tti headers..... #962611
03/30/11 08:12 PM
03/30/11 08:12 PM
Grove, OK
hosehead Offline OP
hosehead  Offline OP
Grove, OK
I was just curious if anyone has had problems w/ the coatings on these. I need a set of headers and have heard some problems have been had by some. I was thinking the ceramic coated and wondering if the thermal barrier is worth the dough. thanks guys.
63 Plymouth savoy
65 d100
66 dart race project
58 plymouth suburban
Re: tti headers..... [Re: hosehead] #962612
03/30/11 08:29 PM
03/30/11 08:29 PM
Nevada
Darter6 Offline
Darter6  Offline
Nevada
I have installed 10-12 sets of TTI's over the years and have never had any problems. Read the directions before installing for tips.Before starting the engine wash any grease, oil, fingerprints , off with soap and water on a cloth "before" starting the engine. I learn things the hard way so that is why I stated "before" twice. On my race car I have the coating Both inside and out.They have been on the car for 5 years and look new.You won't be sorry spending the extra cash.One other tip that I have learned is to install new engine and tranny mounts at the same time. You will be much happier with the fit of your new headers.
Re: tti headers..... [Re: Darter6] #962613
03/30/11 08:34 PM
03/30/11 08:34 PM
Fairview Tennessee
SV_MOPARS Offline
SV_MOPARS  Offline
Fairview Tennessee
tti's , buy the doug's from summit.
Re: tti headers..... [Re: SV_MOPARS] #962614
03/30/11 08:48 PM
03/30/11 08:48 PM
Appalachia
RedRam Offline
RedRam  Offline
Appalachia
I ran the nickle/chrome tti's and now Dougs.
The cppa/tti's turned a dark color and then sarted rusting where two tubes come close to each other.
The Dougs were beautifull at the beginning but turned dull quickly and within 5-6months later I started seeing rust specs here and there. Last march when I pulled my motor the Dougs were covered with rust specs(they were on the truck for about 9 months).
Cppa/tti's were used on a daily driver in ALL weather. The Dougs were never driven in the rain but the truck was parked outside 24/7.
Re: tti headers..... [Re: SV_MOPARS] #962615
03/30/11 08:54 PM
03/30/11 08:54 PM
ILLinois
DartGTS Offline
super street
DartGTS  Offline
super street
ILLinois
Hello:
Don't know what your putting headers on....but i'll pass this along. When I had my race car (2 door post 67 Dart with 440) I had a interference problem with the combination of ARP Studs, Edelbrock heads, and TTI Under chassis headers (1 7/8) The studs stuck up just enough to keep the header flange plate from fitting flat on head surface. Yes the studs were installed correctly.
I solved it by grinding a slight angle down taper to the top of each stud. Allowing the flange to slid over and fit flush.
I'm sure others have seen this issue also. I might mention that the block had been surface trued how much that small amount contributed to the problem I don't know.
As to the coating these were chrome and of course turned that wonderful blue color in no time.
Anyway thats a small bit of FYI.
Maynard
Re: tti headers..... [Re: hosehead] #962616
03/30/11 08:57 PM
03/30/11 08:57 PM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
For the coatings to last, your tuneup needs to be good. If it's off the coatings are gonna suffer.
Yes I think the interior thermal coating is worth it. It keeps under hood temps down which helps with vapor lock. And it helps keep the header from rusting from the inside out. I think it makes the header a little more quiet too.
TTI recomends that you don't use there headers for your first fireup until your sure the tuneup is right. It makes all the difference in coatings.
Re: tti headers..... [Re: DartGTS] #962617
03/30/11 08:59 PM
03/30/11 08:59 PM
Cincinnati, Ohio
Cincinnati, Ohio
Hello:
Maynard
Bluing of chrome headers usaully indicates a overy rich condition. imo
Re: tti headers..... [Re: Challenger 1] #962618
03/30/11 09:03 PM
03/30/11 09:03 PM
ILLinois
DartGTS Offline
super street
DartGTS  Offline
super street
ILLinois
Hello:
Yep I don't doubt that. Had my learning curve, with that car adjusted shall we say.
Maynard
Re: tti headers..... [Re: DartGTS] #962619
03/30/11 10:04 PM
03/30/11 10:04 PM
NJ
rth Offline
rth  Offline
NJ
put tti polished ceramic on my 440.had them sitting in garage over 6 years.just got car running this month,so far still look good.i always thought bluing was due to lean condition.
Re: tti headers..... [Re: rth] #962620
03/31/11 12:06 AM
03/31/11 12:06 AM
Maryland
cudaboone Offline
cudaboone  Offline
Maryland
tti's on my 528 hemi for three years. still look new except where i had some oil drops and the spots turned black. Nothing you can really see. When i get the bucks, i am putting tti from the headers back. Including the exhaust tips. Headers are coated inside.
Re: tti headers..... [Re: rth] #962621
03/31/11 12:09 AM
03/31/11 12:09 AM
Grove, OK
hosehead Offline OP
hosehead  Offline OP
Grove, OK
thanks for the replies guys, just concerned about the coating. I am installing the headers on a 340 in a 69 barracuda so there wont be any fit issues as far as I know.
63 Plymouth savoy
65 d100
Re: tti headers..... [Re: hosehead] #962622
03/31/11 02:23 AM
03/31/11 02:23 AM
So Cal
autoxcuda Online content
autoxcuda  Online Content
So Cal
Corey, just did it last weekend with my Cuda with TTI ceramic and thermal. It was the first startup of a new motor....
http://www.youtube.com/watch?v=s0_-lJTtFpY
Re: tti headers..... [Re: autoxcuda] #962623
03/31/11 03:19 AM
03/31/11 03:19 AM
Mesa, Arizona
dart4forte Offline
dart4forte  Offline
Mesa, Arizona
The SCCA techs let you run with that gas filter?
Re: tti headers..... [Re: autoxcuda] #962624
03/31/11 03:22 AM
03/31/11 03:22 AM
Grove, OK
hosehead Offline OP
hosehead  Offline OP
Grove, OK
Hey thanks Steve! Will you be at Mats? Let me know, your car sounds pretty good. Lets chat soon!
63 Plymouth savoy
65 d100
Re: tti headers..... [Re: hosehead] #962625
03/31/11 03:40 AM
03/31/11 03:40 AM
So Cal
So Cal
Saturday only. Milling around swap and midway. Car will not be there. But the car will be at Spring Fling Speed Festival April 14, 2011 and Spring Fling of course.
Re: tti headers..... [Re: autoxcuda] #962626
03/31/11 09:22 AM
03/31/11 09:22 AM
San Jose, California
DennisH Offline
Vacation
DennisH  Offline
Vacation
TTI's. Thermal ceramic. 6 years. Good service. Dig deep. Buy from a Moparts vendor like A-Z Nick or at a Show. Got mine from them, they seemed peeved and were not cheap.
Did have to do a little ding-l-do ya for the pitmnan arm on the B Body.
Re: tti headers..... [Re: hosehead] #962627
03/31/11 09:53 AM
03/31/11 09:53 AM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
If you like balck, any standard header stripped and painted with VHT's high temp paint will work.
Coming soon!!!!
