Re: Covertible tops
[Re: 70B5Vert]
#964840
04/02/11 10:53 PM
04/02/11 10:53 PM
1_WILD_RT
Management Trainee
Management Trainee
Today? Who Knows?
The best are generally made by Robbins but Robbins only sells to professional installers.. Most restoration suppliers will sell you a top made by Kee..
And no the trim is not reproduced... Find used parts & restore it..
Re: Covertible tops
[Re: 1_WILD_RT]
#964841
04/02/11 11:16 PM
04/02/11 11:16 PM
Posts: 7,547 Albany, NY
67SATisfaction
The member whose name is actually Art
Albany, NY
The good news is it's stainless, so a salvage yard could be a good source.
65 Satellite hardtop 361/4bbl console 727 2.76 67 Satellite convert 383/2bbl column 727 3.23 67 Lancia Fulvia Sport 1.3 Zagato. Alloy body, 1.3L V4 DOHC 4-spd 67 Lancia Fulvia Rallye 1.3. Alloy panel, 1.3L V4 DOHC 4-spd 71 Alfa Romeo GT Junior 1300 Zagato, 1.3L 4cyl DOHC hemi 5-spd 82 Alfa Romeo GTV6 2.5L SOHC hemi V6 5-spd transaxle 75 Maserati Bora US spec 4.9L DOHC hemi V8 5-spd ZF 77 Maserati Khamsin Euro spec 4.9L DOHC hemi V8 5-spd ZF 07 Aston Martin DB9 6.0L DOHC V12 6spd transaxle
Re: Covertible tops
[Re: 67SATisfaction]
#964842
04/02/11 11:20 PM
04/02/11 11:20 PM
Posts: 59 kansas
70B5Vert
kansas
I have my trim, its just that some decided to put snaps on them and drilled 45 holes in the trim!!!
I have someone who can weld up stainless so that will probably be the route I will go.
Re: Covertible tops
[Re: 70B5Vert]
#964844
04/03/11 11:20 AM
04/03/11 11:20 AM
Posts: 5,193 NEW JERSEY
AARCONV
NEW JERSEY
let me know if you find a good guy that fills the holes ...I have the same problem...
Re: Covertible tops
[Re: cudaize]
#964847
04/03/11 09:41 PM
04/03/11 09:41 PM
Posts: 59 kansas
70B5Vert
kansas
Wow,
Great Advice from everyone. Thank You
Top is still on the car. Replaced the lines and lift cylinders a couple of years ago.
The trim is going to be welded by a Airline mechanic who can weld about anything. I've seen his racecar and he welded everything on it. I'll have the chore of buffing it out.
