Bellhousing Installation #973169
04/14/11 05:55 PM
04/14/11 05:55 PM
Washington
19cuda73 Offline OP
19cuda73  Offline OP
Washington
I wanted to move this to the restoration site. I was wondering how frequently the bellhousing alignment is an issue when installing the tranny on a small block.
My block doesn't seem to have these offset dowel pins mine are straight across from each other. Any info would be appreciated. Thanks
1966 Charger 383 4 speed (Black with Red interior)
1973 Cuda 340 4 speed (Lemontwist)
1972 Corvette
Re: Bellhousing Installation [Re: 19cuda73] #973170
04/14/11 05:58 PM
04/14/11 05:58 PM
Washington
19cuda73 Offline OP
19cuda73  Offline OP
Washington
here is a picture of my 340block, my dowel pins are straight across from each other.
1972 Corvette
Re: Bellhousing Installation [Re: 19cuda73] #973171
04/14/11 07:14 PM
04/14/11 07:14 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
That's because that illustration is of a BIG BLOCK/HEMI bellhousing flange.
But any bellhousing could be off , by how much ???
Re: Bellhousing Installation [Re: 19cuda73] #973172
04/14/11 07:23 PM
04/14/11 07:23 PM
Georgetown Ontario Canada
anlauto Offline
anlauto  Offline
If you're using a factory bell housing with factory dowel pins etc...I doubt you have to worry about any type of off-set ? At least I've never heard of that
CHECK OUT MY NEW WEB SITE !
Re: Bellhousing Installation [Re: anlauto] #973173
04/14/11 07:38 PM
04/14/11 07:38 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Not true , I have a factory 70 Bellhousing and it was pretty far off. Not many people check them because they think the factory machined it correctly
Re: Bellhousing Installation [Re: JohnRR] #973174
04/14/11 07:50 PM
04/14/11 07:50 PM
Washington
19cuda73 Offline OP
19cuda73  Offline OP
Washington
Thanks Guys I will find out tomorrow when I bolt up the tranny. I think its all good!!!
1972 Corvette
Re: Bellhousing Installation [Re: 19cuda73] #973175
04/14/11 11:32 PM
04/14/11 11:32 PM
Ohio
Dan Brewer Offline
Dan Brewer  Offline
Ohio
Why not check it? Easier than having a problem and having to take everything back apart.
Dan
A833 4-speeds, parts & services
http://www.brewersperformance.com/
Re: Bellhousing Installation [Re: Dan Brewer] #973176
04/15/11 08:57 AM
04/15/11 08:57 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Dan
Because people want the easy way out, just because you can force parts together doesn't mean they are correctly together.
Re: Bellhousing Installation [Re: JohnRR] #973177
04/15/11 12:58 PM
04/15/11 12:58 PM
Toronto, ON
ehbody Offline
ehbody  Offline
Toronto, ON
Yep, check it.
I had to put in offset dowels when I replace my incorrect bellhousing.
Made installing the transmission a little easier.
Shawn 70 AAR
Re: Bellhousing Installation [Re: anlauto] #973178
04/15/11 04:29 PM
04/15/11 04:29 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
The clutch housing was align bored at the same time the block mains were and that housing stayed with the block all through the build process.
Re: Bellhousing Installation [Re: John_Kunkel] #973179
04/15/11 04:57 PM
04/15/11 04:57 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
I never knew that. Now we have matching numbers bellhousings.
Re: Bellhousing Installation [Re: JohnRR] #973180
04/16/11 06:32 PM
04/16/11 06:32 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
In the pic below you can see some engines being assembled with the bellhousing installed and some not. (the "not" being destined for slush boxes)
Re: Bellhousing Installation [Re: John_Kunkel] #973181
04/17/11 12:46 AM
04/17/11 12:46 AM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
kinda wish you could go back in time and get a few of those engines.
Re: Bellhousing Installation [Re: John_Kunkel] #973182
04/17/11 11:21 AM
04/17/11 11:21 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
So how did they make sure an auto trans was centered , or is that the reason for the flexplate ???
So the question to the OP is ... ORIGINAL bellhousing to that engine ?
Re: Bellhousing Installation [Re: JohnRR] #973183
04/18/11 07:16 AM
04/18/11 07:16 AM
Switzerland, Europe
Swiss_Robert Offline
Switzerland, Europe
Just my humble -story.
I have a big block - but however: I had to replace the cracked bellhousing and got one alu bellhousing from brewers.
Decided to check it (as brewers recommend) as showed in the manual - and it was inside tolerance (radial and axial), so no offside dowels necessary.
After all these years having a 440 I realized that this means having an attitude... and a budget.
Re: Bellhousing Installation [Re: anlauto] #973184
04/25/11 02:29 PM
04/25/11 02:29 PM
Moved to N.E. Tennessee
GomangoCuda Offline
GomangoCuda  Offline
Note that the original posting above shows a page from the Factory Service Manual that clearly explains how to check and correct misalignment so apparently the factory recognised an issue here.
If anybody checks theirs and decides to get offset dowels these are absolutely the ones you want. http://www.robbmcperformance.com/products/dowels.html
Everybody elses are sized for Ford engines and fit way too tight.
Re: Bellhousing Installation [Re: GomangoCuda] #973185
04/26/11 02:08 PM
04/26/11 02:08 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Exactly , Ford dowel is .500 , Mopar dowel is .496 , the dowels sold by Lakewood and such are .500 FORD dowels marketed as Mopar/Ford dowels. At least 1 member cracked his block installed the Lakewood dowel.
