs, Corked, ET Radials,. 11.33@117.72.
Same car, bone stock 346s, 9.5 comp, baby solid. 12.24@110.
[Re: Kern Dog]
#975414
04/19/11 05:40 PM
04/19/11 05:40 PM
HitIt
Santa Barbara, CA
Thanks for that info. I am definitely going to inspect the surfaces soon, and even measure the lift between the valves to see if one of the cam lobes is 'different'.
