Re: Adding an escape door to an Enclosed trailer
[Re: V10nacuda]
#951076
03/15/11 11:17 AM
03/15/11 11:17 AM
Posts: 52,972 Romeo MI
MR_P_BODY
Call any trailer manufacturer they have all the parts but it wont be cheap.... its no different than putting in a window in a house
[Re: Dragula]
#951078
03/15/11 11:51 AM
03/15/11 11:51 AM
MR_P_BODY
My local trailor place refused...I want one in mine, but they won't put it in. Says its not framed for one...I also assumed you could put one in like a window in a house, what do I know.
Dont know why they wouldnt frame it in... its just welding
[Re: julian2007]
#951081
03/15/11 12:58 PM
03/15/11 12:58 PM
Posts: 75,008 U.S.S.A.
JohnRR
U.S.S.A.
Its easy,I put in all my windows in my 44 foot goose, 1 inch square tube works perfect.Build a frame and install a emergency exit window,pull two leavers and the whole window pops out.Some times you can find them used at camper dealers (warranty for small defects like dents and scrapes)I gave 25 bucks each for all mine,there out there you just have to hunt.
He is looking for an escape DOOR , one you open so you can open the door of the car to make it easier to climb out .
[Re: Dragula]
#951082
03/15/11 01:04 PM
03/15/11 01:04 PM
Posts: 8,872 Ontario, Canada
Stanton
Don't question me!
Don't question me!
Ontario, Canada
Sometimes there are jobs that take way more effort than people imagine. Rather than quote what would sound like a ridiculous price they just give a reason for not doing it.
I've put a door in a trailer I owned. Yes, its like putting a window in a house - frame header, etc.. But you also need plates to run between the studs for both the hinges and the lock - the studs themselves have no strength. Its easily a full day job or more - particularly if you have to build the door. Personally, if I were doing it for someone they'd be into $1000. easily by the time it was done.
[Re: JohnRR]
#951083
03/15/11 01:26 PM
03/15/11 01:26 PM
Guitar Jones
Why not just install a winch so you won't have to open the door in the trailer?
'92 D250 Club Cab CTD, 47RH conversion, pump tweaks, injectors, rear disc and hydroboost conversion. '74 W200 Crew Cab 360, NV4500, D44, D60 and NP205 divorced transfer case. Rear disc and hydroboost coming soon! 2019 1500 Long Horn Crew Cab 4WD, 5.7 Hemi.
[Re: JohnRR]
#951084
03/15/11 01:30 PM
03/15/11 01:30 PM
Posts: 1,106 CANADA
Desmond
CANADA
Where can I get one for my life?
[Re: Desmond]
#951085
03/15/11 01:38 PM
03/15/11 01:38 PM
JohnRR
U.S.S.A.
temporary ...
[Re: JohnRR]
#951086
03/15/11 01:54 PM
03/15/11 01:54 PM
Posts: 901 oh
julian2007
oh
sorry must have miss read,But it is still the same just welding, get some tube and some .040 alum and make it.But for all the work a winch would be easier and cheaper. Here are my windows anyway
God made cold beer,good friends,hot ladies and race cars don't spit in his face by pi$$ing and moaning about how life sucks!!!
[Re: Dragula]
#951089
03/15/11 02:45 PM
03/15/11 02:45 PM
Posts: 22,696 Bitopia
jcc
Bitopia
Depending on the trailer, its construction, where the load is carried, and the location of the escape door to the axles and the hitch, I can see that piercing the solid outer skin might causing buckling issues even with a modest door frame. Furthermore fed regulations have been greatly increased lately on trailer designs on the engineering and testing the feds require (way overkill IMO). To have a company modify an existing trailer opens them to many legal liability issues, and not likely worth the potential hassle. Any company qualified to do it, likely won't, and any who will, might not be qualified. A good analogy is the fatigue structural failures on the liberty ships in WW2.
[Re: V10nacuda]
#951091
03/15/11 03:28 PM
03/15/11 03:28 PM
MR_P_BODY
I figured MR P would have done this before.. Didn't you build your own enclosed trailer???
I was thinking that I could cut out a 54" hole & keep it square & just re use the cut out to use as the actual door after adding structure. Take some square tube to connect all the cut uprights where the material was cut out.
The only thing I was concerned about was the hinges... would I have to connect 2-3 other up rights with square tube to support the hanging weight when the door is open??
Yes I did..... you double up the hinge side with studs(metal) header off the top... I used alum angle as trim... have you ever put a door in a house... same as a door or window... the main frames under the floor is the load carrying ... at least it is on mine
