leaky head gasket #962696
03/30/11 09:51 PM
03/30/11 09:51 PM
Wisconsin
BLONDE BARRACUDA Offline OP
Wisconsin
I noticed after haveing my engine built a coulple years ago that I had an external head gasket leak I wasnt woried about it cause I never noticed any water in my oil so I figured it was only external and didnt care but today I took all the plugs out and turned the engine over to set my valves and I had antifreeze coming out of no. 1 there didnt appear to be any antifreeze in the oil I figured I would just put some block sealer in and keep an eye one the oil any recomendations? the headgaskets are cometic with 13.9 to 1 compresion I've heard of several people having them leak and claimed block sealer fixed the problem
Re: leaky head gasket [Re: BLONDE BARRACUDA] #962697
03/30/11 10:40 PM
03/30/11 10:40 PM
On the south side of Nowhere
S/ST 3040 Offline
S/ST 3040  Offline
Here's what happens if you run an engine after firing
with water in a cylinder. It distorts the bearing and
possibly the rod but, bad things are sure to follow if
it's ignored.
Re: leaky head gasket [Re: S/ST 3040] #962698
03/31/11 08:09 AM
03/31/11 08:09 AM
Wisconsin
Wisconsin
I am not sure what you are telling me I caught the fact that there was antifreeze in the cylinder before fireing it then I removed the water from cylinder I still havent started it and there did not appear to be any antifreeze in the oil so not sure what to do I think I am going to flush the system and put block\headgasket sealer in it and see what happens. this happened after setting since November
Re: leaky head gasket [Re: BLONDE BARRACUDA] #962699
03/31/11 09:18 AM
03/31/11 09:18 AM
detroit, mi
POS Dakota Offline
POS Dakota  Offline
detroit, mi
Why not just pull the head to see what's happening and while you're there, change the headgasket?
Re: leaky head gasket [Re: POS Dakota] #962700
03/31/11 09:37 AM
03/31/11 09:37 AM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
what he said
Coming soon!!!!
Re: leaky head gasket [Re: POS Dakota] #962701
03/31/11 09:38 AM
03/31/11 09:38 AM
s.w.fl
bonefish Offline
bonefish  Offline
s.w.fl
been there,even if its just a little the water sitting in the cyl.will etch the cyl.wall where it lays,specialy if it sits for a week or more.
Re: leaky head gasket [Re: bonefish] #962702
03/31/11 11:49 AM
03/31/11 11:49 AM
Wisconsin
Wisconsin
thanks to all for the replies and suggestions
