Re: +++++++ TEAM BRADSHAW OUTLAW 10.5 +++++++
[Re: TrWaters]
#968779
04/09/11 07:55 PM
04/09/11 07:55 PM
Quicktree
[Re: rickstershemi]
#968782
04/10/11 10:24 AM
04/10/11 10:24 AM
Posts: 3,544 Syracuse,NY
CompWedgeEngines
Syracuse,NY
Looks like they made some tuning changes....he hasnt been near 185 MPH yet.....very cool. Are there any websites reporting anything on this race?
RIP Monte Smith
[Re: CompWedgeEngines]
#968783
04/10/11 11:07 AM
04/10/11 11:07 AM
Quicktree
thats what I was thinking. 185 has the mph to run in the 3 sec zone. but I bet they are giving it up down low.
[Re: 105630]
#968785
04/10/11 12:56 PM
04/10/11 12:56 PM
Quicktree
the bullet has results posted in trash be trash section by Drag Radial
link?
[Re: DusterDave]
#968788
04/10/11 03:26 PM
04/10/11 03:26 PM
Quicktree
I plugged in that 185 MPH and guessed Jimmy's race weight at 3,200 lbs. and based on that, they're putting almost 3,000 HP to the rear wheels.
just think if they could get the 60' down, and I doubt that car is 3200lbs
[Re: aarlucas]
#968790
04/10/11 03:33 PM
04/10/11 03:33 PM
Quicktree
Based on what I have seen with the TAFC, 185 will get you very low 4's. Every 3.9 we ran has always been in the 190's. You have to keep in mind the coefficent of drag on his car too. It is like a brick on the nose, where a FC is a little more less brick like. He is getting close though!
Good job Jimmy.
i think it was the last outlaw 10.5 race there was a car that ran 3.90s at 185.
[Re: DusterDave]
#968791
04/10/11 03:35 PM
04/10/11 03:35 PM
Quicktree
What kind of 60' times are they getting?
not positive but probably around 1.11s or slower
[Re: DusterDave]
#968792
04/10/11 04:01 PM
04/10/11 04:01 PM
Posts: 11,684 W. Kentucky
justinp61
W. Kentucky
3200#, I doubt it, I'd guess 2200-2400#
[Re: justinp61]
#968793
04/10/11 05:10 PM
04/10/11 05:10 PM
Posts: 4,616 Kissimmee Fl.
dusturbd340W5
Kissimmee Fl.
cant remember what Jimmy said but I believe it was more than 2400#
70 duster full chassis super pro 416 CNC Indybrock heads 727 w/brake
best so far 1.212 60 6.219 in 1/8 at 110.88 9.768 at 137.81 1/4
[Re: justinp61]
#968794
04/10/11 05:20 PM
04/10/11 05:20 PM
Posts: 3,619 Norwich CT USA
Defbob
Norwich CT USA
Outlaw 10.5 cars are required to weigh a minimum of 3000lbs (big block) and Jimmie also does not have stock front frame rails so he might have a weight penalty on top of that.
