Any amatuer chemists out there? #970462
04/10/11 03:46 PM
04/10/11 03:46 PM
SW Ohio
AAR-B4 Offline OP
AAR-B4  Offline OP
SW Ohio
Or professional. I have given up trying to keep the glycerin inside my Autometer fuel pressure gauge.
I have disassembled it enough to drain the liquid but I would like to remove the film with a solvent.
Hot soapy water does not work, has anybody been successful at this?
Re: Any amatuer chemists out there? [Re: AAR-B4] #970463
04/10/11 04:02 PM
04/10/11 04:02 PM
Kirkland, Washington
Pacnorthcuda Offline
glycerin is soluble in water and alcohol so if water ain't cutting it go to Alcohol. Methyl/Denatured even Rubbing (isopropyl) will work
Re: Any amatuer chemists out there? [Re: Pacnorthcuda] #970464
04/10/11 07:07 PM
04/10/11 07:07 PM
Southern by Choice
Shoozy Offline
I have a foot fetish
Shoozy  Offline
Southern by Choice
Agree on the alcohol. It is also soluble in ethylene glycol. Try a bit of pure EG based antifreeze and then rinse with water. Either that or an alcohol should take good care of the issue.
Old, tired, and sometimes broke down. Me, not my car...
Re: Any amatuer chemists out there? [Re: Shoozy] #970465
04/10/11 09:25 PM
04/10/11 09:25 PM
SW Ohio
AAR-B4 Offline OP
AAR-B4  Offline OP
SW Ohio
Thanks for the suggestions. I'll let you know how it works.
Re: Any amatuer chemists out there? [Re: AAR-B4] #970466
04/11/11 05:34 PM
04/11/11 05:34 PM
SW Ohio
AAR-B4 Offline OP
AAR-B4  Offline OP
SW Ohio
Here's my report:
Soapy hot water and household rubbing alcohol just turned the glycerin to small globs of jelly.
So I tried lab type isopropyl and it still did not dissolve the glycerin but it sure did remove the lettering from the gauge face.
Lesson learned.
Re: Any amatuer chemists out there? [Re: AAR-B4] #970467
04/11/11 06:52 PM
04/11/11 06:52 PM
SOUTH JERSEY
HEMIFRED Offline
HEMIFRED  Offline
SOUTH JERSEY
my last attempt nearly got me busted
home of the
Sox and Martin Hemi Duster
