Re: Installing Hydraulic lifters
[Re: mshred]
#961774
03/29/11 05:45 PM
03/29/11 05:45 PM
Posts: 5,080 organ
maximum entropy
organ
i install hydraulics dry, which makes it really easy to measure/verify preload, then i run the oil pump to pump 'em up.
[Re: maximum entropy]
#961775
03/29/11 06:35 PM
03/29/11 06:35 PM
Posts: 1,379 Airdrie, AB
Mills
Airdrie, AB
trying to adjust rockers on hydrualics with oil in them will usually lead you to an incorrect setting.
#961777
03/29/11 06:51 PM
03/29/11 06:51 PM
Posts: 3,421 Toronto
mshred
Toronto
this seems like consensus then...I will install them dry to set lifter preload...and then after that before starting up the engine is priming the oiling system enough to get oil to the lifters for when the engine is first fired up? or after setting preload should I add some oil to the lifters?
#961779
03/29/11 10:47 PM
03/29/11 10:47 PM
mshred
Toronto
if you run the oil pump for a minute or so, the lifters will be good to go. probably a good idea to turn the engine also.
sounds good
