65 Coronet 318 poly 4 speed conversion #970705
04/10/11 08:01 PM
04/10/11 08:01 PM
Minnesota
peabodyracing Offline OP
Minnesota
I've been lining up parts to switch my 318 3 speed manual 65 Coronet wagon over to a 4 speed. Started thinking this weekend that the bolt pattern is different for 3 speed vs 4 speed and I don't know if that vintage bell housing is drilled for both.
I'm using an early 4 speed so driveshaft and input shaft bearing retainer should be ok. The car is still buried for winter storage, and trying to look at it right now isn't feasible. Thought I should get a jump on locating another bellhousing if needed.
Opinions please; do you think that bellhousing is dual pattern?
Thanks in advance guys.
Re: 65 Coronet 318 poly 4 speed conversion [Re: peabodyracing] #970706
04/10/11 08:13 PM
04/10/11 08:13 PM
Pataskala, Ohio
GTX70sixpack Offline
Pataskala, Ohio
I'm swapping an auto to 4spd in a 65 BelvedereII wagon and am using a early 70's aluminum bellhousing. The bell I took out of my 66 Coronet wagon poly/3spd was cast iron and heavy. Also I am using a 70 Road Runner 4spd and the original Belvedere driveshaft and yoke.
I recently put a 360 4spd with late model bellhousing in a 66 Dart wagon. Other than the z bar bracket, no problems. A few measurements, cut a bracket and welded on a pivot ball.
65 Belvedere II Station Wagon
69 Coronet R/T convertible
70 GTX
70'cuda
99 Dodge Diesel dually 4X4
Re: 65 Coronet 318 poly 4 speed conversion [Re: GTX70sixpack] #970707
04/10/11 08:41 PM
04/10/11 08:41 PM
Andrewh Online content
Andrewh  Online Content
any newer sb housing should work.
you will not be able to line up 1 bolt hole on the drivers side. Just throw that one away.
Re: 65 Coronet 318 poly 4 speed conversion [Re: peabodyracing] #970708
04/11/11 09:10 AM
04/11/11 09:10 AM
West Tennessee
rbstroker Offline
rbstroker  Offline
West Tennessee
The 1965 3 speed bellhousing is different than a 4 speed bellhousing. You will also have to cut the floor and weld in a 4 speed shift tunnel.
Re: 65 Coronet 318 poly 4 speed conversion [Re: rbstroker] #970709
04/11/11 10:30 AM
04/11/11 10:30 AM
Minnesota
Minnesota
Thanks all! Guess the hunt is on then. You've saved me some wasted time. Thanks again.
Re: 65 Coronet 318 poly 4 speed conversion [Re: peabodyracing] #970710
04/11/11 10:51 AM
04/11/11 10:51 AM
Belle Mead, NJ
65Frank Offline
super street
65Frank  Offline
super street
Belle Mead, NJ
When you say early 4 speed do you mean a ball and trunion with the flange on the output? Just asking because that's what's on the three speed.
Frank
Re: 65 Coronet 318 poly 4 speed conversion [Re: 65Frank] #970711
04/11/11 12:36 PM
04/11/11 12:36 PM
Mi,U.S.A.
mike s Offline
mike s  Offline
Mi,U.S.A.
You will need to modify the bracket that holds the ball for the torque tube.It won't line up with the later bell.You also won't be able to use both bracket bolts only one will work.You could fab a new bracket that uses both holes but I used mine with only one bolt and it worked fine.I have pics if you need them.
Leave the gun.......take the Cannoli's....Mike
Re: 65 Coronet 318 poly 4 speed conversion [Re: mike s] #970712
04/11/11 01:40 PM
04/11/11 01:40 PM
Minnesota
Minnesota
This forum is amazing; with the stroke of a few keys I can get a wealth of info from people 'who've been there before'.
I knew about the infamous ball and trunion and had been sitting on this 4 speed for a good 20 years thinking it would come in handy sometime. Also had picked up a 4 speed tunnel hump earlier this winter. I didn't think of the Z bar pivot line up though; that should be manageable.
Thanks again guys!
