Re: 904 Trans Temp Gauge
[Re: dOoC]
#965876
04/04/11 09:45 PM
04/04/11 09:45 PM
RapidRobert
LOTS of people put the sender in-the-pan. The FLASH-TEMP coming off the converter is interesting data but no really real-world operating temp.
Yep Doc you are right, k.i.s.s. put it in the pan & call it good esp as I think you need expensive/diff fitting(s) to get it in the a cooler line & in contact w the fluid. I do put the sender in the side of the pan rather than protrude from the bottom & need to pick the right place on the side so no interference w the VB EDIT the side doesn't drain as completely as the bottom but gets enough out so the pan can come off to ch the filter/adj bands (always a good idea) WO spillage
