Re: 4.7 engine problem need help!
[Re: BigTerry]
#953349
03/19/11 11:40 AM
03/19/11 11:40 AM
Posts: 515 Bolingbrook, IL
HemiRunner
super street
super street
Bolingbrook, IL
Yes, that is a common problem on the 4.7's. they spit the rocker due to the lifter failing. Not a bad idea to replace all the lifters while you're in there. You will also need to check the lifter bore in the head as they sometimes break when the lifter fails & it spits the rocker. If this happens, it's time for a new head. There is a trick to replace them without pulling the cams & timing chains all the way out. Find the tighteneing sequence for the cam hold downs & a little at a time loosen them in the reverse order just enough to get the rocker/followers out or just off the lifter to replace the lifter. When all done make sure everything is lined up & carefully snug the cam hold downs back down in sequence & then follow the torque steps.
Blown & Injected, need I say more?
71 Road Runner
04 Dodge Ram 2500 4x4 CTD
[Re: HemiRunner]
#953350
03/19/11 03:07 PM
03/19/11 03:07 PM
Posts: 6,906 IL, Aurora
ademon
IL, Aurora
At what milage are they failing? is it oil related?
[Re: ademon]
#953351
03/19/11 05:15 PM
03/19/11 05:15 PM
HemiRunner
super street
super street
Bolingbrook, IL
I have seen them in the 50,000 to over 100,000 range, so it's not a specific mileage to look for. All the ones I have done are due to internal lifter failure & it has been anything from them colapsing to seizing up. The new lifters seem to be better, but only time will tell.
71 Road Runner
[Re: 67Monaco]
#953357
03/20/11 12:14 PM
03/20/11 12:14 PM
HemiRunner
super street
super street
Bolingbrook, IL
Another issue that plagues the 3.7 & 4.7 is carbon build up on the exhaust valves. Carbon builds up & hangs the valve open & spits the rocker. Pros & Cons of the 3.7 4.7. Pros Mopar engine, sort of. Cons Carbon build up on ex valve - spits rocker Ex seats fall out - spits rocker Lifter colapses/seizes - can break head, spits rocker Sensitive to overheating - warps head what ya gonna do?
71 Road Runner
[Re: HemiRunner]
#953359
03/20/11 12:29 PM
03/20/11 12:29 PM
Posts: 341 New Jersey
U_Code_Cuda
New Jersey
WOW!! all these cons on the 4.7 and my 2000 Grand Cherokee has 233,000 with no engine or trans problems.... Any suggested maintenance to keep her alive longer
1970 R/T Challenger 4-speed 1971 Demon 340 3-speed
