swing out bar for certification? #970372
04/10/11 12:55 PM
04/10/11 12:55 PM
Port Mcneill,B.C.Canada
I
Islandcuda Offline OP
I
Hi guys I,m told my swing out bar will fail cert. for going in the 9,s cause not enough meet at the end of the bar and the hollow pin, anyone else run into this, thanks Tim
67 cuda new best 1.395 60 10.240 at 128.58mph
Re: swing out bar for certification? [Re: Islandcuda] #970373
04/10/11 12:56 PM
04/10/11 12:56 PM
I
I
another
Re: swing out bar for certification? [Re: Islandcuda] #970374
04/10/11 09:01 PM
04/10/11 09:01 PM
Eighty Four, PA
B G Racing Offline
B G Racing  Offline
Eighty Four, PA
Rule of thumb:width of material from the pin to the end of the bar should be 1 and 1/2 times the diameter of the pin,minimumum would be distance equal to the pin diameter.
Re: swing out bar for certification? [Re: B G Racing] #970375
04/10/11 11:18 PM
04/10/11 11:18 PM
I
I
Thanks I will add on just to be sure
Re: swing out bar for certification? [Re: Islandcuda] #970376
04/11/11 12:15 AM
04/11/11 12:15 AM
The Swamp
Sixpak Offline
Sixpak  Offline
The Swamp
Are those C/E Swing outs?
Re: swing out bar for certification? [Re: Sixpak] #970377
04/11/11 01:50 AM
04/11/11 01:50 AM
I
I
I beleive they were morrison, not sure, my friend who is fabricater ordered and isntalled, has never been an issue, but after backhaving I may go into the 9,s and a freind tried to certify his and failed cause of hollow pin and not enough meet at the end of the bar.
Re: swing out bar for certification? [Re: Islandcuda] #970378
04/11/11 10:51 AM
04/11/11 10:51 AM
Indiana
Scott58 Offline
Scott58  Offline
Indiana
Has anyone got a cert with removable joints like these? I thought there was a post a few weeks back but can't find it.
Scott
Re: swing out bar for certification? [Re: Scott58] #970379
04/11/11 01:22 PM
04/11/11 01:22 PM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
Where are they from?
Re: swing out bar for certification? [Re: Dodgem] #970380
04/11/11 02:10 PM
04/11/11 02:10 PM
Indiana
Scott58 Offline
Scott58  Offline
Indiana
Re: swing out bar for certification? [Re: Scott58] #970381
04/11/11 02:18 PM
04/11/11 02:18 PM
Texas
dannysbee Offline
dannysbee  Offline
Texas
Don't see how that would be of much use on a door bar. Take too long to tighten it up. Now for a removable seat/belt bar two of those would be the thing.
Getting old just means you were smarter than some and luckier than others.
Re: swing out bar for certification? [Re: Scott58] #970382
04/11/11 02:19 PM
04/11/11 02:19 PM
Between a rock & a hard place
cudadoug Offline
cudadoug  Offline
Since you've upgraded to a back half, upgrade to this:
http://www.cachassisworks.com/p-528-swing-out-clevis-dual-eyebolt1-5-8x134-cages.aspx
It's clean, VERY strong and I know it will cert to 8.50 if installed properly.
Re: swing out bar for certification? [Re: cudadoug] #970383
04/11/11 03:42 PM
04/11/11 03:42 PM
South Bend, Indiana
mistress Offline
mistress  Offline
South Bend, Indiana
I Agree, Chris Alston Chassis Works clevis is a nice piece, NHRA Accepted and will cert to 8.50 because mine did
Re: swing out bar for certification? [Re: mistress] #970384
04/11/11 10:43 PM
04/11/11 10:43 PM
I
I
Not enough timeto get that peice where I live, if I would of known this was an issue i would of ordered it when I put my back half kit from allston in. Oh well, after numerous emails and pics and phone calls I have to add on enough meat to the end of the bar to come to 1.625 inches from the hole. May be that measurement from center of hole but I,ll ad a little extra. The cert guy is coming to the island this weekend to cert a bunch of cars starting at one end of the island and ending up 3/4 of the way. Thanks guys
Re: swing out bar for certification? [Re: Islandcuda] #970385
04/11/11 10:46 PM
04/11/11 10:46 PM
Indiana
W5Duster436 Offline
W5Duster436  Offline
Indiana
Here is what they put on mine and told me it would cert to 8.50 with no issues.
'70 Duster - SDSS 436 W5 4spd (Gone)
'71 Dodge D100
'70 Dodge W100
Re: swing out bar for certification? [Re: cudadoug] #970386
04/21/11 04:05 PM
04/21/11 04:05 PM
Auburn, Indiana
The Duster Offline
The Duster  Offline
Auburn, Indiana
Looks like the same piece at A.R.T for $24 less.
http://www.appliedracing.com/roll-bars-c...evis-mount.html
