Lost my cam card, Indy CM3 #955023
03/21/11 07:45 AM
03/21/11 07:45 AM
A shed in England
Tig Offline OP
Tig  Offline OP
A shed in England
As the title of the post suggests, I've misplaced, thrown out or lost the info. Cam is an Indy CM3, I can remember most stuff but not the recommended lash settings Anyone using the same cam who can share the info?
I can only blame old age
TIA
Tig
Re: Lost my cam card, Indy CM3 [Re: Tig] #955024
03/21/11 11:00 PM
03/21/11 11:00 PM
UK
602heavy Offline
602heavy  Offline
UK
Don't know about that cam Tig maybe call Indy?...........or break out dial indicator & measure lash ramp , multiplying this figure by rocker ratio will net lash settings.
Re: Lost my cam card, Indy CM3 [Re: 602heavy] #955025
03/21/11 11:55 PM
03/21/11 11:55 PM
Brisbane Australia
572B1 Offline
572B1  Offline
Brisbane Australia
Send Bob George a pm, Bobs an indy dealer.
Re: Lost my cam card, Indy CM3 [Re: 572B1] #955026
03/22/11 12:26 PM
03/22/11 12:26 PM
Virginia Beach, VA
O
Old School Offline
Old School  Offline
O
Virginia Beach, VA
my cam card for the cm-2 says, for 1.5 rockers intake lash .023, exhaust lash .023. i dont know if they are the same as the cm-3 thou..
68 cuda formula S 588" bb 5sp
70 CUDA CONVERT 500" 5SP (SUBLIME)
70 CUDA CONVERT 500" 5SP (PLUMCRAZY):TOO MUCH HORSEPOWER, IS ALMOST ENOUGH!
Re: Lost my cam card, Indy CM3 [Re: Old School] #955027
03/22/11 06:28 PM
03/22/11 06:28 PM
A shed in England
Tig Offline OP
Tig  Offline OP
A shed in England
Thanks for the help guys, cam card found in the obvious place
Re: Lost my cam card, Indy CM3 [Re: Tig] #955028
03/22/11 07:58 PM
03/22/11 07:58 PM
NC
440Jim Offline
440Jim  Offline
NC
Now that you found it,
can you post a scan so people can save it and help the next guy?
Re: Lost my cam card, Indy CM3 [Re: 440Jim] #955029
03/23/11 03:19 PM
03/23/11 03:19 PM
A shed in England
Tig Offline OP
Tig  Offline OP
A shed in England
Sure, but since I don't have a scanner I'll type it.
Cam data Duration @ .05 in
Intake and ex lash .023 .024 .025 in (I'm guessing this is for 1.5 1.6 and 1.7 arms)
Lobe seperation 112.5 cam deg.
Valve overlap 65.8 crank deg.
Intake
Valve opens 32.3 'BTDC
C/L 108.5 'ATDC
Duration 282 Crank deg
Valve closes 69.7 'ABDC
lobe lift .479 in
Valve lift (1.5) .719 in
Exhaust
Valve opens 85.3 'BBDC
C/L 116.5 'BTDC
Valve closes 33.5 'ATDC
Duration 298.8 crank deg
Lobe lift .450 in
Valve lift (1.5) .675 in
HTH's Sorry I didn't think to add this before
Re: Lost my cam card, Indy CM3 [Re: Tig] #955030
03/23/11 03:47 PM
03/23/11 03:47 PM
NC
440Jim Offline
440Jim  Offline
NC
Exhaust
WOW, lots of duration at 0.050"
Re: Lost my cam card, Indy CM3 [Re: 440Jim] #955031
03/23/11 05:37 PM
03/23/11 05:37 PM
A shed in England
Tig Offline OP
Tig  Offline OP
A shed in England
Yes Why would that be?
Re: Lost my cam card, Indy CM3 [Re: Tig] #955032
03/23/11 07:45 PM
03/23/11 07:45 PM
Virginia Beach, VA
O
Old School Offline
Old School  Offline
O
Virginia Beach, VA
i show the cm-3 cam as 284/300 @.050. the cm-5 is 287/310 @.050
Re: Lost my cam card, Indy CM3 [Re: Old School] #955033
03/23/11 08:14 PM
03/23/11 08:14 PM
Akron, Ohio
ProSport Offline
ProSport  Offline
Akron, Ohio
Wow, what is the CM-1 and CM-2 at .050?
Re: Lost my cam card, Indy CM3 [Re: ProSport] #955034
03/23/11 10:19 PM
03/23/11 10:19 PM
Virginia Beach, VA
O
Old School Offline
Old School  Offline
O
Virginia Beach, VA
i have the cm-2 in my 580" street motor. it is 282/290 @.050. the cm-1 is 276/283 @.050. i'm re-doing my 500" motor now. it had the r-1 in it before at 272/276 @.050. i will be trying the cm-1 in that motor.i am going to dyno both cams. i will post the dyno results soon.
