1965 / 1966 Fury's ..what tire size have you used ? #96946
07/30/08 09:43 AM
07/30/08 09:43 AM
S.E. South Dakota !
bigdad Offline OP
Still Posting A Lot
bigdad  Offline OP
Still Posting A Lot
S.E. South Dakota !
I need larger tires on the Fury, I thought these would fill the wheel openings but, they are way too small
currently 235 x 60's on rear 225's on front
Not excited about the looks of the wheels on the car either so..
Thinking american racing Torque Thrusts
and going 255 x 70's on rear but, wonder if they will fit
The main problem is getting them on between brake drum and wheel opening , once they are on I think they will fit
Anyone have any expericance on what will fit on them ?
The lips of fools bring them strife, and their mouths invite a beating.Proverbs 18:6
Re: 1965 / 1966 Fury's ..what tire size have you used ? [Re: bigdad] #96947
07/30/08 10:10 AM
07/30/08 10:10 AM
Janesville, WI
P
polarconvert Offline
P
Janesville, WI
I can fit 265's on the rear of my 65 polara if jack the car by the frame and let the axle sag. They say 270's will fit
Re: 1965 / 1966 Fury's ..what tire size have you used ? [Re: polarconvert] #96948
07/30/08 10:13 AM
07/30/08 10:13 AM
S.E. South Dakota !
bigdad Offline OP
Still Posting A Lot
bigdad  Offline OP
Still Posting A Lot
S.E. South Dakota !
265 ---70's ?
Re: 1965 / 1966 Fury's ..what tire size have you used ? [Re: bigdad] #96949
07/30/08 10:09 PM
07/30/08 10:09 PM
S.E. South Dakota !
bigdad Offline OP
Still Posting A Lot
bigdad  Offline OP
Still Posting A Lot
S.E. South Dakota !
Re: 1965 / 1966 Fury's ..what tire size have you used [Re: bigdad] #96950
07/30/08 10:15 PM
07/30/08 10:15 PM
Madera, CA.
MowP4rsn Offline
MowP4rsn  Offline
Madera, CA.
Uh, those 16" wheels? 15"?? 17"???
Re: 1965 / 1966 Fury's ..what tire size have you used [Re: MowP4rsn] #96951
07/30/08 10:22 PM
07/30/08 10:22 PM
Great White North
Furyman Offline
Furyman  Offline
Great White North
On my 66 Fury wagon I ran 275 60 15's on a 15x7 Magnum.....lots of room.I've got 15 x 10 Alum slots for my 65 wagon.....have not bought tires yet.
"Long Live Mopars"
Re: 1965 / 1966 Fury's ..what tire size have you used [Re: MowP4rsn] #96952
07/30/08 10:26 PM
07/30/08 10:26 PM
85086
moparpollack Offline
Lil Herman
Lil Herman
85086
Re: 1965 / 1966 Fury's ..what tire size have you used [Re: Furyman] #96953
07/30/08 10:28 PM
07/30/08 10:28 PM
S.E. South Dakota !
bigdad Offline OP
Still Posting A Lot
bigdad  Offline OP
Still Posting A Lot
S.E. South Dakota !
Any pictures ?
mine are 15 x 7's ...
Re: 1965 / 1966 Fury's ..what tire size have you used [Re: bigdad] #96954
07/30/08 10:30 PM
07/30/08 10:30 PM
S.E. South Dakota !
bigdad Offline OP
Still Posting A Lot
bigdad  Offline OP
Still Posting A Lot
S.E. South Dakota !
I need more tire ..Looks dumb
Re: 1965 / 1966 Fury's ..what tire size have you used [Re: bigdad] #96955
07/30/08 10:35 PM
07/30/08 10:35 PM
Madera, CA.
MowP4rsn Offline
MowP4rsn  Offline
Madera, CA.
I'd think about upping the size to 17" wheels. I'll bet that would look really good on that station weapon.
Re: 1965 / 1966 Fury's ..what tire size have you used [Re: MowP4rsn] #96956
07/30/08 10:42 PM
07/30/08 10:42 PM
Madera, CA.
MowP4rsn Offline
MowP4rsn  Offline
Madera, CA.
Maybe something like these chromed Dodge Nitro wheels?
I'm sure there's probably a good deal to be found for take-offs at a dealership in the area.
Or howzabout these stock 17" steelies off a 1500 Ram?
Re: 1965 / 1966 Fury's ..what tire size have you used [Re: MowP4rsn] #96957
07/30/08 10:47 PM
07/30/08 10:47 PM
S.E. South Dakota !
bigdad Offline OP
Still Posting A Lot
bigdad  Offline OP
Still Posting A Lot
S.E. South Dakota !
I better get my bullet proof vest on but ..
Yeah, I did consider 17's ..
My 1st thought is shuffle the ones over from my truck to check fitment see if they fit
But, the plan would be for the grey centered ones
although, those steel ones you posted other than that cheap looking center are not awful
Re: 1965 / 1966 Fury's ..what tire size have you used [Re: bigdad] #96958
07/30/08 10:51 PM
07/30/08 10:51 PM
Madera, CA.
MowP4rsn Offline
MowP4rsn  Offline
Madera, CA.
They don't look too bad, do they?
And the bid price to start is CHEAP, with just 2 days left.
Plus, you get to stick with the SILVER paint scheme
Re: 1965 / 1966 Fury's ..what tire size have you used [Re: MowP4rsn] #96959
07/30/08 10:59 PM
07/30/08 10:59 PM
S.E. South Dakota !
bigdad Offline OP
Still Posting A Lot
bigdad  Offline OP
Still Posting A Lot
S.E. South Dakota !
Kicker is I think the bolt pattern is 5 on 5 1/2 ?
Re: 1965 / 1966 Fury's ..what tire size have you used [Re: bigdad] #96960
07/30/08 11:01 PM
07/30/08 11:01 PM
Madera, CA.
MowP4rsn Offline
MowP4rsn  Offline
Madera, CA.
Really?? Dang...I did not know that.
Well, the Charger/Magnum/300 stock steelie is 17", close to 5 on 4.5"
Re: 1965 / 1966 Fury's ..what tire size have you used [Re: MowP4rsn] #96961
07/30/08 11:06 PM
07/30/08 11:06 PM
S.E. South Dakota !
bigdad Offline OP
Still Posting A Lot
bigdad  Offline OP
Still Posting A Lot
S.E. South Dakota !
Unless they changed something thats the bolt pattern on them
Now, the jeep cherokees I think are 4 1/2
I would run straight old steel wheels with red line tires but, I'm affraid thats a WHOLE lotta white with that big billboard
I like this look too
Re: 1965 / 1966 Fury's ..what tire size have you used ? [Re: bigdad] #96962
07/30/08 11:20 PM
07/30/08 11:20 PM
Montana
FuryUs Offline
FuryUs  Offline
Montana
Mine's a '67, but fitment is probably similar. I have 255/60/17s on the back. A buddy has 255/70/15s on a '67 Fury vert. In both cases, you've got to jack it way up by the frame to get the tire in there.
Cragar has some relatively cheap steel 17s available from Summit. I used to have Mustang bullit wheels on my wagon but switched to the steelies a couple months ago.
Re: 1965 / 1966 Fury's ..what tire size have you used [Re: bigdad] #96963
07/30/08 11:21 PM
07/30/08 11:21 PM
Madera, CA.
MowP4rsn Offline
MowP4rsn  Offline
Madera, CA.
Gotta admit the Torque Thrusts look good.
Here's a Jeep wheel that is 17" and has 4.5" bolt pattern...but it's pricey too
Re: 1965 / 1966 Fury's ..what tire size have you used [Re: MowP4rsn] #96964
07/30/08 11:23 PM
07/30/08 11:23 PM
Madera, CA.
MowP4rsn Offline
MowP4rsn  Offline
Madera, CA.
That Jeep wheel is for a Liberty, btw, so I imagine a Dodge Nitro has the same bp.
HOLLANDER INTERCHANGE #9057
Re: 1965 / 1966 Fury's ..what tire size have you used [Re: MowP4rsn] #96965
07/31/08 12:50 AM
07/31/08 12:50 AM
Cochise County Arizona
SPWC Offline
SPWC  Offline
Im currently running a 275/60/15 on the rear of my wagon with 15X7 Cop car rims. Fit nicely,no rubbing.
