Re: OK Gen 3 type hemi stuff....
[Re: Garceau]
#957138
03/23/11 06:18 PM
03/23/11 06:18 PM
Posts: 3,354 ohio
HEMIDARTS
ohio
[Re: Garceau]
#957141
03/23/11 08:02 PM
03/23/11 08:02 PM
Posts: 17,876 S.E. Michigan
ZIPPY
S.E. Michigan
The 440 is based on an aftermarket, Mopar Performance Aluminum Gen 3 hemi block. Same architecture as 5.7/6.1.
Rich H.
Esse Quam Videri
[Re: ZIPPY]
#957142
03/23/11 08:08 PM
03/23/11 08:08 PM
Posts: 3,354 ohio
HEMIDARTS
ohio
[Re: fishy340]
#957144
03/24/11 02:01 PM
03/24/11 02:01 PM
ZIPPY
S.E. Michigan
Thx and I'm sorry if I killed the thread I'd suggest joining lxforums.com if you want to see alot of gen 3 engine combos. Usually the tech info is not very detailed but at least you can get ideas of cam/head/displacement combos which is better than nothing. Just keep in mind they're all oriented towards use in a modern car...and as in every forum, beware of BS. Now hopefully somebody will post about another motor/car.
Rich H.
Esse Quam Videri
[Re: hemidup]
#957149
04/09/11 05:16 PM
04/09/11 05:16 PM
Posts: 1,828 houston texas
gremlinsteve
houston texas
same combo i just ground up a cam for made 700 plus ft lb at 2000 rpm using that displacement and head unit. that was wheel torque btw..on a chasis dyno. so add about 18 percent dt loss
stecve
if You Like Gremlinsteve. Gremlinsteve Likes You.
