Re: How do Indy's rocker shafts hold up to roller springs?
[Re: Old School]
#965906
04/04/11 10:45 PM
04/04/11 10:45 PM
Posts: 469 Tennessee
steeldust
Tennessee
Just curious if the Indy rocker arm shafts like they provide w/ their 440-1 kit hold up to 600#s OK, or if they're not beefy enough and end up oblonged / egg shaped after usage. These would be for use w/ plain-bearing style rockers, not needle-bearing fulcrums.
shafts seem ok, but this is what there rocker arms do with to much pressure....
I broke three 1.5 offset rocker on a 640 lift cam last year they were IND black arms i know four guys that have broke rockers and they went to JESEL but i got me a set of T&D shaft mount rockers i got 1.6 rockers on a 725 lift cam i will see if they hold up in a 572 stoker. GOOD LUCK
[Re: Old School]
#965910
04/05/11 11:31 AM
04/05/11 11:31 AM
Posts: 16,928 NC
440Jim
NC
What spring pressures and how much time were on the rockers?
[Re: steeldust]
#965911
04/05/11 11:33 AM
04/05/11 11:33 AM
Posts: 16,928 NC
440Jim
NC
What spring pressures and how many passes when you started breaking them?
[Re: BradH]
#965912
04/05/11 11:50 AM
04/05/11 11:50 AM
Posts: 16,492 On the run…
BloFish
On the run…
Did you give up on the VI's Brad and switch to Indy?
It really doesn't matter whether you win or lose… as long as you look good doing it!
‘65 A100 ‘69 ‘Cuda ‘73 Vega GT ‘06 Mega Cab ‘14 Mercedes SLK
[Re: BloFish]
#965913
04/05/11 11:54 AM
04/05/11 11:54 AM
BradH
The Stage VIs have a pending deal on them; this is just looking into options for shafts for the Victors since Hughes doesn't sell theirs separately anymore (only as part of rocker arm kits) and my used RAS shafts are going w/ the Stage VIs. Will still be using Hughes/Probe rockers w/ the Victors.
[Re: RADAMX]
#965917
04/05/11 02:53 PM
04/05/11 02:53 PM
Posts: 644 Minnesota
Barnstorm
Minnesota
We use Mopar perf HD shafts with Comp 948 springs {950@ 1.20 open] and Indy black 1.5's...geometry is dead on with plenty of oil uptop. 440-1 offsets....broke 1 ex rocker in 15 yrs. Lucky?
The little old lady from Pasadena is back!
[Re: Old School]
#965918
06/16/11 01:54 PM
06/16/11 01:54 PM
Posts: 4,072 Mo.
racerx
Mo.
...I broke a rocker a few weeks ago with the car idling in the garage can't remember the spring presure off hand but the cam is a solid roller with 693/706 with 274/277@50 and it broke a rocker almost like in the shape of a C
[Re: 440Jim]
#965919
06/16/11 02:14 PM
06/16/11 02:14 PM
Posts: 877 ky
68roadrunner
ky
mine was good for a hundred passes with 300# on the seat and 690# open. and also one shaft was cracked when i took them off.
did not know they offered a thick wall version, thats what i get for not buying from bg.
