low mount alternator pics #962862
03/31/11 06:27 AM
03/31/11 06:27 AM
metro detroit
turner Offline OP
turner  Offline OP
metro detroit
I have ditched my mech. fuel pump and stepping up my engine program, this year I want to also remount my alternator. I was at Mancini racing Tuesday and looked at the DMI unit and decided it was not the best scenario for me, using the cnc'd motor plate that Mancini offers looks like there will be interference with the top mounting hole. I was expecting a different mount but thats what they carry, can someone post a pic of alternetive low mount alternator brackets, thanks in advance
Re: low mount alternator pics [Re: turner] #962863
03/31/11 06:54 AM
03/31/11 06:54 AM
Taxes & Virus's R-US, NY
Dragula Online content
Dragula  Online Content
Re: low mount alternator pics [Re: Dragula] #962864
03/31/11 10:03 AM
03/31/11 10:03 AM
metro detroit
turner Offline OP
turner  Offline OP
metro detroit
I have a Moroso generic adjustment arm similar to the one in your pic, but I have mine mounted on the drivers side on the top of the plate. Ill have to look at my plate to see if I have the material to mount my bracket down there. Does anyone have a pic of the low mount made by magnum hp or someone else on the board, I thought I remember it on Andyf,s cnc plate wich is the same plate that I have.
Re: low mount alternator pics [Re: turner] #962865
03/31/11 10:35 AM
03/31/11 10:35 AM
MR_P_BODY Offline
MR_P_BODY  Offline
I made a mount that mounts where the fuel pump did,
not on my motor plate
Re: low mount alternator pics [Re: Dragula] #962866
03/31/11 10:57 AM
03/31/11 10:57 AM
Q
Quicktree Offline
Quicktree  Offline
Q
hey that looks just like mine
Re: low mount alternator pics [Re: MR_P_BODY] #962867
03/31/11 11:01 AM
03/31/11 11:01 AM
Lubbock,TX
DavidDean Offline
DavidDean  Offline
Lubbock,TX
Mine mounts off my engine plate
Re: low mount alternator pics [Re: turner] #962868
03/31/11 11:35 AM
03/31/11 11:35 AM
Oregon,USA
RAT PATROL Offline
RAT PATROL  Offline
Oregon,USA
I saw this one somewhere, not sure where.
Re: low mount alternator pics [Re: turner] #962869
03/31/11 11:56 AM
03/31/11 11:56 AM
AndyF Offline
AndyF  Offline
Mancini has an alternator kit that hangs on the CNC motor plate. Part number is AR207. It works with the Powermaster 8162 or 8172 alternator.
Re: low mount alternator pics [Re: RAT PATROL] #962870
03/31/11 12:11 PM
03/31/11 12:11 PM
poplar bluff mo.
toplescuda Offline
I Whine
toplescuda  Offline
I Whine
poplar bluff mo.
i just took mine and set it where it wanted to be and still lined up with a pulley .took some construction paper made a pattern, traced it out on some 1/2plate alum. and used the 2 lower timing chain cover bolts on passenger side. came out pretty good and will set bout 2 inches above k frame
1970 barracuda convert. 1 of 59
1970 pro street A.A.R. clone (panther pink)
1971 charger
2015 hellcat challenger. Redline red
2014 quad cab 4x4 ram 8 speed hemi
Re: low mount alternator pics [Re: AndyF] #962871
03/31/11 12:11 PM
03/31/11 12:11 PM
Charleston
sixpackgut Offline
Drag Week Mod Champion
sixpackgut  Offline
Charleston
Re: low mount alternator pics [Re: sixpackgut] #962872
03/31/11 09:36 PM
03/31/11 09:36 PM
metro detroit
turner Offline OP
turner  Offline OP
metro detroit
Thanks for all the input guys I appreciate it, I have a few different ways to go. I like the cleanliness in the pic that andyf posted, doesnt get much easier than that if you have the room, that was a great link that was added to the post as well. I will post what I come up with later this week, thanks again
Re: low mount alternator pics [Re: AndyF] #962873
03/31/11 10:12 PM
03/31/11 10:12 PM
Arizona
PolyDart Offline
PolyDart  Offline
Arizona
Andy, you're too modest
Re: low mount alternator pics [Re: AndyF] #962874
04/02/11 02:35 AM
04/02/11 02:35 AM
Mooresburg, Tn
'72CudaRacer Offline
Mooresburg, Tn
Andy, I called Mancini thursday and they said they don't have that kit. Has to be drop shipped from the factory. So I ordered it from PSO. Hope its here next week.
Brian
Re: low mount alternator pics [Re: '72CudaRacer] #962875
04/02/11 12:39 PM
04/02/11 12:39 PM
AndyF Offline
AndyF  Offline
Should be in your mail box on Monday.
Re: low mount alternator pics [Re: AndyF] #962876
04/02/11 01:36 PM
04/02/11 01:36 PM
Indiana
Scott58 Offline
Scott58  Offline
Indiana
Andy-
Is the AR207 setup for a specific dampner/pulley configuration or is there some depth adjustment? I'm wondering if there is an issue with mounting a crank trigger wheel behind the pulley and then not having the alternator line up. Looks like the top bracket could be spaced out simply but the bottom one is not so obvious. Maybe you have a picture of the kind of setup I'm talking about?
Scott
Re: low mount alternator pics [Re: Scott58] #962877
04/02/11 09:55 PM
04/02/11 09:55 PM
AndyF Offline
AndyF  Offline
It is designed for a specific combination of parts. Depth can be adjusted by the use of spacers, but there aren't any extra spacers in the kit. It works with the parts that are in the picture.
I originall designed a "universal" low mount kit but it cost too much to mfg. So I gave up on that approach and went with a combination of parts that a lot of racers are using. ATI damper + MSD crank trigger + DMI pulley.
Re: low mount alternator pics [Re: Scott58] #962878
04/02/11 09:58 PM
04/02/11 09:58 PM
glendora, ca.
Deepockets Offline
Deepockets  Offline
glendora, ca.
here's one more. i came off the fuel pump bolts and have the upper and lower braces that are adjustable.
