Re: tti headers.....
[Re: SV_MOPARS]
#962615
03/30/11 08:54 PM
03/30/11 08:54 PM
Posts: 393 ILLinois
DartGTS
super street
super street
ILLinois
Hello: Don't know what your putting headers on....but i'll pass this along. When I had my race car (2 door post 67 Dart with 440) I had a interference problem with the combination of ARP Studs, Edelbrock heads, and TTI Under chassis headers (1 7/8) The studs stuck up just enough to keep the header flange plate from fitting flat on head surface. Yes the studs were installed correctly. I solved it by grinding a slight angle down taper to the top of each stud. Allowing the flange to slid over and fit flush. I'm sure others have seen this issue also. I might mention that the block had been surface trued how much that small amount contributed to the problem I don't know. As to the coating these were chrome and of course turned that wonderful blue color in no time. Anyway thats a small bit of FYI.
Maynard
[Re: DartGTS]
#962617
03/30/11 08:59 PM
03/30/11 08:59 PM
Challenger 1
Cincinnati, Ohio
Maynard
Bluing of chrome headers usaully indicates a overy rich condition. imo
[Re: hosehead]
#962622
03/31/11 02:23 AM
03/31/11 02:23 AM
Posts: 27,477 So Cal
autoxcuda
So Cal
thanks for the replies guys, just concerned about the coating. I am installing the headers on a 340 in a 69 barracuda so there wont be any fit issues as far as I know.
Corey, just did it last weekend with my Cuda with TTI ceramic and thermal. It was the first startup of a new motor....
http://www.youtube.com/watch?v=s0_-lJTtFpY
[Re: autoxcuda]
#962623
03/31/11 03:19 AM
03/31/11 03:19 AM
Posts: 16,161 Mesa, Arizona
dart4forte
Mesa, Arizona
The SCCA techs let you run with that gas filter?
[Re: autoxcuda]
#962624
03/31/11 03:22 AM
03/31/11 03:22 AM
Posts: 1,935 Grove, OK
hosehead
Grove, OK
Hey thanks Steve! Will you be at Mats? Let me know, your car sounds pretty good. Lets chat soon!
63 Plymouth savoy 65 d100 66 dart race project 58 plymouth suburban
[Re: hosehead]
#962625
03/31/11 03:40 AM
03/31/11 03:40 AM
autoxcuda
So Cal
Saturday only. Milling around swap and midway. Car will not be there. But the car will be at Spring Fling Speed Festival April 14, 2011 and Spring Fling of course.
