Re: E body a-pillar plastic trim parts being reproduced?
[Re: PAINT IT BLACK]
#958580
03/25/11 07:58 PM
03/25/11 07:58 PM
Posts: 2,059 NW/Indiana - Chi town
ricomondo
Palco has them,but that is a last ditch resort. I didnt like them on a previous Challenger I had. Check with BE&A, or PG classics, they may have them
GY3 71 Demon 340
#958581
03/25/11 10:04 PM
03/25/11 10:04 PM
Posts: 1,822 Colorado
denfireguy
Colorado
I have a pair of medium blue ones from DashTop but I do not see them on their web site anymore. Craig
2014 Ram 1500 Laramie, 73 Cuda Previous mopars: 62 Valiant, 65 Fury III, 68 Fury III, 72 Satellite, 74 Satellite, 89 Acclaim, 98 Caravan, 2003 Durango Only previous Non-Mopar: Schwinn Tornado
#958582
03/26/11 02:19 PM
03/26/11 02:19 PM
Posts: 1,163 NORTHERN VA
THESHAKERPROJECT
NORTHERN VA
I don't see them anywhere...
I would find a nice set of orig as there not that hard to find...
#958584
03/27/11 03:07 PM
03/27/11 03:07 PM
Posts: 4,324 St. Louis, Mo
318 Stroker
St. Louis, Mo
I called one Mopar salvage yard and they told me they had none, but thought they were being reproduced. According to BE&A and PG Classics sites, they don't have them for e body. The reason I don't want originals is because of uv damage. Mine cracked, I jb welded them and they cracked again when I tried to install. Guess I'll call around.
Check around some more for good used ones. They seem to be fairly common. But be aware that there were two different recipes for the plastic. There are the hard brittle kind which easily crack, and the flexible ones which are almost indestructable. Also, I believe there were two different screw hole configurations for the various years, so be aware of that too....
I would place a "wanted" ad here on Moparts.
[Re: 318 Stroker]
#958585
03/27/11 03:20 PM
03/27/11 03:20 PM
Posts: 1,912 Anchorage, Alaska
Iceman01
Challenged
Challenged
Anchorage, Alaska
... be aware that there were two different recipes for the plastic. There are the hard brittle kind which easily crack, and the flexible ones which are almost indestructable. Also, I believe there were two different screw hole configurations for the various years...
[Re: 318 Stroker]
#958587
03/28/11 10:05 AM
03/28/11 10:05 AM
Posts: 7,647 Houston Texas
PAINT IT BLACK
Got a CHIP on my shoulder
Houston Texas
[Re: Dante]
#958590
03/28/11 08:42 PM
03/28/11 08:42 PM
Posts: 1,084 Long Island, NY
70plymA34
Long Island, NY
I have them Pillar Posts
The current repro a-pillar posts are good for a driver but not made out of the same material and dont have the same look as the originals. They are good for fit but very glossy probably due to not being injected molded. If there is a way to knock the gloss down they would blend in better. its to bad the guy that made those excellent ebody door panels make the a pillars as well. it would be a nice compliment to an interior restoration.
