Page 1 of 5 1 2 3 4 5
Pinion Angle - here we go.... #973465
04/14/11 11:59 PM
04/14/11 11:59 PM
Worst Weather USA
493_DART Offline OP
493_DART  Offline OP
Worst Weather USA
I find this confusing because there are 8 different methods/opinions on the subject .
SO--lets try a new approach. Im going to post my measurements and lets see if everyone comes up with the same number in the end .
Here we go:
d-shaft at rear angle 86 degrees (4 ? ) DOWN measured on bottom of shaft. D shaft is pointed down at rear.
pinion flange 81 degrees (9 ? ) DOWN vertically measured . pinion is pointing down .
trans seal - measured vertically 88 degrees (2?) UP .
pinion yoke (u joint cap) 5 degrees DOWN
so ... what is my pinion angle ?
Re: Pinion Angle - here we go.... [Re: 493_DART] #973466
04/15/11 12:06 AM
04/15/11 12:06 AM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
Blue....
Re: Pinion Angle - here we go.... [Re: 493_DART] #973467
04/15/11 12:18 AM
04/15/11 12:18 AM
MR_P_BODY Offline
MR_P_BODY  Offline
You should state weather the ? are pointed up or down
Re: Pinion Angle - here we go.... [Re: 493_DART] #973468
04/15/11 12:22 AM
04/15/11 12:22 AM
Carson City, Nevada
Biginchmopar Offline
Carson City, Nevada
Well, I hate to tell you this but lets start over.
1.) Get the car up in the air with the car supported on the rear axle and the front supported around the front suspention.
2.) Take the driveline off the pinion yoke.
3.) Measure the angle on the pinion yoke were the caps bolt to.
4.) This should give you a measurement with the needle on one side of 90* towards the front of the car or towards the back of the car. Record it.
5.) Put the driveline back on
6.) Now put the tool on the bottom of the driveline and take another measurement. Again it should be on one side or the other of the 90* mark toward the front or back of the car. Record it.
7.) Now that all that is done if one measurement is 4* toward the back and the other is 2* toward the front your pinion angle would be 6*.
8.) If they are both the same way (toward the back) 4* and 2* then your pinion angle is 2*.
Hope all this helps!
Re: Pinion Angle - here we go.... [Re: Biginchmopar] #973469
04/15/11 12:24 AM
04/15/11 12:24 AM
Carson City, Nevada
Carson City, Nevada
Al,
You make me laugh!!!
RED!
Re: Pinion Angle - here we go.... [Re: MR_P_BODY] #973470
04/15/11 12:26 AM
04/15/11 12:26 AM
St. Paul , Mn.
tubtar Offline
tubtar  Offline
St. Paul , Mn.
Fear wasn't enough to keep me from clicking on this.
I wish I could help , but I am struggling to decipher your angles and how they relate to flat level ground.
There seems to be an information overload.
You can get the pinion angle from the tail shaft and pinion yoke angles alone..........yes ?
Or maybe I am more confused than you are.
Re: Pinion Angle - here we go.... [Re: MR_P_BODY] #973471
04/15/11 12:27 AM
04/15/11 12:27 AM
Canton, Ohio
Sport440 Offline
Sport440  Offline
Canton, Ohio
As Stated, you have 275* of Pinion Angle all added up.
I can state without a doubt! That you do have some pinion angle!
Re: Pinion Angle - here we go.... [Re: Sport440] #973472
04/15/11 12:30 AM
04/15/11 12:30 AM
Carson City, Nevada
Carson City, Nevada
GREEN!....
Re: Pinion Angle - here we go.... [Re: tubtar] #973473
04/15/11 12:35 AM
04/15/11 12:35 AM
MR_P_BODY Offline
MR_P_BODY  Offline
2 theories ... one uses pinion and trans the other
uses pinion and drive shaft... now days I just ask
which answer would you like... I dont care to get
into all the BS... I happen to use the drive shaft
but when I built the car I put the trans on centerline
with the pinion
Re: Pinion Angle - here we go.... [Re: MR_P_BODY] #973474
04/15/11 01:25 AM
04/15/11 01:25 AM
Worst Weather USA
493_DART Offline OP
493_DART  Offline OP
Worst Weather USA
everything would be down angles relative to the floor
the pinion is pointed down
the rear of the d sfaft is pointed down
except the trans tail--i think it was up
Re: Pinion Angle - here we go.... [Re: Biginchmopar] #973475
04/15/11 02:09 AM
04/15/11 02:09 AM
Worst Weather USA
493_DART Offline OP
493_DART  Offline OP
Worst Weather USA
ok on the rear yoke its 80 needle pointing to the rear
on the D-shaft its 86 needle pointed to the front of car
this is with the car on the ground -- weight in the seat. Thats how "most" of the people say to measure.
Re: Pinion Angle - here we go.... [Re: tubtar] #973476
04/15/11 03:26 AM
04/15/11 03:26 AM
Worst Weather USA
493_DART Offline OP
493_DART  Offline OP
Worst Weather USA
yep-im confused -with 5 or more methods out there..
This is with me laying under the drivers side --------looks like i have pinion yoke angle at 10 degrees - the diff is REALLY pointed down at a pretty good angle.
and d-shaft angle 4 degrees --looking at it , the shaft is definitely pointing DOWN .
there is basically a V shape where the shaft meets the diff. Does this make sense ?
the reason i used the 81 or 86 numbers is the gauge only has a magnet on one side---or i could only use the gauge a certain way -- SO , 90 degrees on the gauge would be ZERO .
Re: Pinion Angle - here we go.... [Re: 493_DART] #973477
04/15/11 05:59 AM
04/15/11 05:59 AM
U.S.
moparniac Offline
moparniac  Offline
U.S.
(you can go off the balancer if you can get on it for this measurement also)
-3
Mopar Performance
Re: Pinion Angle - here we go.... [Re: 493_DART] #973478
04/15/11 08:13 AM
04/15/11 08:13 AM
somwhere
smokinwoody Offline
smokinwoody  Offline
somwhere
HOLY SMOKERS..BATMAN...
Im spittin coffee everywhere reading this one...scratch my head violently...
if you're on leaf springs, I put my pinion angle down 3*...thats it...
now I probably realy started something...
Re: Pinion Angle - here we go.... [Re: smokinwoody] #973479
04/15/11 09:42 AM
04/15/11 09:42 AM
PA
moparacer Offline
moparacer  Offline
PA
Just do it according to the chart on Rosslers sight....
Been setting pinion angle up like that for 20+ years and never had a drive line failure.
Or even a vibration for that matter...
67 Barracuda street/bracket car 11.27-119
68 Dart 502 BB 8.70s-152
414 cid SB Dragster 7.65-174
Re: Pinion Angle - here we go.... [Re: Biginchmopar] #973480
04/15/11 11:03 AM
04/15/11 11:03 AM
Az
Crizila Offline
Crizila  Offline
Az
Great explaination. Rates right up there with the best.
Fastest 300
Re: Pinion Angle - here we go.... [Re: 493_DART] #973481
04/15/11 01:14 PM
04/15/11 01:14 PM
Carson City, Nevada
Carson City, Nevada
With this info I would say your pinion angle is 14*
Your info says to me that the pinion yoke is down 10* and you driveshaft angle is down 4*
Re: Pinion Angle - here we go.... [Re: 493_DART] #973482
04/15/11 01:26 PM
04/15/11 01:26 PM
Grand Haven, MI
patrick Offline
patrick  Offline
Grand Haven, MI
Here we go:
trans seal 88, so it's 2 degrees up. for 0 pinion angle, the pinion yoke measurement would need to be 2 degrees down.
all the other measurements are given are irrelevant. since your pinion is rotated another 3 degrees nose down from 0, you're at 3 degrees nose down.
2017 Grand Cherokee Overland
Re: Pinion Angle - here we go.... [Re: moparniac] #973483
04/15/11 01:28 PM
04/15/11 01:28 PM
Carson City, Nevada
Carson City, Nevada
-3
I would say 7* pinion angle. This is why if your transmission was 0* just for sake of trying to make things easy, then you raise the trans 2* you have added angle if you lower it 2* you would have 3* pinion angle. This is why I always use the drive shaft and the pinion yoke, the math is easier.
Re: Pinion Angle - here we go.... [Re: Biginchmopar] #973484
04/15/11 02:03 PM
04/15/11 02:03 PM
Grand Haven, MI
patrick Offline
patrick  Offline
Grand Haven, MI
-3
bzzzt! do not pass go, do not collect $200.
pinion angle is the angle of the tranny output shaft relative to the pinion shaft. if the tranny is 0, to have 0 pinion angle, the pinion has to be 0. if the tranny is 2 deg. nose up (higher in rear than front), the pinion has to be 2 degrees nose down (higher in the rear than the front) for pinion angle. his pinion shaft is 3 degrees nose down more than the 0 point, so -3 (3 degrees nose down) is correct
