904 Trans Temp Gauge #965868
04/04/11 03:56 PM
04/04/11 03:56 PM
Under My Car
Mopar_Country Offline OP
Under My Car
I am getting ready to install a Transgo TF-2 reprogramming kit, and while I'm there I want to install a trans temp gauge. My question is which line should I put it in, the front or rear?
Re: 904 Trans Temp Gauge [Re: Mopar_Country] #965869
04/04/11 04:03 PM
04/04/11 04:03 PM
the front
that one as it comes right from the TC, where fluid is the hottest
Re: 904 Trans Temp Gauge [Re: RapidRobert] #965870
04/04/11 06:02 PM
04/04/11 06:02 PM
Under My Car
Under My Car
Do I want to check it where it's the hottest or do I want to check it on the return to see how effective my cooling system is?
Re: 904 Trans Temp Gauge [Re: Mopar_Country] #965871
04/04/11 06:09 PM
04/04/11 06:09 PM
Florida STAYcation
dOc ! Offline
The village idiot's idiot
dOc !  Offline
Florida STAYcation
LOTS of people put the sender in-the-pan. The FLASH-TEMP coming off the converter is interesting data but no really real-world operating temp.
Re: 904 Trans Temp Gauge [Re: dOc !] #965872
04/04/11 06:13 PM
04/04/11 06:13 PM
Under My Car
Under My Car
I thought about that, I'm already installing a drain plug in the pan and if I did that I would be twice as paranoid about a leak. I'm going to look into that option further.
Re: 904 Trans Temp Gauge [Re: Mopar_Country] #965873
04/04/11 06:17 PM
04/04/11 06:17 PM
Florida STAYcation
dOc ! Offline
dOc !  Offline
Florida STAYcation
INSTALLING a drain-plug ? ... why not just buy a deep 904 steel pan WITH the plug ?? ...THEN put the sender on the side of that.
Re: 904 Trans Temp Gauge [Re: dOc !] #965874
04/04/11 06:35 PM
04/04/11 06:35 PM
Under My Car
Under My Car
Budget is about over for this year. I may do that next year when I yank the motor and trans. Pan plug 6 bucks.
New pan with plug 50 bucks and then add a filter extension 25 bucks.
Re: 904 Trans Temp Gauge [Re: Mopar_Country] #965875
04/04/11 08:09 PM
04/04/11 08:09 PM
Florida STAYcation
dOc ! Offline
dOc !  Offline
Florida STAYcation
ISN'T the filter extension included ? ... also .. the plug-kits that I am aware of are not-so-hot.
Re: 904 Trans Temp Gauge [Re: dOc !] #965876
04/04/11 09:45 PM
04/04/11 09:45 PM
Yep Doc you are right, k.i.s.s. put it in the pan & call it good esp as I think you need expensive/diff fitting(s) to get it in the a cooler line & in contact w the fluid. I do put the sender in the side of the pan rather than protrude from the bottom & need to pick the right place on the side so no interference w the VB EDIT the side doesn't drain as completely as the bottom but gets enough out so the pan can come off to ch the filter/adj bands (always a good idea) WO spillage
