Installing Hydraulic lifters #961771
03/29/11 03:45 PM
03/29/11 03:45 PM
Toronto
mshred Offline OP
mshred  Offline OP
Toronto
When installing hydraulic lifters, whether they be flat tappet or roller, should I install the lifters pumped up or drained of oil totally? How do you guys do it? I am resusing all my old hydraulic roller lifters and was just curious about correct method for reinstalling. I know the oil holes on the lifters should be facing the camshaft, but im unsure on installing them pumped up or not
thanks
Re: Installing Hydraulic lifters [Re: mshred] #961772
03/29/11 04:34 PM
03/29/11 04:34 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
I like to put in a few squirts of oil so they are not dry , when you install the valvetrain the pushrod will pus out as much as they need to.
Re: Installing Hydraulic lifters [Re: JohnRR] #961773
03/29/11 04:56 PM
03/29/11 04:56 PM
Rock Springs
Bob_Coomer Offline
Bob_Coomer  Offline
Rock Springs
sure I wipe some kind of lubricant on the outside of the lifters. But I dont like to have them full of oil. Unless you dont care about measure or looking at lifter pre-load. Which most dont, but later complain about how noisy the valve train is on the Comp XE cams.. LOL
Re: Installing Hydraulic lifters [Re: mshred] #961774
03/29/11 05:45 PM
03/29/11 05:45 PM
organ
maximum entropy Offline
organ
i install hydraulics dry, which makes it really easy to measure/verify preload, then i run the oil pump to pump 'em up.
Re: Installing Hydraulic lifters [Re: maximum entropy] #961775
03/29/11 06:35 PM
03/29/11 06:35 PM
Airdrie, AB
Mills Offline
Mills  Offline
Airdrie, AB
trying to adjust rockers on hydrualics with oil in them will usually lead you to an incorrect setting.
Re: Installing Hydraulic lifters [Re: Mills] #961776
03/29/11 06:38 PM
03/29/11 06:38 PM
Eighty Four, PA
B G Racing Offline
B G Racing  Offline
Eighty Four, PA
Comp Cams says not to pump them up before installing.
Re: Installing Hydraulic lifters [Re: maximum entropy] #961777
03/29/11 06:51 PM
03/29/11 06:51 PM
Toronto
mshred Offline OP
mshred  Offline OP
Toronto
this seems like consensus then...I will install them dry to set lifter preload...and then after that before starting up the engine is priming the oiling system enough to get oil to the lifters for when the engine is first fired up? or after setting preload should I add some oil to the lifters?
Re: Installing Hydraulic lifters [Re: mshred] #961778
03/29/11 07:03 PM
03/29/11 07:03 PM
organ
organ
if you run the oil pump for a minute or so, the lifters will be good to go. probably a good idea to turn the engine also.
Re: Installing Hydraulic lifters [Re: maximum entropy] #961779
03/29/11 10:47 PM
03/29/11 10:47 PM
Toronto
mshred Offline OP
mshred  Offline OP
Toronto
sounds good
