Pinion Angle - here we go....
#973465
04/14/11 11:59 PM
04/14/11 11:59 PM
Posts: 4,384 Worst Weather USA
493_DART
Worst Weather USA
I find this confusing because there are 8 different methods/opinions on the subject .
SO--lets try a new approach. Im going to post my measurements and lets see if everyone comes up with the same number in the end .
Here we go:
d-shaft at rear angle 86 degrees (4 ? ) DOWN measured on bottom of shaft. D shaft is pointed down at rear.
pinion flange 81 degrees (9 ? ) DOWN vertically measured . pinion is pointing down .
trans seal - measured vertically 88 degrees (2?) UP .
pinion yoke (u joint cap) 5 degrees DOWN
so ... what is my pinion angle ?
Re: Pinion Angle - here we go....
[Re: 493_DART]
#973468
04/15/11 12:22 AM
04/15/11 12:22 AM
Posts: 1,397 Carson City, Nevada
Biginchmopar
Carson City, Nevada
Well, I hate to tell you this but lets start over. 1.) Get the car up in the air with the car supported on the rear axle and the front supported around the front suspention. 2.) Take the driveline off the pinion yoke. 3.) Measure the angle on the pinion yoke were the caps bolt to. 4.) This should give you a measurement with the needle on one side of 90* towards the front of the car or towards the back of the car. Record it. 5.) Put the driveline back on 6.) Now put the tool on the bottom of the driveline and take another measurement. Again it should be on one side or the other of the 90* mark toward the front or back of the car. Record it. 7.) Now that all that is done if one measurement is 4* toward the back and the other is 2* toward the front your pinion angle would be 6*. 8.) If they are both the same way (toward the back) 4* and 2* then your pinion angle is 2*. Hope all this helps!
[Re: MR_P_BODY]
#973470
04/15/11 12:26 AM
04/15/11 12:26 AM
Posts: 3,082 St. Paul , Mn.
tubtar
St. Paul , Mn.
Fear wasn't enough to keep me from clicking on this. I wish I could help , but I am struggling to decipher your angles and how they relate to flat level ground. There seems to be an information overload. You can get the pinion angle from the tail shaft and pinion yoke angles alone..........yes ? Or maybe I am more confused than you are.
[Re: tubtar]
#973473
04/15/11 12:35 AM
04/15/11 12:35 AM
Posts: 52,972 Romeo MI
MR_P_BODY
2 theories ... one uses pinion and trans the other uses pinion and drive shaft... now days I just ask which answer would you like... I dont care to get into all the BS... I happen to use the drive shaft but when I built the car I put the trans on centerline with the pinion
[Re: Biginchmopar]
#973475
04/15/11 02:09 AM
04/15/11 02:09 AM
493_DART
Worst Weather USA
ok on the rear yoke its 80 needle pointing to the rear
on the D-shaft its 86 needle pointed to the front of car
this is with the car on the ground -- weight in the seat. Thats how "most" of the people say to measure.
[Re: tubtar]
#973476
04/15/11 03:26 AM
04/15/11 03:26 AM
493_DART
Worst Weather USA
yep-im confused -with 5 or more methods out there..
This is with me laying under the drivers side --------looks like i have pinion yoke angle at 10 degrees - the diff is REALLY pointed down at a pretty good angle.
and d-shaft angle 4 degrees --looking at it , the shaft is definitely pointing DOWN .
there is basically a V shape where the shaft meets the diff. Does this make sense ?
the reason i used the 81 or 86 numbers is the gauge only has a magnet on one side---or i could only use the gauge a certain way -- SO , 90 degrees on the gauge would be ZERO .
[Re: 493_DART]
#973477
04/15/11 05:59 AM
04/15/11 05:59 AM
Posts: 6,295 U.S.
moparniac
U.S.
trans seal - measured vertically 88 degrees (2?) UP . (you can go off the balancer if you can get on it for this measurement also)
-3
Mopar Performance
[Re: 493_DART]
#973478
04/15/11 08:13 AM
04/15/11 08:13 AM
Posts: 12,339 somwhere
smokinwoody
somwhere
HOLY SMOKERS..BATMAN... Im spittin coffee everywhere reading this one...scratch my head violently... if you're on leaf springs, I put my pinion angle down 3*...thats it... now I probably realy started something...
[Re: smokinwoody]
#973479
04/15/11 09:42 AM
04/15/11 09:42 AM
Posts: 2,494 PA
moparacer
PA
Just do it according to the chart on Rosslers sight....
Been setting pinion angle up like that for 20+ years and never had a drive line failure.
Or even a vibration for that matter...
67 Barracuda street/bracket car 11.27-119 68 Dart 502 BB 8.70s-152 414 cid SB Dragster 7.65-174
[Re: 493_DART]
#973481
04/15/11 01:14 PM
04/15/11 01:14 PM
Biginchmopar
Carson City, Nevada
With this info I would say your pinion angle is 14*
Your info says to me that the pinion yoke is down 10* and you driveshaft angle is down 4*
[Re: moparniac]
#973483
04/15/11 01:28 PM
04/15/11 01:28 PM
Biginchmopar
Carson City, Nevada
-3
I would say 7* pinion angle. This is why if your transmission was 0* just for sake of trying to make things easy, then you raise the trans 2* you have added angle if you lower it 2* you would have 3* pinion angle. This is why I always use the drive shaft and the pinion yoke, the math is easier.
[Re: Biginchmopar]
#973484
04/15/11 02:03 PM
04/15/11 02:03 PM
Posts: 16,123 Grand Haven, MI
patrick
Grand Haven, MI
-3
bzzzt! do not pass go, do not collect $200.
pinion angle is the angle of the tranny output shaft relative to the pinion shaft. if the tranny is 0, to have 0 pinion angle, the pinion has to be 0. if the tranny is 2 deg. nose up (higher in rear than front), the pinion has to be 2 degrees nose down (higher in the rear than the front) for pinion angle. his pinion shaft is 3 degrees nose down more than the 0 point, so -3 (3 degrees nose down) is correct
